8821 - Mark Call as SPAM
chuck47172
Does anyone know if the 8800 series feature "mark call as spam" works on a wireless 8821?
I don't think it does but if I'm wrong I could use some instructions on using the feature as I don't have an 8821 on hand.
Jaime Valencia
That feature was introduced on FW 12.7(1) but the 8821 doesn't use that FW
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/firmware/12-7-1/releasenotes/p881_b_rns-8800-1271.html#reference_98DB3351E2850A08F9D2C7C081449D87
To my knowledge, that feature is not available in the 8821, you can review the RN for the 8821 FW and if it is indeed supported, it has to be listed there, and which FW version introduced it.
java
if this helps, please rate
Jaime Valencia
java
