Yes, it supports meet-me, you can refer to the documentation and it will be mentioned there.
Yes, they can be used without the wired/wireless mic kits you can buy, those are used to expand the coverage of the device.
I don't believe they support background images, if they do, you can find that information in the phone admin guide, if there is no section for customizing the background, that's not an option.
java
if this helps, please rate
