8831 Conference Phone not dialing out on CME 10.5
Kevin Parsons
Hello!
I am fully aware of the ability to Fast Track config a 8831 IP conference phone on CME version 10.5, and have been able to get them to register on a couple of different customer systems so far.  Unfortunately, although the phone will register, get dial-tone, and call internal extensions, neither phone can make outbound calls.  When they try to dial outbound they get dead air.
Here is the config I am using:
voice register pool-type  8831
 phoneload-support
 description Cisco IP Phone 8831
 reference-pooltype 6941
voice register global
 mode  cme
 source-address 10.45.10.1 port 5060
 max-dn 300
 max-pool 58
 load 8831 sip8831.9-3-3-5
 authenticate register
 authenticate realm all
 timezone 8
 hold-alert
 mwi stutter
 mwi reg-e164
 voicemail 5000
 phone-redirect-limit 20
 tftp-path flash:
 file text
 create profile sync 0711514725045331
 ntp-server 10.0.0.2 mode directedbroadcast
 camera
 video
voice register dn  30
 number 1176
 allow watch
 pickup-call any-group
 pickup-group 1
 name Conference Phone
 label Conference x1176
 mwi
voice register template  1
 softkeys hold  Resume Newcall iDivert
 softkeys idle  Newcall Redial DND Pickup Gpickup Cfwdall
 softkeys ringIn  Answer DND iDivert
 softkeys connected  Endcall Hold Park Trnsfer iDivert Confrn
 conference admin
voice register pool  30
 busy-trigger-per-button 1
 id mac AC44.F211.0494
 type 8831
 number 1 dn 30
 template 1
 presence call-list
 dtmf-relay rtp-nte sip-kpml sip-notify
 username 1176 password adgj
 description Conference
 codec g711ulaw
 no vad
 paging-dn 90
 camera
 video
Obviously the IP's and phone numbers will be different on the other system, but the config is the same.
Has anyone else experienced this, and if so, how did you fix it?
Thanks in advance for any help!
Kevin
8 Replies 8
Kevin,
We'll need a bit more data before we can start diagnosing your problem.
How are you connecting to the PSTN? SIP Trunk? ISDN?
We'll need the appropriate debug outputs (debug ccsip messages or debug isdn q931) to start. Also please confirm if other phones are working properly.
FG
Yep, I figured as much, and just now was able to get the output of both debugs, as shown below:
This system is connected via PRI.  The first call was from ext. 4761 (307-432-4761) to my cell phone # (719-330-0326).   User gets dial tone, dials the number, then dead air.
Then we tried inbound calling from my cell to the same number, and got two way, clear audio.
000547: Mar 10 11:02:30.147 MDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:9@10.90.46.1;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.90.46.126:5060;branch=z9hG4bK747298aa
From: "Conference Phone 2" <sip:4761@10.90.46.1>;tag=ac44f210869503675d266562-0c091031
To: <sip:9@10.90.46.1;user=phone>
Call-ID: ac44f210-8695001e-4915f2d9-6239f16a@10.90.46.126
Max-Forwards: 70
Date: Tue, 10 Mar 2015 17:02:19 GMT
CSeq: 101 INVITE
User-Agent: Cisco-CP8831G/9.3.2
Contact: <sip:9B201F9C-21A6@10.90.46.126:5060;transport=udp>
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "Conference Phone 2" <sip:4761@10.90.46.1>;party=calling;id-type=subscriber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.2.0,X-cisco-xsi-8.5.1
Allow-Events: kpml,dialog
Content-Length: 352
Content-Type: application/sdp
Content-Disposition: sessterm ion;handling=optional
v=0
o=Cisco-SIPUA 2439 0 IN IP4 10.90.46.126
s=SIP Call
t=0 0
m=audio 17128 RTP/AVP 0 8 18 102 116 101
c=IN IP4 10.90.46.126
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:102 L16/16000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
000548: Mar 10 11:02:31.155 MDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 INVITE
Expires: 180
Content-Length: 352
Content-Disposition: seion;handling=optional
v=0
s=SIP Call
t=0 0
a=fmtp:116 mode=20
a=fmtp:101 0-15
a=sendrecv
000549: Mar 10 11:02:33.175 MDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 INVITE
Expires: 180
Content-Length: 352
Content-Disposition: session;handling=optional
v=0
s=SIP Call
t=0 0
a=fmtp:116 mode=20
a=fmtp:101 0-15
a=sendrecv
000550: Mar 10 11:02:37.207 MDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 INVITE
Expires: 180
Content-Length: 352
v=0
s=SIP Call
t=0 0
a=fmtp:116 mode=20
a=fmtp:101 0-15
a=sendrecv
000551: Mar 10 11:02:45.255 MDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 INVITE
Expires: 180
Content-Length: 352
v=0
s=SIP Call
t=0 0
a=fmtp:116 mode=20
a=fmtp:101 0-15
a=sendrecv
000552: Mar 10 11:02:49.815 MDT: ISDN Se0/0/1:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 3074324707
000553: Mar 10 11:02:49.819 MDT: ISDN Se0/0/1:23 Q931: Sending SETUP  callref = 0x4C73 callID = 0xCBF4 switch = primary-ni interface = User
000554: Mar 10 11:02:49.819 MDT: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x4C73
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98393
                Exclusive, Channel 19
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x2180, '3074324707'
                Plan:ISDN, Type:National
        Called Party Number i = 0x80, '19702216655'
                Plan:Unknown, Type:Unknown
000555: Mar 10 11:02:49.851 MDT: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0xCC73
000556: Mar 10 11:02:51.795 MDT: ISDN Se0/0/1:23 Q931: RX <- PROGRESS pd = 8  callref = 0xCC73
        Progress Ind i = 0x8288 - In-band info or appropriate now available
000557: Mar 10 11:02:54.219 MDT: ISDN Se0/0/1:23 Q931: RX <- CONNECT pd = 8  callref = 0xCC73
000558: Mar 10 11:02:54.223 MDT: ISDN Se0/0/1:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x4C73
% Ambiguous command:  "t"
IMT-CheyenneCleveland#
000559: Mar 10 11:03:33.063 MDT: ISDN Se0/0/1:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x4C73
        Cause i = 0x8090 - Normal call clearing
000560: Mar 10 11:03:33.083 MDT: ISDN Se0/0/1:23 Q931: RX <- RELEASE pd = 8  callref = 0xCC73
000561: Mar 10 11:03:33.083 MDT: ISDN Se0/0/1:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x4C73
000562: Mar 10 11:03:51.095 MDT: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x662F
                Standard = CCITT
        Channel ID i = 0xA18381
                Preferred, Channel 1
        Facility i = 0x9F8B0100A115020101020100800D506172736F6E73204B6576696E
                Protocol Profile =  Networking Extensions
                0xA115020101020100800D506172736F6E73204B6576696E
                Component = Invoke component
                        Invoke Id = 1
                        Operation = CallingName
                                Name Presentation Allowed Extended
                                Name = Parsons Kevin
        Calling Party Number i = 0x2180, '7193300326'
        Called Party Number i = 0x80, '4761'
000563: Mar 10 11:03:51.099 MDT: ISDN Se0/0/1:23 Q931: Received SETUP  callref = 0xE62F callID = 0x0137 switch = primary-ni interface = User
000564: Mar 10 11:03:51.111 MDT: //214770/4273596380F2/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4761@10.90.46.126:5060 SIP/2.0
Via: SIP/2.0/UDP 10.90.46.1:5060;branch=z9hG4bK15A26A9B
Remote-Party-ID: <sip:7193300326@10.90.46.1>;party=calling;screen=no;privacy=off
From: <sip:7193300326@10.90.46.1>;tag=70586960-1A17
To: <sip:4761@10.90.46.126>
Date: Tue, 10 Mar 2015 17:03:51 GMT
Call-ID: 427491B3-C67E11E4-A3EBB0AE-58947A89@10.90.46.1
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 1114855779-3330150884-2163352809-3005374160
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M1
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1426007031
Contact: <sip:7193300326@10.90.46.1:5060>
Call-Info: <sip:10.90.46.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: kpml, telephone-event
Content-Disposition: session;handling=required
Content-Length: 290
v=0
o=CiscoSystemsSIP-GW-UserAgent 1754 5630 IN IP4 10.90.46.1
s=SIP Call
c=IN IP4 10.90.46.1
t=0 0
m=audio 23004 RTP/AVP 0 100 101
c=IN IP4 10.90.46.1
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=fmtp:101 0-16
a=ptime:20
000565: Mar 10 11:03:51.111 MDT: ISDN Se0/0/1:23 Q931: TX -> CALL_PROC pd = 8  callref = 0xE62F
        Channel ID i = 0xA98381
000566: Mar 10 11:03:51.123 MDT: //214770/4273596380F2/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Tue, 10 Mar 2015 17:03:40 GMT
CSeq: 101 INVITE
Server: Cisco-CP8831G/9.3.2
Content-Length: 0
000567: Mar 10 11:03:51.215 MDT: //214770/4273596380F2/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:4761@10.90.46.126>;tag=ac44f210869503683fe76b0b-504ec658
CSeq: 101 INVITE
Remote-Party-ID: "Conference Phone 2" <sip:4761@10.90.46.1>;party=called;id-type=subscriber;privacy=off;screen=yes
Content-Length: 0
000568: Mar 10 11:03:51.219 MDT: ISDN Se0/0/1:23 Q931: TX -> ALERTING pd = 8  callref = 0xE62F
000569: Mar 10 11:03:59.667 MDT: //214770/4273596380F2/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Tue, 10 Mar 2015 17:03:49 GMT
CSeq: 101 INVITE
Content-Length: 204
v=0
o=Cisco-SIPUA 2806 0 IN IP4 10.90.46.126
s=SIP Call
t=0 0
m=audio 21252 RTP/AVP 0 101
a=fmtp:101 0-15
a=sendrecv
000570: Mar 10 11:03:59.671 MDT: ISDN Se0/0/1:23 Q931: TX -> CONNECT pd = 8  callref = 0xE62F
        Connected Number i = 0x8081, '4761'
000571: Mar 10 11:03:59.671 MDT: //214770/4273596380F2/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:9B201F9C-21A6@10.90.46.126:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.90.46.1:5060;branch=z9hG4bK15A2712B4
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
000572: Mar 10 11:03:59.695 MDT: ISDN Se0/0/1:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x662F
000573: Mar 10 11:04:07.615 MDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:7193300326@10.90.46.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.90.46.126:5060;branch=z9hG4bK2804da88
From: <sip:4761@10.90.46.126>;tag=ac44f210869503683fe76b0b-504ec658
To: <sip:7193300326@10.90.46.1>;tag=70586960-1A17
Max-Forwards: 70
Date: Tue, 10 Mar 2015 17:03:57 GMT
CSeq: 101 BYE
Content-Length: 0
000574: Mar 10 11:04:07.631 MDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 10 Mar 2015 17:04:07 GMT
Server: Cisco-SIPGateway/IOS-15.3.3.M1
CSeq: 101 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=396,OS=63360,PR=395,OR=63200,PL=0,JI=0,LA=0,DU=7
Content-Length: 0
000575: Mar 10 11:04:07.651 MDT: ISDN Se0/0/1:23 Q931: TX -> DISCONNECT pd = 8  callref = 0xE62F
000576: Mar 10 11:04:07.675 MDT: ISDN Se0/0/1:23 Q931: RX <- RELEASE pd = 8  callref = 0x662F
000577: Mar 10 11:04:07.675 MDT: ISDN Se0/0/1:23 Q931: TX -> RELEASE_COMP pd =
Received:
Max-Forwards: 70
CSeq: 101 INVITE
Expires: 180
Content-Length: 352
v=0
s=SIP Call
t=0 0
a=fmtp:116 mode=20
a=fmtp:101 0-15
a=sendrecv
Received:
Max-Forwards: 70
CSeq: 101 INVITE
Expires: 180
Content-Length: 352
v=0
s=SIP Call
t=0 0
a=fmtp:116 mode=20
a=fmtp:101 0-15
a=sendrecv
Received:
Max-Forwards: 70
CSeq: 101 INVITE
Expires: 180
Content-Length: 352
v=0
s=SIP Call
t=0 0
a=fmtp:116 mode=20
a=fmtp:101 0-15
a=sendrecv
Received:
Max-Forwards: 70
CSeq: 101 INVITE
Expires: 180
Content-Length: 352
v=0
s=SIP Call
t=0 0
a=fmtp:116 mode=20
a=fmtp:101 0-15
a=sendrecv
Received:
Max-Forwards: 70
CSeq: 101 INVITE
Expires: 180
Content-Length: 352
v=0
s=SIP Call
t=0 0
a=fmtp:116 mode=20
a=fmtp:101 0-15
a=sendrecv
                Standard = CCITT
                Standard = CCITT
                        Invoke Id = 1
Sent:
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 290
v=0
s=SIP Call
c=IN IP4 10.90.46.1
t=0 0
c=IN IP4 10.90.46.1
a=fmtp:100 192-194
a=fmtp:101 0-16
a=ptime:20
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 204
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=sendrecv
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Received:
Max-Forwards: 70
CSeq: 101 BYE
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 101 BYE
Content-Length: 0
Kevin,
Thanks for the info. Can you post a "show run". I'd like to take a look at your dial-peer configuration among a few other things.
I don't want to post the entire config, but here are the dial-peers for outbound and inbound calls.  Let me know what else you'd like to see and I'll get it for you.
dial-peer voice 911 pots
 translation-profile outgoing OUT_FULL_e164
 destination-pattern 911
 port 0/0/1:23
 forward-digits all
dial-peer voice 9911 pots
 destination-pattern 9911
 port 0/0/1:23
 forward-digits 3
dial-peer voice 9001 pots
 description Local Calls
 destination-pattern 9[2-9].........
 port 0/0/1:23
dial-peer voice 9002 pots
 description Long Distance Calls
 destination-pattern 91[2-9].........
 port 0/0/1:23
 prefix 1
dial-peer voice 9011 pots
 description International Calls
 destination-pattern 9011T
 port 0/0/1:23
 prefix 011
dial-peer voice 100 pots
 preference 1
 incoming called-number .T
 direct-inward-dial
 port 0/0/1:23
Thanks, Kevin.
All the configuration looks correct, you can place calls internally to other SCCP phones without an issue correct? Looks like you are negotiating g711ulaw so that wouldn't be a problem with a PRI.
Usually when a phone establishes a call but there is no audio is due to the RTP stream getting blocked by an ACL somewhere, but incoming calls work fine so we can rule that out.
I had a similar issue with 8831s, it turned out to be that the phone was discarding packets due to a corrupt firmware version. Can you access the statistics during a call and see it shows?
FG
LOL  your timing is killing me!
I'm not on site, and have to keep asking someone to help me place the calls.  I had JUST hung up with her and then saw this.
I'll get that capture as soon as I can.  I will say, though, that the firmware version that's being used was recommended by TAC.
Kevin
DokoweBazado
How did you resolve this?
I honestly don't remember what I did to get this to work; I completely forgot to keep this thread updated.   I do believe, however, that going to CME v11.0 will do the trick, as you're no longer fast tracking under CME 11.0.
