08-26-2016 07:54 AM - edited 03-17-2019 07:56 AM
Hi everyone,
I tried to match busy greetings that I've recorded but I've always matched the standard one.
After I launched RTMT, I saw that for CFA, CFNA & CFB I always matched FwdNoAnswerd as reason.
How can I fix this ?
Pls suggest
Solved! Go to Solution.
08-29-2016 01:42 AM
Can you check if the DN for which you are testing does not have any other shared instance. If yes, then you will need to adjust the busy Trigger on all the other shared DNs as well.
Deepak
08-26-2016 08:53 AM
Hi there,
- Is this a SCCP or SIP integration?
- does the DN you are testing with have a Busy Trigger of 1?
- is the Busy greeting set as active?
Cheers!
Rob
08-26-2016 09:12 AM
Hi Rob,
First of all, thank you for responding.
It is a SIP integration
I set the Busy Trigger (and Multiple Call) to 1.
I CUC, busy greeting is set as active.
08-29-2016 01:42 AM
Deepak
08-29-2016 02:49 AM
That made the job !
great, Thx !
08-29-2016 03:01 AM
Glad that it helped and thanks for marking the Correct Answer.
Deepak
08-26-2016 09:43 AM
Hi there,
First off, you are most welcome!
You may want to look at this bug in CUC 10.5;
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuq90525
Known Fixed Releases: |
(8)
08-28-2016 11:16 PM
