11-23-2016 09:10 AM - edited 03-17-2019 08:45 AM
We have a Cisco 8831 conference phone which is running Sip8831.9-3-3-5 firmware and we want to use it on a 3rd party PBX, so need the 3PCC firmware on it.
Firstly, is there any way I can tell if the firmware version above is an Enterprise image?
Secondly, if it is Enterprise is it possible to convert this to the 3PCC (cp-8831-sip.9-3-4-SR2-3PCC) version?
I have seen a note in the below document that has a note saying: After you upgrade to the enterprise firmware, you cannot revert to the third-party call control firmware.
I presume I know the answer to this, but just want confirmation that the 8831 is indeed running the Enterprise version of software already.
Chris
Solved! Go to Solution.
11-23-2016 09:29 AM
Hi Chris,
Please refer the following
https://supportforums.cisco.com/discussion/12912251/3pcc-cisco-7800-8800-phones
Manish
11-23-2016 09:29 AM
Hi Chris,
Manish
11-24-2016 02:17 AM
Thanks Manish. My own research told me as much, but I guess I thought it worthwhile posting in case there was a workaround I hadn't stumbled across.
11-24-2016 02:19 AM
Absolutely, no harm in confirming something if you are in doubt.
Manish
