02-24-2017 11:03 PM - edited 03-17-2019 09:39 AM
I will connect 3x 8831 conference phones to the customer's CME router on version 11.6 (ios 15.6(3)M1), but can not them connect them registered.
I have configured as below. Do anybody know how to configure?
voice register global
mode cme
source-address 10.148.20.4 port 5060
timeouts interdigit 5
max-dn 150
max-pool 50
load 8831 sip8831.10-3-1SR3-5
authenticate presence
authenticate register
authenticate realm all
olsontimezone Asia/Tokyo version 2011h
timezone 44
time-format 24
date-format D/M/Y
url directory http://10.148.20.4/localdirectory
tftp-path flash:
create profile sync 0001526421712519
ntp-server 10.16.64.124 mode unicast
conference hardware
voice register dn 1
number 6761
name 4M Meeting Room
label 4M Meeting Room(6761)
voice register dn 2
number 6772
name 4L Meeting Room
label 4L Meeting Room(6772)
voice register dn 3
number 6806
name 5M Meeting Room
label 5M Meeting Room(6806)
voice register template 1
exclude directory em
button-layout 1-4 line
button-layout 5-99 speed-dial
softkeys hold Resume Newcall
softkeys idle Newcall Redial Pickup Cfwdall
softkeys ringIn Answer
softkeys seized Endcall Redial Pickup Gpickup Cfwdall
softkeys connected Endcall Hold Trnsfer Park Confrn ConfList
softkeys remote-in-use Newcall
conference drop-mode local
conference admin
transfer max-length 12
voice register pool 1
busy-trigger-per-button 1
id mac AC44.F217.F7DC
type 8831
number 1 dn 1
template 1
dtmf-relay rtp-nte
voice-class codec 10
no vad
voice register pool 2
id mac AC44.F217.F725
type 8831
number 1 dn 2
template 1
dtmf-relay rtp-nte
no vad
voice register pool 3
id mac AC44.F217.F7E5
type 8831
number 1 dn 3
template 1
dtmf-relay rtp-nte
no vad
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
registrar server
voice class codec 10
codec preference 1 g711ulaw
codec preference 2 g729r8
Voie register all status is as blow.
VOICE REGISTER GLOBAL
CONFIG [Version=11.6]
Version 11.6
Mode is cme
Max-pool is 50
Max-dn is 150
Outbound-proxy is enabled and will use global configured value
Security Policy: DEVICE-DEFAULT
Forced Authorization Code Refer is enabled
Source-address is 10.148.20.4 port 5060
Load 8831 is sip8831.10-3-1SR3-5
Authenticate register
Authenticate realm all
Authenticate presence
NTP Server Address is 10.16.64.124
NTP Server Mode is: unicast
Time-format is 24
Date-format is D/M/Y
Time-zone is 44
Hold-alert is disabled
Mwi stutter is disabled
Mwi registration for full E.164 is disabled
Forwarding local is enabled
Video is disabled
Camera is disabled
Privacy is enabled
Privacy-on-hold is disabled
Conference hardware is enabled
Dst auto adjust is enabled
start at Apr week 1 day Sun time 02:00
stop at Oct week 8 day Sun time 02:00
Directory url is http://10.148.20.4/localdirectory
Max redirect number is 5
IP QoS DSCP:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for service
Telnet Level: 0
Tftp path is flash:/its
Generate text file is disabled
Tftp files are created, current syncinfo 0001526421712519
OS79XX.TXT is not created
timeout interdigit 5
timeout transfer recall 0
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
MWI unsolicited notify is disabled
Active registrations : 0
Total SIP phones registered: 0
Total Registration Statistics
Registration requests : 224
Registration success : 0
Registration failed : 216
unRegister requests : 0
unRegister success : 0
unRegister failed : 0
Auto-Register requests : 0
Attempts to register
after last unregister : 224
Last register request time : 15:56:29.043 JST Sat Feb 25 2017
Last unregister request time :
Register success time :
Unregister success time :
VOICE REGISTER DN
Dn Tag 1
Config:
Number is 6761
Preference is 0
Huntstop is disabled
Name 4M Meeting Room
Auto answer is disabled
Label is 4M Meeting Room(6761)
Pool 1 has this DN configured for line 1
Dn Tag 2
Config:
Number is 6772
Preference is 0
Name 4L Meeting Room
Label is 4L Meeting Room(6772)
Pool 2 has this DN configured for line 1
Dn Tag 3
Config:
Number is 6806
Preference is 0
Name 5M Meeting Room
Label is 5M Meeting Room(6806)
Pool 3 has this DN configured for line 1
VOICE REGISTER TEMPLATE
Temp Tag 1
Config:
Attended Transfer is enabled
Blind Transfer is enabled
Semi-attended Transfer is enabled
Conference softkey is enabled
Caller-ID block is disabled
DnD control is enabled
Video is disabled
Camera is disabled
Anonymous call block is disabled
softkey connected Endcall Hold Trnsfer Park Confrn ConfList
softkey hold Resume Newcall
softkey idle Newcall Redial Pickup Cfwdall
softkey seized Endcall Redial Pickup Gpickup Cfwdall
softkey remote-in-use Newcall
softkey ringIn Answer
Lpcor type none
paging-dn 0 [multicast]
conference admin: yes
conference add mode: all
conference drop mode: local
Pool 1 has this template configured
Pool 2 has this template configured
Pool 3 has this template configured
VOICE REGISTER DIALPLAN
VOICE REGISTER POOL
Pool Tag 1
Config:
Mac address is AC44.F217.F7DC
Type is 8831
Number list 1 : DN 1
Proxy Ip address is 0.0.0.0
DTMF Relay is enabled, rtp-nte
Call Waiting is enabled
DnD is disabled
Video is disabled
Camera is disabled
Night Service Bell is disabled
Busy trigger per button value is 1
keep-conference is enabled
registration expires timer max is 3600 and min is 60
template is 1
kpml signal is enabled
Lpcor Type is none
Transport type is udp
service-control mechanism is not supported
Registration method: per line
Privacy feature is not configured.
Privacy button is disabled
Reason for unregistered state:
No registration request since last reboot/unregister
paging-dn: config 0 [multicast] effective 0 [multicast]
Dialpeers created:
Statistics:
Registration requests : 0
Registration failed : 0
after last unregister : 0
Pool Tag 2
Config:
Mac address is AC44.F217.F725
Type is 8831
Number list 1 : DN 2
DnD is disabled
Video is disabled
Camera is disabled
template is 1
Lpcor Type is none
Dialpeers created:
Statistics:
Pool Tag 3
Config:
Mac address is AC44.F217.F7E5
Type is 8831
Number list 1 : DN 3
DnD is disabled
Video is disabled
Camera is disabled
template is 1
Lpcor Type is none
Dialpeers created:
Statistics:
Let me know if any more information is required.
Thank you.
Solved! Go to Solution.
02-25-2017 05:44 AM
- Make sure that your DHCP pool has option 150 pointing to CME
- Remove the following commands from 'voice register global'
- apply 'create profile' command on 'voice register global'
02-25-2017 05:44 AM
02-26-2017 04:47 PM
Thank you for your support, I was very sorry.
DHCP Option 150 was fine.
I could successfully register after deleting 3 lines of Voice register global.
thank you so much.
