8831 won't register to CME - SIP CONTACT issue?
Greg Winton
I have 3x Cisco 8831 conference phones which have worked on our CME for around 2 years now. But last week I noticed all 3 are showing "phone not registered".
Checking debugs I see:
9078392: Feb 4 16:23:47.541: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:10.200.13.1 SIP/2.0
Via: SIP/2.0/UDP 10.200.13.147:5060;branch=z9hG4bK3ad64bcf
From: <sip:8132@10.200.13.1>;tag=ac44f21020ac00075467629e-35707c7e
To: <sip:8132@10.200.13.1>
Call-ID: ac44f210-20ac0007-21f02de8-22d331a3@10.200.13.147
Max-Forwards: 70
Date: Sat, 01 Jan 2000 00:57:02 GMT
CSeq: 106 REGISTER
User-Agent: Cisco-CP8831G/9.3.2
Contact: <sip:A9B4-21B8@10.200.13.147:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-ac44f21020ac>";+u.sip!devicename.ccm.cisco.com="SEPAC44F21020AC";+u.sip!model.ccm.cisco.com="659"
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.2.0,X-cisco-xsi-8.5.1
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:14 Name=SEPAC44F21020AC Load=sip8831.9-3-3-5.loads Last=cm-closed-tcp"
Expires: 3600
9078393: Feb 4 16:23:47.545: //81041/029E8906AC74/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 Unauthorized
To: <sip:8132@10.200.13.1>;tag=10CC155C-2272
Date: Mon, 04 Feb 2019 16:23:47 GMT
Server: Cisco-SIPGateway/IOS-15.5.3.M2
CSeq: 106 REGISTER
WWW-Authenticate: Digest realm="",nonce="C1F2EEB44E7ACEEF",algorithm=MD5,qop="auth"
Content-Length: 0
To me it looks like the SIP Contact header is what is causing the issue?
If anymore debugs/information is needed I can collect these tomorrow morning.
Ryan Huff
Level 4
Level 4
What hardware platform?
What version of CME / IOS?
What version of phone firmware?
Can you post a sanitized show run (specifically, the voice service voip and global register sections)?
Hope this helps,
Ryan
(: ... please rate helpful posts ... :)
Hi Ryan,
Hardware - CISCO2921/K9
Version - CME 10.5 / IOS 15.5(3)M2
Phone firmware - 8831 sip8831.9-3-3-5
voice service voip
ip address trusted list
ipv4 X.X.X.X X.X.X.X -----> SIP provider
ipv4 X.X.X.X X.X.X.X ----> Internal Network
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server
early-offer forced
midcall-signaling passthru
g729 annexb-all
voice register pool-type 8831
xml-config maxNumCalls 2
xml-config busyTrigger 1
xml-config custom sshAccess 0
num-lines 2
description Cisco IP Phone 8831
reference-pooltype 7975
voice register pool-type 8831A
description Cisco SIP Phone 8831
reference-pooltype 6921
voice register global
mode cme
source-address 10.200.13.1 port 5060
timeouts interdigit 4
max-dn 50
max-pool 10
load 8831 sip8831.9-3-3-5.loads
authenticate register
olsontimezone europe/london version 2012c
timezone 48
date-format D/M/Y
tftp-path flash:
create profile sync 4479532450662347
voice register dn 20
number 8130
name Boardroom
label Boardroom
voice register dn 21
number 8132
name Conference 1
label Conference 1
voice register dn 22
number 8120
name Conference 2
label Conference 2
voice register pool 1
busy-trigger-per-button 1
id mac AC44.F212.DAE4
type 8831
number 1 dn 20
dtmf-relay sip-kpml
username XXXX password XXXX
codec g711ulaw
voice register pool 2
id mac AC44.F210.20AC
type 8831A
number 1 dn 21
voice-class codec 1000
voice register pool 3
id mac AC44.F219.5553
type 8831
number 1 dn 22
dtmf-relay sip-kpml
codec g711ulaw
no vad
