8841 - Do Not Disturb
marora1209
Not knowing when the 8841 phone is in DND mode is causing issues for our users.
Is there a configuration option to have it display the DND state on the display as the older models did?
5 Replies 5
Rob Huffman
Hi there,
DND display is available with the release of new firmware 11-0-1;
User Interface Enhancements Users can now see the Do Not Disturb(DND) icon displayed in the top line of the phone screen when DND is enabled. Users may also notice a larger displayed font size and an improved line label display. The administrator does not need to enable these improvements. These features are supported on the following phones: • Cisco IP Phone 8811 • Cisco IP Phone 8841 • Cisco IP Phone 8845 • Cisco IP Phone 8851 • Cisco IP Phone 8851NR • Cisco IP Phone 8861 • Cisco IP Phone 8865
From;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/english/11-0-1/releasenotes/p881_b_cisco-ip-phone-8800-series.pdf
Cheers!
Rob
Thanks All for your quick feedback
Deepak Rawat
Working as design for 88XX phone, check the user guide below
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8811_8841_8851_8861/10_5/english/userguide/P881_BK_C9A41445_00_cisco-ip-phone-8811-8841.pdf
Turn DND On and Off
Procedure
Step 1
Press DND to turn on DND.
Visual confirmation displays briefly.
Step 2
Press DND again to turn off DND.
Deepak
- Rate Helpful Posts -
Jaime Valencia
The only option would be to adjust your phone button template to have a DND button to show that, otherwise, you only get the brief notification, and that's WAD
java
if this helps, please rate
marora1209
