8841's on CME 14.1
karolkarol1
New to CME - configuring ISR 4431 running IOS 17.03.03 with CME 14.1
The issue is that I'm unable to find 8841's under telephony-service - that model is not listed as an option:
Router(config-telephony)#load ?
12SP 12SP+ and 30VIP phones
6901 Cisco IP Phone 6901
6911 Cisco IP Phone 6911
6921 Cisco IP Phone 6921
6941 Cisco IP Phone 6941
6945 Cisco IP Phone 6945
6961 Cisco IP Phone 6961
7902 Cisco IP Phone 7902
7905 Cisco IP Phone 7905
7906 Cisco IP Phone 7906
7910 Cisco IP Phone 7910
7911 Cisco IP Phone 7911
7912 Cisco IP Phone 7912
7914 Cisco IP Phone 7914 14-Button Line Expansion Module
7915-12 Cisco IP Phone 7915 12-Button Line Expansion Module
7915-24 Cisco IP Phone 7915 24-Button Line Expansion Module
7916-12 Cisco IP Phone 7916 12-Button Line Expansion Module
7916-24 Cisco IP Phone 7916 24-Button Line Expansion Module
7920 Cisco IP Phone 7920
7921 Cisco IP Phone 7921
7925 Cisco IP Phone 7925
7926 Cisco IP Phone 7926
7931 Cisco IP Phone 7931
7935 Cisco IP Conference Station 7935
7936 Cisco IP Phone 7936
7937 Cisco IP Conference Station 7937
7941 Cisco IP Phone 7941
7941GE Cisco IP Phone 7941GE
7942 Cisco IP Phone 7942
7945 Cisco IP Phone 7945
7960-7940 Cisco IP Phone 7940/7960
7961 Cisco IP Phone 7961
7961GE Cisco IP Phone 7961GE
7962 Cisco IP Phone 7962
7965 Cisco IP Phone 7965
7970 Cisco IP Phone 7970
7971 Cisco IP Phone 7971
7975 Cisco IP Phone 7975
7985 Cisco IP Phone 7985
8941 Cisco IP Phone 8941
8945 Cisco IP Phone 8945
ata ATA phone emulation for analog phone
I have downloaded the firmware (cmterm-88xx.14-0-1-0101-145) and loaded it on the flash, then added the below commands but the 8841 is still not listed and when connected the screen says "unprovisioned"
tftp-server boot1288xx.BE-01-007.sbn
tftp-server fbi88xx.BE-01-012.sbn
tftp-server kern88xx.14-0-1-0101-145.sbn
tftp-server kern288xx.14-0-1-0101-145.sbn
tftp-server kern388xx.14-0-1-0101-145.sbn
tftp-server m0patch288xx.BE-01-001.sbn
tftp-server preloader88xx.BE-01-007.sbn
tftp-server rootfs88xx.14-0-1-0101-145.sbn
tftp-server rootfs288xx.14-0-1-0101-145.sbn
tftp-server rootfs388xx.14-0-1-0101-145.sbn
tftp-server sb288xx.BE-01-028.sbn
tftp-server sb2288xx.BE-01-015.sbn
tftp-server sb2388xx.BE-01-031.sbn
tftp-server sip88xx.14-0-1-0101-145.loads
tftp-server ssb288xx.BE-01-007.sbn
tftp-server vc488xx.14-0-1-0101-145.sbn
tftp-server bootflash:boot1288xx.BE-01-007.sbn alias boot1288xx.BE-01-007.sbn
tftp-server bootflash:fbi88xx.BE-01-012.sbn alias fbi88xx.BE-01-012.sbn
tftp-server bootflash:kern88xx.14-0-1-0101-145.sbn alias kern88xx.14-0-1-0101-145.sbn
tftp-server bootflash:kern288xx.14-0-1-0101-145.sbn alias kern288xx.14-0-1-0101-145.sbn
tftp-server bootflash:kern388xx.14-0-1-0101-145.sbn alias kern388xx.14-0-1-0101-145.sbn
tftp-server bootflash:m0patch288xx.BE-01-001.sbn alias m0patch288xx.BE-01-001.sbn
tftp-server bootflash:preloader88xx.BE-01-007.sbn alias preloader88xx.BE-01-007.sbn
tftp-server bootflash:rootfs88xx.14-0-1-0101-145.sbn alias rootfs88xx.14-0-1-0101-145.sbn
tftp-server bootflash:rootfs288xx.14-0-1-0101-145.sbn alias rootfs288xx.14-0-1-0101-145.sbn
tftp-server bootflash:rootfs388xx.14-0-1-0101-145.sbn alias rootfs388xx.14-0-1-0101-145.sbn
tftp-server bootflash:sb288xx.BE-01-028.sbn alias sb288xx.BE-01-028.sbn
tftp-server bootflash:sb2288xx.BE-01-015.sbn alias sb2288xx.BE-01-015.sbn
tftp-server bootflash:sb2388xx.BE-01-031.sbn alias sb2388xx.BE-01-031.sbn
tftp-server bootflash:sip88xx.14-0-1-0101-145.loads alias sip88xx.14-0-1-0101-145.loads
tftp-server bootflash:ssb288xx.BE-01-007.sbn alias ssb288xx.BE-01-007.sbn
tftp-server bootflash:vc488xx.14-0-1-0101-145.sbn alias vc488xx.14-0-1-0101-145.sbn
Is there a step I'm missing? Does the firmware need to be installed in any way? Like I mentioned I'm new to CME so any guidance / help would be appreciated!
Telephony service is to SCCP phone. for SIP phones you need to configure voice register global.
Here is a sample configuration. When ever you configure a phone y issue create profile under voice register global.
 mode cme
 source-address 192.168.X.X  port 5060
 timeouts interdigit 5
 max-dn 100
 max-pool 100
 load 7841 sip78xx.12-7-1-0001-393
 load 8841 sip88xx.12-7-1-0001-393
 load 8851 sip88xx.12-7-1-0001-393
 timezone 34
 date-format D/M/Y
 create profile sync 0401550434846917
voice register dn  1
 number 101
 pickup-call any-group
 pickup-group 1
 name Chairman
 label Chairman Desk
voice register pool  1
 busy-trigger-per-button 2
 id mac 7802.B179.17D8
 type 8841
 number 1 dn 1
 template 1
 cor incoming INT default
 dtmf-relay rtp-nte sip-kpml
 voice-class codec 1
Response Signature
 mode cme
 max-dn 100
 max-pool 100
 timezone 34
 date-format D/M/Y
voice register dn  1
 number 101
 pickup-group 1
 name Chairman
 label Chairman Desk
 type 8841
 number 1 dn 1
 template 1
 voice-class codec 1
Response Signature
Thanks Nithin!
