01-16-2017 09:37 AM - edited 03-17-2019 09:11 AM
Hello
Currently we are running 7965 VPN phones, connecting to ASA, authenticating via SSL. It is working well.
However we need to move to the 88XX series phone since the 7965 has been retired. We are targeting the 8841 at this time.
I have a 8841 in house that I have pushed the cert to and see LSC installed on the PC. However once moved to a DSL line, it will not register.
Do I have to build a separate cert for the new model phone?
Thanks in advance.
Solved! Go to Solution.
01-16-2017 10:20 AM
You do not need separate cert for different models.
Apply the same vpn profile on the phone and that should take it.
When the phone is taken outside, is the phone attempting to kick in vpn?
You can check the status messages on the phone to get an insight.
You may also refer to PhonAnyConnect VPN Phone
Please rate and mark if helpful
Adarsh Chauhan
01-16-2017 10:20 AM
Adarsh Chauhan
