8841 With CME
Yuen Yeung Hsu
I try add the 8841 SIP phone to the CME with fast-track mode. But the phone still prompted "unprovisioned"
Anything i am missing? Since i can't found any reference about the 8841 fast-track configuration. There is the CME configuration.
IOS version 15.4
voice register pool-type  8841
 xml-config maxNumCalls 4
 xml-config busyTrigger 2
 phoneload-support
 telnet-support
 num-lines 6
 description test_8841
 reference-pooltype 9971
voice register global
 mode  cme
 source-address 172.17.152.129 port 5060
 max-dn 20
 max-pool 10
 authenticate register
 create profile sync 0305300840135259
voice register pool  1
 busy-trigger-per-button 1
 id mac BCC4.93A4.66D3
 type 8841
 number 1 dn 1
 username test password test
16 Replies 16
It still seems like I'm missing some files, and I'm not sure how to generate the CTL and ITL files in CME.
Jonathan Beardsley CCNA Voice; MCITP Telecom & Network Administrator DECOSIMO
Also 400 error is for Refer request, however we were unable see an register message from phone. From last tftp debug it seems phone do not like something in configuration file, hence downloads it again and again. It would be with to open config file n have a look. You can open it with "more flash0:/config-file name", paste output here. Also you may want to remove locale command for UK from voice register global, as tftp do not have this file.
