8841 With CME
Yuen Yeung Hsu
I try add the 8841 SIP phone to the CME with fast-track mode. But the phone still prompted "unprovisioned"
Anything i am missing? Since i can't found any reference about the 8841 fast-track configuration. There is the CME configuration.
IOS version 15.4
voice register pool-type  8841
 xml-config maxNumCalls 4
 xml-config busyTrigger 2
 phoneload-support
 telnet-support
 num-lines 6
 description test_8841
 reference-pooltype 9971
voice register global
 mode  cme
 source-address 172.17.152.129 port 5060
 max-dn 20
 max-pool 10
 authenticate register
 create profile sync 0305300840135259
voice register pool  1
 busy-trigger-per-button 1
 id mac BCC4.93A4.66D3
 type 8841
 number 1 dn 1
 username test password test
16 Replies 16
Were you able to get this to work on CME?
Jonathan Beardsley CCNA Voice; MCITP Telecom & Network Administrator DECOSIMO
Hi Jonathan,
8841 phones can be registered using fast track configuration. If you face any issues in registering, please provide your running config along with the below debugs when you try to register the phone to check.
debug tftp events
debug tftp packets
debug voice register errors
debug voice register events
debug ccsip all
Well it looks like the 88XX series phones are not available on this gateway. I have loaded the sip load files in the flash. What do I do next?
VSB-Glville-2901#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
VSB-Glville-2901(config)#voice register global
VSB-Glville-2901(config-register-global)# mode  cme
VSB-Glville-2901(config-register-global)# source-address 10.20.168.1 port 5060
VSB-Glville-2901(config-register-global)# max-dn 25
VSB-Glville-2901(config-register-global)# max-pool 20
VSB-Glville-2901(config-register-global)# load 8841 sip88xx.10-3-1-20.loads
% Invalid input detected at '^' marker.
VSB-Glville-2901(config-register-global)# timezone 21
VSB-Glville-2901(config-register-global)# time-format 24
VSB-Glville-2901(config-register-global)# date-format D/M/Y
VSB-Glville-2901(config-register-global)# tftp-path flash:
VSB-Glville-2901(config-register-global)# create profile
VSB-Glville-2901(config-register-global)# network-locale GB
VSB-Glville-2901(config-register-global)#!
VSB-Glville-2901(config-register-global)#voice register dn  1
VSB-Glville-2901(config-register-dn)# number 6010
VSB-Glville-2901(config-register-dn)# name 8841
VSB-Glville-2901(config-register-dn)# label New 8841
VSB-Glville-2901(config-register-dn)# mwi
VSB-Glville-2901(config-register-dn)#!
VSB-Glville-2901(config-register-dn)#voice register pool  1
VSB-Glville-2901(config-register-pool)# busy-trigger-per-button 2
VSB-Glville-2901(config-register-pool)# id mac AC7E.8A2B.07A4
VSB-Glville-2901(config-register-pool)# type 8841
VSB-Glville-2901(config-register-pool)# number 1 dn 1
VSB-Glville-2901(config-register-pool)# presence call-list
VSB-Glville-2901(config-register-pool)# dtmf-relay rtp-nte
VSB-Glville-2901(config-register-pool)# username cisco password cisco
VSB-Glville-2901(config-register-pool)# codec g711ulaw
VSB-Glville-2901(config-register-pool)#exit
VSB-Glville-2901(config-register-global)#load ?
  3905       Cisco SIP Phone 3905
  3911       Cisco SIP Phone 3911
  3951       Cisco SIP Phone 3951
  6901       Cisco SIP Phone 6901
  6911       Cisco SIP Phone 6911
  6921       Cisco SIP Phone 6921
  6941       Cisco SIP Phone 6941
  6945       Cisco SIP Phone 6945
  6961       Cisco SIP Phone 6961
  7821       Cisco SIP Phone 7821
  7841       Cisco SIP Phone 7841
  7861       Cisco SIP Phone 7861
  7905       Cisco SIP Phone 7905
  7906       Cisco SIP Phone 7906
  7911       Cisco SIP Phone 7911
  7912       Cisco SIP Phone 7912
  7941       Cisco SIP Phone 7941
  7941GE     Cisco SIP Phone 7941GE
  7942       Cisco SIP Phone 7942
  7945       Cisco SIP Phone 7945
  7960-7940  Telecaster 7960 & 7940 phones
  7961       Cisco SIP Phone 7961
  7961GE     Cisco SIP Phone 7961GE
  7962       Cisco SIP Phone 7962
  7965       Cisco SIP Phone 7965
  7970       Cisco SIP Phone 7970
  7971       Cisco SIP Phone 7971
  7975       Cisco SIP Phone 7975
  8941       Cisco SIP Phone 8941
  8945       Cisco SIP Phone 8945
  8961       Cisco SIP Phone 8961
  9945       Cisco SIP Phone 9945
  9951       Cisco SIP Phone 9951
  9965       Cisco SIP Phone 9965
  9971       Cisco SIP Phone 9971
  ATA        Cisco SIP Phone ATA
  ATA-187    Cisco Analog Phone Adapter ATA 187
  Cius       Cisco Cius (Android based Tablet)
  DX650      Cisco Desktop Collaboration Experience DX650
  E20        Cisco Video Phone E20
VSB-Glville-2901(config-register-global)#do sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 05-Jun-15 13:24 by prod_rel_team
Hi Jonathan,
yes. these phone types are npt avaialble. that is why you need to use the fast track configuration to get that option.
PLease configure the following pool type:
xml-config maxNumCalls 6
num-lines 5
description Cisco IP Phone 8841
reference-pooltype 8961
With this you will get the phone type to configure in voice register pool. Then you could configure 8841 phones usual way
Rajan
I was missing the "number 1 dn X" command. this was causing phones not to register. Thanks for your help!!!
Ok That's Great. But as per conifg posted aobve, seems DN command was there..
 type 8841
 number 1 dn 1
 presence call-list
 dtmf-relay rtp-nte
 codec g711ulaw
Definately SIP phones needs DN to get registered as that acts as identifer , between phone and CME.
Amit
I'm sorry I didn't post back. Yes, I had the DN command, and at some point reconfigured without it. I don't remember what I changed for SIP, but it then wasn't working until I added the DN back.
hello guys,
 I'm trying to register the 8841 with my cme but I'm unable too.
when I go to
voice register global to load the SIP. I don't see the load options for 8841, did I miss uploading anything ?
8841 test_8841
thank you
Ditmar,
Kindly attach the "show tech".
Kevin
If you upgrade the IOS on the Router to the latest version, 8800 series and 7800 series phones will be available by default.
Hi Jonathan,
I am currently facing the same problem with my 8841 phones did you find the solution for the problem?
Thank you,
Rabeeh
I was able to enter the phoneload reference and tested it out. Here is the config, and the debug output. it looks like the phone config files are not being generated by the router. I'm posting this here, as I continue to research.
VSB-Glville-2901#sh run
Building configuration...
Current configuration : 13127 bytes
! Last configuration change at 15:42:14 UTC Tue Nov 17 2015 by dci
version 15.4
hostname VSB-Glville-2901
boot-start-marker
boot-end-marker
card type t1 0 0
logging buffered 51200 warnings
enable secret 5 $1$yez8$HHFFgqbliyhSySph4Sykn.
aaa new-model
aaa authentication login default enable
aaa session-id common
network-clock-participate wic 0
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.20.168.1 10.20.168.10
ip dhcp pool ccp-pool
 import all
 network 10.10.10.0 255.255.255.128
 default-router 10.10.10.1
 lease 0 2
ip dhcp pool VSB-Glville-Voice
 network 10.20.168.0 255.255.255.0
 default-router 10.20.168.1
 option 150 ip 10.20.168.1
no ip domain lookup
ip domain name volstatebank.com
ip cef
no ipv6 cef
isdn switch-type primary-ni
cts logging verbose
crypto pki trustpoint TP-self-signed-1227855161
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1227855161
 revocation-check none
 rsakeypair TP-self-signed-1227855161
crypto pki certificate chain TP-self-signed-1227855161
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31323237 38353531 3631301E 170D3135 30393236 30343031
  33345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 32323738
  35353136 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100AA6C 2B08652D B53E195A 79F68DD8 55543E26 917E6CF4 C31BCE57 95113520
  6804CE79 FFA0B5B8 92F13893 B663B63E B4B43986 19053E1C 8366B756 A8138880
  E8A9F737 D3C5FFE2 DED20DE9 2B3703E2 65FF1682 AF496E9E A044FE6C 51F1ACDD
  FB60C8F4 B18929F4 FF3D1D63 DF20011A 93B63DAE CD210DBC 7E5FD567 34AD560B
  DF190203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1405C0AD B2AA8E1C A2E4F558 F8EB36C3 03EED0F0 90301D06
  03551D0E 04160414 05C0ADB2 AA8E1CA2 E4F558F8 EB36C303 EED0F090 300D0609
  2A864886 F70D0101 05050003 818100A4 6BA69976 44C0F258 51E9D0F5 D70C9D0B
  DCD0C214 41FAD2D3 B22854FD 81553250 491A4CB7 9E673BF1 8B36D613 FAB30040
  734531DC 377402A2 18861BAA 3948E32E EC067FB4 EC90FE9A 8B3966DC D054B397
  9416D012 BBF804E7 B962571F 694891E0 50DC4590 AA5D8769 20ECE9BD D0EC1234
  755D076B AA852023 4BB22B7E 1C618A
        quit
voice-card 0
 dsp services dspfarm
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
 phoneload-support
 telnet-support
 num-lines 6
 mode  cme
 max-dn 25
 max-pool 20
 timezone 21
 time-format 24
 date-format D/M/Y
 tftp-path flash:
 create profile sync 0055249492429519
 network-locale GB
voice register dn  1
 number 6010
 name 8841
 label New 8841
 mwi
 type 8841
 number 1 dn 1
 presence call-list
 dtmf-relay rtp-nte
 codec g711ulaw
license udi pid CISCO2901/K9 sn FJC1939A395
hw-module pvdm 0/0
hw-module pvdm 0/1
username jbeardsley privilege 15 password 0
username dci privilege 15 secret 5 $1$nNc7$XsZjF0IB6DZ5A13PWp7EF0
redundancy
controller T1 0/0/0
 cablelength long 0db
 pri-group timeslots 1-12,24
ip ssh version 2
interface Embedded-Service-Engine0/0
 ip unnumbered GigabitEthernet0/0.20
 service-module ip address 10.20.168.3 255.255.255.0
 service-module ip default-gateway 10.20.168.1
interface GigabitEthernet0/0
 description connection to VSB-Glville-2960
 ip address 10.10.10.1 255.255.255.128
 duplex auto
 speed auto
interface GigabitEthernet0/0.10
 description Data VLAN
 encapsulation dot1Q 10
 ip address 172.20.168.254 255.255.255.0
interface GigabitEthernet0/0.20
 description Voice VLAN
 encapsulation dot1Q 20
 ip address 10.20.168.1 255.255.255.0
interface GigabitEthernet0/0.99
 description Native VLAN
 encapsulation dot1Q 99 native
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:23
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 10.20.168.3 255.255.255.255 Embedded-Service-Engine0/0
tftp-server flash0:/Ringtones/Bass.raw alias Bass.raw
tftp-server flash0:/Ringtones/Analog1.raw alias Analog1.raw
tftp-server flash0:/Ringtones/Analog2.raw alias Analog2.raw
tftp-server flash0:/Ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash0:/Ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash0:/Ringtones/CallBack.raw alias CallBack.raw
tftp-server flash0:/Ringtones/Chime.raw alias Chime.raw
tftp-server flash0:/Ringtones/Classic1.raw alias Classic1.raw
tftp-server flash0:/Ringtones/Classic2.raw alias Classic2.raw
tftp-server flash0:/Ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash0:/Ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash0:/Ringtones/Drums1.raw alias Drums1.raw
tftp-server flash0:/Ringtones/Drums2.raw alias Drums2.raw
tftp-server flash0:/Ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash0:/Ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash0:/Ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash0:/Ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash0:/Ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash0:/Ringtones/Piano1.raw alias Piano1.raw
tftp-server flash0:/Ringtones/Piano2.raw alias Piano2.raw
tftp-server flash0:/Ringtones/Pop.raw alias Pop.raw
tftp-server flash0:/Ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash0:/Ringtones/Ring1.raw alias Ring1.raw
tftp-server flash0:/Ringtones/Ring2.raw alias Ring2.raw
tftp-server flash0:/Ringtones/Ring3.raw alias Ring3.raw
tftp-server flash0:/Ringtones/Ring4.raw alias Ring4.raw
tftp-server flash0:/Ringtones/Ring5.raw alias Ring5.raw
tftp-server flash0:/Ringtones/Ring6.raw alias Ring6.raw
tftp-server flash0:/Ringtones/Ring7.raw alias Ring7.raw
tftp-server flash0:/Ringtones/Sax1.raw alias Sax1.raw
tftp-server flash0:/Ringtones/Sax2.raw alias Sax2.raw
tftp-server flash0:/Ringtones/Vibe.raw alias Vibe.raw
tftp-server flash0:Desktops/320x212x16/LIST.XML
tftp-server flash0:Desktops/320x212x16/TN-CFS.png
tftp-server flash0:Desktops/320x212x16/CFS.png
tftp-server flash0:SCCP45.9-1-1SR1S.loads
tftp-server flash0:apps45.9-1-1TH1-16.sbn
tftp-server flash0:cnu45.9-1-1TH1-16.sbn
tftp-server flash0:cvm45sccp.9-1-1TH1-16.sbn
tftp-server flash0:dsp45.9-1-1TH1-16.sbn
tftp-server flash0:jar45sccp.9-1-1TH1-16.sbn
tftp-server flash0:term45.default.loads
tftp-server flash0:term65.default.loads
tftp-server flash0:/Ringtones/Ringlist.xml alias Ringlist.xml
tftp-server flash0:/GUI
tftp-server flash0:GUI
tftp-server flash:sip88xx.10-3-1-20.loads
tftp-server flash:fbi88xx.BE-01-010.sbn
tftp-server flash:sb288xx.BE-01-019.sbn
tftp-server flash:kern88xx.10-3-1-20.sbn
tftp-server flash:rootfs88xx.10-3-1-20.sbn
tftp-server flash:vc488xx.10-3-1-20.sbn
access-list 23 permit 10.10.10.0 0.0.0.127
control-plane
voice-port 0/0/0:23
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 7000 voip
 destination-pattern 7000
 session protocol sipv2
 session target ipv4:10.20.168.3
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 7001 voip
 destination-pattern 7001$
 codec g711ulaw
 no vad
dial-peer voice 7002 voip
 destination-pattern 7002
 codec g711ulaw
 no vad
dial-peer voice 7003 voip
 destination-pattern 7003
 codec g711ulaw
 no vad
dial-peer voice 1 pots
 description 911 Dial Peer
 translation-profile incoming EXTIN
 destination-pattern 9911$
 incoming called-number .
 direct-inward-dial
 port 0/0/0:23
 forward-digits 3
dial-peer voice 2 pots
 description Local Dial Peer
 destination-pattern 9[2-9]..[2-9]......$
 port 0/0/0:23
 forward-digits 7
dial-peer voice 3 pots
 description LD Dial Peer
 destination-pattern 91[2-9]..[2-9]......$
 port 0/0/0:23
 forward-digits 11
dial-peer voice 16 pots
 description 411 Dial Peer
 translation-profile outgoing 411
 destination-pattern 9411$
 port 0/0/0:23
 forward-digits 3
gatekeeper
 shutdown
telephony-service
 no auto-reg-ephone
 authentication credential dci pa55w0rd
 max-ephones 30
 max-dn 100
 ip source-address 10.20.168.1 port 2000
 system message Vol State Bank
 url services http://10.20.168.3/voiceview/common/login.do
 url authentication http://10.20.168.1/CCMCIP/authenticate.asp
 load 7915-24 B015-1-0-3
 load 7916-24 B016-1-0-3
 load 7965 SCCP45.9-1-1SR1S
 time-zone 8
 voicemail 7000
 max-conferences 8 gain -6
 moh enable-g711 "Sep2015.wav"
 web admin system name dci secret 5 $1$YEhD$frtzKDA0oMKxKzkHcybtJ.
 dn-webedit
 time-webedit
 transfer-system full-consult
 transfer-pattern ....
 trunk optimization pre-connect
 secondary-dialtone 9
 after-hours block pattern 1 91900 7-24
 after-hours block pattern 2 9011 7-24
 after-hours block pattern 3 91242 7-24
 after-hours block pattern 4 91264 7-24
 after-hours block pattern 5 91268 7-24
 after-hours block pattern 6 91284 7-24
 after-hours block pattern 7 91340 7-24
 after-hours block pattern 8 91345 7-24
 after-hours block pattern 9 91441 7-24
 after-hours block pattern 10 91473 7-24
 after-hours block pattern 11 91649 7-24
 after-hours block pattern 12 91664 7-24
 after-hours block pattern 13 91721 7-24
 after-hours block pattern 14 91758 7-24
 after-hours block pattern 15 91767 7-24
 after-hours block pattern 16 91784 7-24
 after-hours block pattern 17 91787 7-24
 after-hours block pattern 18 91809 7-24
 after-hours block pattern 19 91829 7-24
 after-hours block pattern 20 91849 7-24
 after-hours block pattern 21 91868 7-24
 after-hours block pattern 22 91869 7-24
 after-hours block pattern 23 91876 7-24
 after-hours block pattern 24 91939 7-24
 create cnf-files version-stamp 7960 Apr 04 2011 10:37:17
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 privilege level 15
 transport input telnet ssh
line vty 5 15
 privilege level 15
scheduler allocate 20000 1000
end
VSB-Glville-2901#
VSB-Glville-2901#
*Nov 17 16:02:43.867: TFTP: Server request for port 53188, socket_id 0x21A7457C for process 428
*Nov 17 16:02:43.867: TFTP: read request from host 10.20.168.11(53188) via GigabitEthernet0/0.20
*Nov 17 16:02:43.867: TFTP: Looking for CTLSEPAC7E8A2B07A4.tlv
*Nov 17 16:02:43.867: TFTP: Sending error 1 No such file
*Nov 17 16:02:44.975: TFTP: Server request for port 50934, socket_id 0x21A7457C for process 428
*Nov 17 16:02:44.975: TFTP: read request from host 10.20.168.11(50934) via GigabitEthernet0/0.20
*Nov 17 16:02:44.975: TFTP: Looking for ITLSEPAC7E8A2B07A4.tlv
*Nov 17 16:02:44.975: TFTP: Sending error 1 No such file
*Nov 17 16:02:46.303: TFTP: Server request for port 50946, socket_id 0x21A7457C for process 428
*Nov 17 16:02:46.303: TFTP: read request from host 10.20.168.11(50946) via GigabitEthernet0/0.20
*Nov 17 16:02:46.303: TFTP: Looking for ITLFile.tlv
*Nov 17 16:02:46.303: TFTP: Sending error 1 No such file
*Nov 17 16:02:47.851: TFTP: Server request for port 49902, socket_id 0x21A7457C for process 428
*Nov 17 16:02:47.851: TFTP: read request from host 10.20.168.11(49902) via GigabitEthernet0/0.20
*Nov 17 16:02:47.851: TFTP: Looking for SEPAC7E8A2B07A4.cnf.xml
*Nov 17 16:02:47.851: TFTP: Sending error 1 No such file
*Nov 17 16:02:48.943: TFTP: Server request for port 51100, socket_id 0x21A7457C for process 428
*Nov 17 16:02:48.943: TFTP: read request from host 10.20.168.11(51100) via GigabitEthernet0/0.20
*Nov 17 16:02:48.943: TFTP: Looking for XMLDefault.cnf.xml
*Nov 17 16:02:48.943: TFTP: Opened system:/its/vrf1/XMLDefault.cnf.xml, fd 5, size 3487 for process 428
*Nov 17 16:02:48.943: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x21A7457C
*Nov 17 16:02:48.947: TFTP: Received ACK for block 1, socket_id 0x21A7457C
*Nov 17 16:02:48.947: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x21A7457C
*Nov 17 16:02:48.947: TFTP: Received ACK for block 2, socket_id 0x21A7457C
*Nov 17 16:02:48.947: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x21A7457C
*Nov 17 16:02:48.947: TFTP: Received ACK for block 3, socket_id 0x21A7457C
*Nov 17 16:02:48.947: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x21A7457C
*Nov 17 16:02:48.947: TFTP: Received ACK for block 4, socket_id 0x21A7457C
*Nov 17 16:02:48.947: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x21A7457C
*Nov 17 16:02:48.947: TFTP: Received ACK for block 5, socket_id 0x21A7457C
*Nov 17 16:02:48.947: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x21A7457C
*Nov 17 16:02:48.947: TFTP: Received ACK for block 6, socket_id 0x21A7457C
*Nov 17 16:02:48.947: TFTP: Sending block 7 (retry 0), len 415, socket_id 0x21A7457C
*Nov 17 16:02:48.951: TFTP: Received ACK for block 7, socket_id 0x21A7457C
*Nov 17 16:02:48.951: TFTP: Finished system:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 428
*Nov 17 16:02:49.899: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x21A7457C with refCount = 1
*Nov 17 16:02:49.899: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3EF041FC with refCount = 1
*Nov 17 16:02:49.899: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.20.168.11]:5060, local_address:[ - ]
*Nov 17 16:02:49.899: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x21A7457C
*Nov 17 16:02:49.899: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Nov 17 16:02:49.899: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REFER sip:10.20.168.1 SIP/2.0
Via: SIP/2.0/UDP 10.20.168.11:5060;branch=z9hG4bK004aa522
From: "" <sip:@10.20.168.11>;tag=ac7e8a2b07a400044ce99b17-0000ffe3
To: <sip:10.20.168.1>
Call-ID: ac7e8a2b-07a40004-0d62a2c9-40455815@10.20.168.11
Date: Fri, 01 May 2015 17:07:34 GMT
CSeq: 1000 REFER
User-Agent: Cisco-CP8841/10.3.1
Expires: 10
Max-Forwards: 70
Contact: <sip:@10.20.168.11:5060;transport=udp>
Require: norefersub
Referred-By: "" <sip:@10.20.168.11>
Refer-To: cid:5d87dfa9@10.20.168.11
Content-Id: <5d87dfa9@10.20.168.11>
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE
Content-Length: 507
Content-Type: application/x-cisco-alarm+xml
Content-Disposition: session;handling=required
<?xml version="1.0" encoding="UTF-8"?>
<x-cisco-alarm>
<Alarm Name="DeviceTLInfo">
<ParameterList>
<String name="DeviceName">SEPAC7E8A2B07A4</String>
<String name="IPv4Address">10.20.168.11</String>
<String name="IPv6Address"></String>
<String name="CTL_Signature">Not Installed</String>
<String name="CTL_TFTP_Server">N/A</String>
<String name="ITL_Signature">Not Installed</String>
<String name="ITL_TFTP_Server">N/A</String>
<String name="StatusCode">6</String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x3F5B69F0) with key=[30] to table
*Nov 17 16:02:49.903: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
*Nov 17 16:02:49.903: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
*Nov 17 16:02:49.903: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.20.168.11,Port 5060, Transport 1, SentBy Port 5060vrfid 0
*Nov 17 16:02:49.903: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: ip_best_local_address 10.20.168.1 for SIP
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 10.20.168.1
*Nov 17 16:02:49.903: //-1/7C4E365F801F/SIP/State/sipSPIChangeState: 0x3F5B69F0 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.20.168.11,Port 5060, Transport 1, SentBy Port 5060vrfid 0
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x3EF041FC) counter, current msg->refCount = 2
*Nov 17 16:02:49.903: //-1/7C4E365F801F/SIP/Info/verbose/4096/sipSPIAssignCcbLastRequest: Current ccb(0x3F5B69F0)->last_request = 0x3EF041FC, refCount = 2
*Nov 17 16:02:49.903: //-1/7C4E365F801F/SIP/Info/verbose/1024/sipSPIGetViaHostInURLFormat: VIA URL:sip:10.20.168.11:5060, Host:10.20.168.11
*Nov 17 16:02:49.903: //-1/7C4E365F801F/SIP/Info/info/16384/ccsip_api_handle_ood_refer_ind: No matching dialpeer for the REFER request
*Nov 17 16:02:49.903: //-1/7C4E365F801F/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x3EF041FC) counter, current msg->refCount = 1
*Nov 17 16:02:49.903: //-1/7C4E365F801F/SIP/Info/info/4096/sipSPIProcessNoReferSub: ccsip_api_refer_ind returned: SIP_INTERNAL_ERR
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x21A7457C with refCount = 1
*Nov 17 16:02:49.903: //-1/7C4E365F801F/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 4 event
*Nov 17 16:02:49.903: //-1/7C4E365F801F/SIP/Info/notify/4096/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
*Nov 17 16:02:49.903: //-1/7C4E365F801F/SIP/Transport/sipSPISendReferResponse: Sending Refer Response to the transport layer
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPITransportSendMessage: msg=0x21A7457C, addr=10.20.168.11, port=5060, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x0
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPITransportSendMessage: gcb is not available while sending the msg
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnectionIfExists: Connection Holder for addr=10.20.168.11 not found
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportLogicSendMsgImmediate: Ignoring local address to find a connid for sending response
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x21A7457C, addr=10.20.168.11, port=5060, local_addr=, connId=0 vrfid=0 for UDP
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[30] removed.
*Nov 17 16:02:49.903: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3EF041FC
*Nov 17 16:02:49.903: //-1/7C4E365F801F/SIP/Info/verbose/4096/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Nov 17 16:02:49.903: //-1/7C4E365F801F/SIP/Info/verbose/1/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
*Nov 17 16:02:49.903: //-1/7C4E365F801F/SIP/Info/info/8192/sipSPIStopOverlapInfoTimer: Stopping Overlap Info Timer
*Nov 17 16:02:49.903: //-1/7C4E365F801F/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Freeing ccb 0x3F5B69F0
*Nov 17 16:02:49.907: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request
To: <sip:10.20.168.1>;tag=3DE903C-12A8
Date: Tue, 17 Nov 2015 16:02:49 GMT
Server: Cisco-SIPGateway/IOS-15.4.3.M3
CSeq: 1000 REFER
Content-Length: 0
Contact: <sip:10.20.168.1:5060>
try removing the load command in voice register global and do a "no create profile" followed by "create profile" and rebooting the phone once.
Also check with the below commands to see whether config file is generated
sh flash
show voice register tftp-bind
I removed load command, "no create profile", replaced load command, and "create profile" no errors on re-create.
Phone still will not register. I'm getting a 400 bad request on sip, but it is still making its requests to the CME.
VSB-Glville-2901#sh flash
-#- --length-- -----date/time------ path
1    104193476 Sep 26 2015 03:39:14 +00:00 c2900-universalk9-mz.SPA.154-3.M3.bin
2         3066 Sep 26 2015 03:52:24 +00:00 cpconfig-29xx.cfg
3            0 Sep 26 2015 03:53:04 +00:00 ccpexp
4            0 Sep 26 2015 03:53:06 +00:00 ccpexp/external
5            0 Sep 26 2015 03:53:06 +00:00 ccpexp/external/development-bundle
6            0 Sep 26 2015 03:53:06 +00:00 ccpexp/external/development-bundle/themes
7            0 Sep 26 2015 03:53:06 +00:00 ccpexp/external/development-bundle/themes/flick
8            0 Sep 26 2015 03:53:06 +00:00 ccpexp/external/development-bundle/themes/flick/images
9         1738 Sep 26 2015 03:53:10 +00:00 ccpexp/external/development-bundle/themes/flick/images/animated-overlay.gif
10         180 Sep 26 2015 03:53:10 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_flat_0_aaaaaa_40x100.png
11         180 Sep 26 2015 03:53:12 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_flat_0_eeeeee_40x100.png
12         178 Sep 26 2015 03:53:12 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_flat_55_ffffff_40x100.png
13         178 Sep 26 2015 03:53:12 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_flat_75_ffffff_40x100.png
14         105 Sep 26 2015 03:53:12 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_glass_65_ffffff_1x400.png
15          90 Sep 26 2015 03:53:14 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_highlight-soft_100_f6f6f6_1x100.png
16         118 Sep 26 2015 03:53:14 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_highlight-soft_25_0073ea_1x100.png
17         136 Sep 26 2015 03:53:14 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_highlight-soft_50_dddddd_1x100.png
18        4369 Sep 26 2015 03:53:14 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-icons_0073ea_256x240.png
19        4369 Sep 26 2015 03:53:16 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-icons_454545_256x240.png
20        4369 Sep 26 2015 03:53:16 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-icons_666666_256x240.png
21        4369 Sep 26 2015 03:53:16 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-icons_ff0084_256x240.png
22        4369 Sep 26 2015 03:53:16 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-icons_ffffff_256x240.png
23       27419 Sep 26 2015 03:53:18 +00:00 ccpexp/external/development-bundle/themes/flick/jquery-ui-1.10.3.custom.css1
24       26635 Sep 26 2015 03:53:18 +00:00 ccpexp/external/development-bundle/themes/flick/jquery-ui-1.8.17.custom.css1
25       27419 Sep 26 2015 03:53:18 +00:00 ccpexp/external/development-bundle/themes/flick/jquery-ui.css
26         840 Sep 26 2015 03:53:18 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.accordion.css
27         292 Sep 26 2015 03:53:20 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.all.css
28         771 Sep 26 2015 03:53:20 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.base.css
29        2541 Sep 26 2015 03:53:20 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.button.css
30        1468 Sep 26 2015 03:53:20 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.core.css
31        1304 Sep 26 2015 03:53:22 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.dialog.css
32        1454 Sep 26 2015 03:53:22 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.menu.css
33         618 Sep 26 2015 03:53:22 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.progressbar.css
34        1207 Sep 26 2015 03:53:22 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.resizable.css
35        1314 Sep 26 2015 03:53:22 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.slider.css
36        1322 Sep 26 2015 03:53:24 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.tabs.css
37       17106 Sep 26 2015 03:53:24 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.theme.css
38         375 Sep 26 2015 03:53:24 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.tooltip.css
39           0 Sep 26 2015 03:53:06 +00:00 ccpexp/external/js
40       93868 Sep 26 2015 03:53:28 +00:00 ccpexp/external/js/jquery-1.7.1.min.js
41           0 Sep 26 2015 03:53:28 +00:00 ccpexp/external/js/jquery-ui-1.10.3.custom.min.js
42       46982 Sep 26 2015 03:53:28 +00:00 ccpexp/external/js/jquery-ui-1.10.4.custom.min.js
43     1144429 Sep 26 2015 03:53:26 +00:00 ccpexp/external/jQueryFramework.js
44       17769 Sep 26 2015 03:53:28 +00:00 ccpexp/external/jquery.i18n.properties-1.0.9.js
45       21601 Sep 26 2015 03:53:28 +00:00 ccpexp/external/jquery.validate.min.js
46         929 Sep 26 2015 03:53:30 +00:00 ccpexp/external/readme.txt
47       45489 Sep 26 2015 03:53:30 +00:00 ccpexp/external/underscore.js
48           0 Sep 26 2015 03:53:06 +00:00 ccpexp/html
49           0 Sep 26 2015 03:53:06 +00:00 ccpexp/html/bundles
50       51275 Sep 26 2015 03:53:30 +00:00 ccpexp/html/bundles/CCPExpNG.properties
51        3372 Sep 26 2015 03:53:32 +00:00 ccpexp/html/bundles/ValidationMessages.properties
52           0 Sep 26 2015 03:53:08 +00:00 ccpexp/html/fonts
53       62856 Sep 26 2015 03:53:34 +00:00 ccpexp/html/fonts/FontAwesome.otf
54       38205 Sep 26 2015 03:53:36 +00:00 ccpexp/html/fonts/fontawesome-webfont.eot
55      202148 Sep 26 2015 03:53:36 +00:00 ccpexp/html/fonts/fontawesome-webfont.svg
56       80652 Sep 26 2015 03:53:36 +00:00 ccpexp/html/fonts/fontawesome-webfont.ttf
57       44432 Sep 26 2015 03:53:36 +00:00 ccpexp/html/fonts/fontawesome-webfont.woff
58           0 Sep 26 2015 03:53:08 +00:00 ccpexp/html/images
59        3406 Sep 26 2015 03:53:38 +00:00 ccpexp/html/images/Activate.png
60        1282 Sep 26 2015 03:53:40 +00:00 ccpexp/html/images/Collapse.png
61        1473 Sep 26 2015 03:53:40 +00:00 ccpexp/html/images/Excel.png
62        3419 Sep 26 2015 03:53:40 +00:00 ccpexp/html/images/Help_uishell_16.png
63        1405 Sep 26 2015 03:53:40 +00:00 ccpexp/html/images/IPS_drilldown.png
64        3040 Sep 26 2015 03:53:40 +00:00 ccpexp/html/images/NoSIM.png
65        3233 Sep 26 2015 03:53:42 +00:00 ccpexp/html/images/NoSignal.png
66         371 Sep 26 2015 03:53:42 +00:00 ccpexp/html/images/NotActivate.png
67        3219 Sep 26 2015 03:53:42 +00:00 ccpexp/html/images/SIM.png
68        3421 Sep 26 2015 03:53:42 +00:00 ccpexp/html/images/Sent-Mail.png
69         261 Sep 26 2015 03:53:44 +00:00 ccpexp/html/images/Signal1.png
70         294 Sep 26 2015 03:53:44 +00:00 ccpexp/html/images/Signal2.png
71         319 Sep 26 2015 03:53:44 +00:00 ccpexp/html/images/Signal3.png
72         324 Sep 26 2015 03:53:44 +00:00 ccpexp/html/images/Signal4.png
73         324 Sep 26 2015 03:53:44 +00:00 ccpexp/html/images/Signal5.png
74      211889 Sep 26 2015 03:53:46 +00:00 ccpexp/html/images/UtmSpriteImage.png
75       33259 Sep 26 2015 03:53:46 +00:00 ccpexp/html/images/allImagesby40.png
76       22196 Sep 26 2015 03:53:46 +00:00 ccpexp/html/images/allimagesby80.jpg
77         181 Sep 26 2015 03:53:48 +00:00 ccpexp/html/images/application.png
78      114483 Sep 26 2015 03:53:48 +00:00 ccpexp/html/images/banner.jpg
79       56706 Sep 26 2015 03:53:48 +00:00 ccpexp/html/images/banner6.jpg
80       33012 Sep 26 2015 03:53:48 +00:00 ccpexp/html/images/bars.jpg
81        2816 Sep 26 2015 03:53:50 +00:00 ccpexp/html/images/blankSpace.png
82       83587 Sep 26 2015 03:53:50 +00:00 ccpexp/html/images/caaDeviceList.png
83        1315 Sep 26 2015 03:53:50 +00:00 ccpexp/html/images/ccpeQR.png
84       16786 Sep 26 2015 03:53:50 +00:00 ccpexp/html/images/ceserver.png
85       12575 Sep 26 2015 03:53:50 +00:00 ccpexp/html/images/content-security.jpg
86        1330 Sep 26 2015 03:53:52 +00:00 ccpexp/html/images/cpu_utilization.png
87        1270 Sep 26 2015 03:53:52 +00:00 ccpexp/html/images/cws.png
88        1102 Sep 26 2015 03:53:52 +00:00 ccpexp/html/images/device-details.png
89        1269 Sep 26 2015 03:53:52 +00:00 ccpexp/html/images/device_details.png
90        1268 Sep 26 2015 03:53:54 +00:00 ccpexp/html/images/disable.png
91         992 Sep 26 2015 03:53:54 +00:00 ccpexp/html/images/down.png
92        1972 Sep 26 2015 03:53:54 +00:00 ccpexp/html/images/dragArrow.png
93        1271 Sep 26 2015 03:53:54 +00:00 ccpexp/html/images/enable.png
94        1287 Sep 26 2015 03:53:56 +00:00 ccpexp/html/images/expand.png
95        1435 Sep 26 2015 03:53:56 +00:00 ccpexp/html/images/firewall.png
96        1597 Sep 26 2015 03:53:56 +00:00 ccpexp/html/images/flash-memory.png
97        1174 Sep 26 2015 03:53:56 +00:00 ccpexp/html/images/flash_memory.png
98        6877 Sep 26 2015 03:53:56 +00:00 ccpexp/html/images/header_icon_sprite.png
99        1816 Sep 26 2015 03:53:58 +00:00 ccpexp/html/images/information.png
100        941 Sep 26 2015 03:53:58 +00:00 ccpexp/html/images/interfacePort.png
101       1191 Sep 26 2015 03:53:58 +00:00 ccpexp/html/images/interfaces.png
102      22992 Sep 26 2015 03:53:58 +00:00 ccpexp/html/images/ips-enable.jpg
103      39606 Sep 26 2015 03:54:00 +00:00 ccpexp/html/images/ips-in-enable.png
104      17467 Sep 26 2015 03:54:00 +00:00 ccpexp/html/images/ips.jpg
105        209 Sep 26 2015 03:54:00 +00:00 ccpexp/html/images/key_minus.png
106        238 Sep 26 2015 03:54:00 +00:00 ccpexp/html/images/key_plus.png
107      18760 Sep 26 2015 03:54:02 +00:00 ccpexp/html/images/logo.png
108       1374 Sep 26 2015 03:54:02 +00:00 ccpexp/html/images/maximize.png
109       1293 Sep 26 2015 03:54:02 +00:00 ccpexp/html/images/network.png
110      10130 Sep 26 2015 03:54:02 +00:00 ccpexp/html/images/papergrid.jpg
111       1374 Sep 26 2015 03:54:04 +00:00 ccpexp/html/images/policy.png
112       1234 Sep 26 2015 03:54:04 +00:00 ccpexp/html/images/port.png
113       1591 Sep 26 2015 03:54:04 +00:00 ccpexp/html/images/processor-memory.png
114       1458 Sep 26 2015 03:54:04 +00:00 ccpexp/html/images/processor_memory.png
115       1236 Sep 26 2015 03:54:06 +00:00 ccpexp/html/images/reload.png
116       2087 Sep 26 2015 03:54:06 +00:00 ccpexp/html/images/right-check-icon.png
117       2975 Sep 26 2015 03:54:06 +00:00 ccpexp/html/images/right_arrow.png
118       4059 Sep 26 2015 03:54:06 +00:00 ccpexp/html/images/router.png
119       1405 Sep 26 2015 03:54:08 +00:00 ccpexp/html/images/search-icon.png
120       1178 Sep 26 2015 03:54:08 +00:00 ccpexp/html/images/settings.png
121       3339 Sep 26 2015 03:54:08 +00:00 ccpexp/html/images/sortable.png
122       5363 Sep 26 2015 03:54:08 +00:00 ccpexp/html/images/split-icon40.png
123       5945 Sep 26 2015 03:54:10 +00:00 ccpexp/html/images/startup.gif
124      29881 Sep 26 2015 03:54:10 +00:00 ccpexp/html/images/startupImage.png
125       1161 Sep 26 2015 03:54:10 +00:00 ccpexp/html/images/temperature.png
126      13338 Sep 26 2015 03:54:10 +00:00 ccpexp/html/images/tileImages.png
127       1247 Sep 26 2015 03:54:12 +00:00 ccpexp/html/images/top_10_applications.png
128       1381 Sep 26 2015 03:54:12 +00:00 ccpexp/html/images/top_10_threats.png
129       1590 Sep 26 2015 03:54:12 +00:00 ccpexp/html/images/top_10_users.png
130      16843 Sep 26 2015 03:54:12 +00:00 ccpexp/html/images/towerDown.png
131      16843 Sep 26 2015 03:54:14 +00:00 ccpexp/html/images/towerUp.png
132        330 Sep 26 2015 03:54:14 +00:00 ccpexp/html/images/user.png
133      17840 Sep 26 2015 03:54:14 +00:00 ccpexp/html/images/utm_40.png
134       3428 Sep 26 2015 03:54:14 +00:00 ccpexp/html/images/utm_80.jpg
135      12683 Sep 26 2015 03:54:16 +00:00 ccpexp/html/images/vpn.jpg
136       1488 Sep 26 2015 03:54:16 +00:00 ccpexp/html/images/vpn.png
137       1630 Sep 26 2015 03:54:16 +00:00 ccpexp/html/images/vpnAdd.png
138       1377 Sep 26 2015 03:54:16 +00:00 ccpexp/html/images/zone.png
139       4613 Sep 26 2015 03:53:30 +00:00 ccpexp/html/basicwizard.html
140     167875 Sep 26 2015 03:53:32 +00:00 ccpexp/html/ccpExpress.css1
141       8453 Sep 26 2015 03:53:32 +00:00 ccpexp/html/ccpExpress.html
142       3418 Sep 26 2015 03:53:32 +00:00 ccpexp/html/ceServer.html
143       6431 Sep 26 2015 03:53:34 +00:00 ccpexp/html/configureDHCP.html
144       9194 Sep 26 2015 03:53:34 +00:00 ccpexp/html/dhcpDns.html
145      17768 Sep 26 2015 03:53:34 +00:00 ccpexp/html/font-awesome.min.css1
146       6331 Sep 26 2015 03:53:38 +00:00 ccpexp/html/frames.html
147       1542 Sep 26 2015 03:53:38 +00:00 ccpexp/html/framesEndUser.html
148      41176 Sep 26 2015 03:53:38 +00:00 ccpexp/html/iAndC.html
149       6001 Sep 26 2015 03:54:18 +00:00 ccpexp/html/jquery.steps.css
150        703 Sep 26 2015 03:54:18 +00:00 ccpexp/html/jsNotEnabled.html
151       3670 Sep 26 2015 03:54:18 +00:00 ccpexp/html/navigationTemplate.html
152      12835 Sep 26 2015 03:54:18 +00:00 ccpexp/html/nv.d3.css
153      23346 Sep 26 2015 03:54:18 +00:00 ccpexp/html/overview.html
154       5634 Sep 26 2015 03:54:20 +00:00 ccpexp/html/phonehome.html
155       1948 Sep 26 2015 03:54:20 +00:00 ccpexp/html/pingAndTrace.html
156      10298 Sep 26 2015 03:54:20 +00:00 ccpexp/html/staticRouting.html
157       1754 Sep 26 2015 03:54:20 +00:00 ccpexp/html/transportCLI.html
158      23602 Sep 26 2015 03:54:22 +00:00 ccpexp/html/user.html
159      68649 Sep 26 2015 03:54:22 +00:00 ccpexp/html/utm.html
160       1970 Sep 26 2015 03:54:22 +00:00 ccpexp/html/wireless.html
161      99397 Sep 26 2015 03:54:24 +00:00 ccpexp/html/wizard.html
162          0 Sep 26 2015 03:53:08 +00:00 ccpexp/js
163          0 Sep 26 2015 03:53:08 +00:00 ccpexp/js/l10n
164          0 Sep 26 2015 03:53:08 +00:00 ccpexp/js/unittest
165        358 Sep 26 2015 03:54:24 +00:00 ccpexp/js/CachedCommands.JSON
166      91776 Sep 26 2015 03:54:24 +00:00 ccpexp/js/HWDictionary.xml
167       1873 Sep 26 2015 03:54:24 +00:00 ccpexp/js/analytics.js
168    1741767 Sep 26 2015 03:54:28 +00:00 ccpexp/js/ccpExpressFeatures.js
169      19236 Sep 26 2015 03:54:28 +00:00 ccpexp/js/ccpExpressValidation.js
170       6216 Sep 26 2015 03:54:28 +00:00 ccpexp/js/cliWorker.js
171       1157 Sep 26 2015 03:54:28 +00:00 ccpexp/js/connectionWorker.js
172      31509 Sep 26 2015 03:54:30 +00:00 ccpexp/js/deviceCommunicator.js
173      25304 Sep 26 2015 03:54:30 +00:00 ccpexp/js/frames.js
174      46890 Sep 26 2015 03:54:30 +00:00 ccpexp/js/performChecks.js
175       5521 Sep 26 2015 03:54:30 +00:00 ccpexp/js/routerDashboardWorker.js
176       5729 Sep 26 2015 03:54:32 +00:00 ccpexp/js/securityDashboardWorker.js
177      17547 Sep 26 2015 03:54:32 +00:00 ccpexp/js/wizard.js
178          0 Sep 26 2015 03:53:08 +00:00 ccpexp/odm
179        506 Sep 26 2015 03:54:32 +00:00 ccpexp/odm/overviewshCpuUtil.odm
180        630 Sep 26 2015 03:54:32 +00:00 ccpexp/odm/overviewshFileSystem.odm
181        813 Sep 26 2015 03:54:32 +00:00 ccpexp/odm/overviewshProcMemory.odm
182        818 Sep 26 2015 03:54:34 +00:00 ccpexp/odm/overviewshVer.odm
183        614 Sep 26 2015 03:54:34 +00:00 ccpexp/odm/wirelessshCdpNeighborDetail.odm
184          0 Sep 26 2015 03:53:08 +00:00 ccpexp/templates
185         85 Sep 26 2015 03:54:46 +00:00 ccpexp/templates/ATMDescription.txt
186         73 Sep 26 2015 03:54:46 +00:00 ccpexp/templates/ChatScript_EVDO.txt
187         72 Sep 26 2015 03:54:48 +00:00 ccpexp/templates/ChatScript_HSPA.txt
188         78 Sep 26 2015 03:54:48 +00:00 ccpexp/templates/ChatScript_HSPA7.txt
189         66 Sep 26 2015 03:54:48 +00:00 ccpexp/templates/ChatScript_LTE.txt
190         76 Sep 26 2015 03:54:48 +00:00 ccpexp/templates/CreateACLforNAT.txt
191       1042 Sep 26 2015 03:54:48 +00:00 ccpexp/templates/CreateATMBackupWanInterface.txt
192       1295 Sep 26 2015 03:54:50 +00:00 ccpexp/templates/CreateATMBackupWanInterfacewithPPPoE.txt
193        174 Sep 26 2015 03:54:50 +00:00 ccpexp/templates/CreateATMPrimaryWanInterface.txt
194        265 Sep 26 2015 03:54:50 +00:00 ccpexp/templates/CreateATMPrimaryWanInterfacewithPPPoE.txt
195       1468 Sep 26 2015 03:54:50 +00:00 ccpexp/templates/CreateBackUpCellular_DiPer_EVDO.txt
196       1431 Sep 26 2015 03:54:52 +00:00 ccpexp/templates/CreateBackUpCellular_DiPer_HSPA.txt
197       1465 Sep 26 2015 03:54:52 +00:00 ccpexp/templates/CreateBackUpCellular_DiPer_HSPA7.txt
198       1314 Sep 26 2015 03:54:52 +00:00 ccpexp/templates/CreateBackUpCellular_NonDiPer_EVDO.txt
199       1284 Sep 26 2015 03:54:52 +00:00 ccpexp/templates/CreateBackUpCellular_NonDiPer_HSPA.txt
200       1284 Sep 26 2015 03:54:52 +00:00 ccpexp/templates/CreateBackUpCellular_NonDiPer_HSPA7.txt
201        999 Sep 26 2015 03:54:54 +00:00 ccpexp/templates/CreateBackWanIntwithPPPoENoDialer.txt
202        907 Sep 26 2015 03:54:54 +00:00 ccpexp/templates/CreateBackupWanInterface.txt
203       1164 Sep 26 2015 03:54:54 +00:00 ccpexp/templates/CreateBackupWanInterfacewithPPPoE.txt
204         42 Sep 26 2015 03:54:54 +00:00 ccpexp/templates/CreateNatObjectGroup.txt
205        158 Sep 26 2015 03:54:56 +00:00 ccpexp/templates/CreatePrimWanIntwithPPPoENoDialer.txt
206        648 Sep 26 2015 03:54:56 +00:00 ccpexp/templates/CreatePrimaryCellular_DiPer_EVDO.txt
207        662 Sep 26 2015 03:54:56 +00:00 ccpexp/templates/CreatePrimaryCellular_DiPer_HSPA.txt
208        699 Sep 26 2015 03:54:56 +00:00 ccpexp/templates/CreatePrimaryCellular_DiPer_HSPA7.txt
209        552 Sep 26 2015 03:54:56 +00:00 ccpexp/templates/CreatePrimaryCellular_NonDiPer_EVDO.txt
210        517 Sep 26 2015 03:54:58 +00:00 ccpexp/templates/CreatePrimaryCellular_NonDiPer_HSPA.txt
211        517 Sep 26 2015 03:54:58 +00:00 ccpexp/templates/CreatePrimaryCellular_NonDiPer_HSPA7.txt
212        174 Sep 26 2015 03:54:58 +00:00 ccpexp/templates/CreatePrimaryWanInterface.txt
213        201 Sep 26 2015 03:54:58 +00:00 ccpexp/templates/CreatePrimaryWanInterfacewithPPPoE.txt
214        106 Sep 26 2015 03:55:00 +00:00 ccpexp/templates/DefaultCws.txt
215         68 Sep 26 2015 03:55:00 +00:00 ccpexp/templates/DefaultInterface.txt
216        696 Sep 26 2015 03:55:00 +00:00 ccpexp/templates/DefaultIps.txt
217        410 Sep 26 2015 03:55:00 +00:00 ccpexp/templates/DefaultZone.txt
218        110 Sep 26 2015 03:55:02 +00:00 ccpexp/templates/EncapsulationPPP.txt
219         96 Sep 26 2015 03:55:02 +00:00 ccpexp/templates/FirewallPolicyCreate.txt
220        271 Sep 26 2015 03:55:02 +00:00 ccpexp/templates/FirewallPolicyDeleteAll.txt
221        390 Sep 26 2015 03:55:02 +00:00 ccpexp/templates/FirewallPolicyDisable.txt
222        233 Sep 26 2015 03:55:04 +00:00 ccpexp/templates/FirewallPolicyEnable.txt
223        172 Sep 26 2015 03:55:04 +00:00 ccpexp/templates/FirewallVPNPolicyCreate.txt
224         39 Sep 26 2015 03:55:04 +00:00 ccpexp/templates/IPSAdd.txt
225        229 Sep 26 2015 03:55:04 +00:00 ccpexp/templates/IPSCompileSignatures.txt
226         42 Sep 26 2015 03:55:04 +00:00 ccpexp/templates/IPSDelete.txt
227         65 Sep 26 2015 03:55:06 +00:00 ccpexp/templates/MMDsl.txt
228         19 Sep 26 2015 03:55:06 +00:00 ccpexp/templates/NofilePrivilege.txt
229       1638 Sep 26 2015 03:55:06 +00:00 ccpexp/templates/ScannerPayloadTemplate.txt
230         56 Sep 26 2015 03:55:06 +00:00 ccpexp/templates/ZoneMgmtAdd.txt
231         59 Sep 26 2015 03:55:08 +00:00 ccpexp/templates/ZoneMgmtDelete.txt
232         45 Sep 26 2015 03:55:08 +00:00 ccpexp/templates/addDNS.txt
233         66 Sep 26 2015 03:55:08 +00:00 ccpexp/templates/addNewDHCP.txt
234         74 Sep 26 2015 03:55:08 +00:00 ccpexp/templates/addNewDHCP_DNS.txt
235         94 Sep 26 2015 03:55:10 +00:00 ccpexp/templates/associateVlan.txt
236         61 Sep 26 2015 03:55:10 +00:00 ccpexp/templates/authRoulToLAN.txt
237        114 Sep 26 2015 03:55:10 +00:00 ccpexp/templates/authorizationPolicy.txt
238         10 Sep 26 2015 03:55:10 +00:00 ccpexp/templates/cdpRun.txt
239        146 Sep 26 2015 03:55:12 +00:00 ccpexp/templates/chap.txt
240         87 Sep 26 2015 03:55:12 +00:00 ccpexp/templates/classMapApp.txt
241         79 Sep 26 2015 03:55:12 +00:00 ccpexp/templates/classMapCategory.txt
242         88 Sep 26 2015 03:55:12 +00:00 ccpexp/templates/classMapParameterMap.txt
243         85 Sep 26 2015 03:55:12 +00:00 ccpexp/templates/classMapPolicy.txt
244        103 Sep 26 2015 03:55:14 +00:00 ccpexp/templates/classMapURL.txt
245         88 Sep 26 2015 03:55:14 +00:00 ccpexp/templates/classMapUserGroup.txt
246        364 Sep 26 2015 03:55:14 +00:00 ccpexp/templates/cnsFormCreate.txt
247        461 Sep 26 2015 03:55:14 +00:00 ccpexp/templates/cnsFormCreateWithIp.txt
248        255 Sep 26 2015 03:55:16 +00:00 ccpexp/templates/cnsFormCreateWithoutIp.txt
249        478 Sep 26 2015 03:55:16 +00:00 ccpexp/templates/cnsFormDelete.txt
250        361 Sep 26 2015 03:55:16 +00:00 ccpexp/templates/cnsFormImage.txt
251        590 Sep 26 2015 03:55:16 +00:00 ccpexp/templates/cnsFormImageDelete.txt
252        478 Sep 26 2015 03:55:18 +00:00 ccpexp/templates/cnsFormIpDelete.txt
253        412 Sep 26 2015 03:55:18 +00:00 ccpexp/templates/cnsFormWithoutIpDelete.txt
254        110 Sep 26 2015 03:55:18 +00:00 ccpexp/templates/configAuthServer.txt
255        161 Sep 26 2015 03:55:18 +00:00 ccpexp/templates/configLDAPIPv4.txt
256        138 Sep 26 2015 03:55:20 +00:00 ccpexp/templates/configNTLMService.txt
257        159 Sep 26 2015 03:55:20 +00:00 ccpexp/templates/configNetFlow.txt
258         46 Sep 26 2015 03:55:20 +00:00 ccpexp/templates/configWebAuthService.txt
259         31 Sep 26 2015 03:55:20 +00:00 ccpexp/templates/contentScan.txt
260        113 Sep 26 2015 03:55:20 +00:00 ccpexp/templates/createATMInterface.txt
261        148 Sep 26 2015 03:55:22 +00:00 ccpexp/templates/createATMInterfacePppoe.txt
262        135 Sep 26 2015 03:55:22 +00:00 ccpexp/templates/createATMInterfaceWithDHCP.txt
263        158 Sep 26 2015 03:55:22 +00:00 ccpexp/templates/createATMInterfaceWithDHCPHostname.txt
264        137 Sep 26 2015 03:55:24 +00:00 ccpexp/templates/createATMInterfaceWithIpv6Autoconfig.txt
265        102 Sep 26 2015 03:55:24 +00:00 ccpexp/templates/createATMInterfaceWithIpv6DhcpClient.txt
266        203 Sep 26 2015 03:55:24 +00:00 ccpexp/templates/createATMInterfaceWithIpv6PrefixFPro.txt
267        165 Sep 26 2015 03:55:24 +00:00 ccpexp/templates/createATMInterfaceWithIpv6StaticIP.txt
268        137 Sep 26 2015 03:55:26 +00:00 ccpexp/templates/createATMInterfaceWithStaticIP.txt
269        417 Sep 26 2015 03:55:26 +00:00 ccpexp/templates/createDialer.txt
270        102 Sep 26 2015 03:55:26 +00:00 ccpexp/templates/createEigrp.txt
271         80 Sep 26 2015 03:55:26 +00:00 ccpexp/templates/createInterface.txt
272        137 Sep 26 2015 03:55:28 +00:00 ccpexp/templates/createLoopback.txt
273        198 Sep 26 2015 03:55:28 +00:00 ccpexp/templates/createNat.txt
274         50 Sep 26 2015 03:55:28 +00:00 ccpexp/templates/createNatOutside.txt
275        131 Sep 26 2015 03:55:28 +00:00 ccpexp/templates/createVLAN.txt
276         57 Sep 26 2015 03:55:30 +00:00 ccpexp/templates/cwsWhiteListing.txt
277         66 Sep 26 2015 03:55:30 +00:00 ccpexp/templates/deConfigAuthRoulToLAN.txt
278        116 Sep 26 2015 03:55:30 +00:00 ccpexp/templates/deConfigAuthServer.txt
279        148 Sep 26 2015 03:55:30 +00:00 ccpexp/templates/deConfigNTLMAuthService.txt
280        174 Sep 26 2015 03:55:32 +00:00 ccpexp/templates/deConfigNetFlow.txt
281         47 Sep 26 2015 03:55:32 +00:00 ccpexp/templates/deConfigWebAuthService.txt
282         67 Sep 26 2015 03:55:32 +00:00 ccpexp/templates/deconfigLDAP.txt
283        108 Sep 26 2015 03:55:32 +00:00 ccpexp/templates/defaultRoute.txt
284         49 Sep 26 2015 03:55:34 +00:00 ccpexp/templates/deleteAclClassMap.txt
285        600 Sep 26 2015 03:55:34 +00:00 ccpexp/templates/deleteBackupInterfaceConfigs.txt
286        745 Sep 26 2015 03:55:34 +00:00 ccpexp/templates/deleteBackupInterfaceConfigsPPPOE.txt
287         44 Sep 26 2015 03:55:34 +00:00 ccpexp/templates/deleteClassMapApp.txt
288         40 Sep 26 2015 03:55:36 +00:00 ccpexp/templates/deleteClassMapUrl.txt
289         34 Sep 26 2015 03:55:36 +00:00 ccpexp/templates/deleteContentScan.txt
290         19 Sep 26 2015 03:55:36 +00:00 ccpexp/templates/deleteCwsWhiteListing.txt
291         25 Sep 26 2015 03:55:36 +00:00 ccpexp/templates/deleteDNS.txt
292         52 Sep 26 2015 03:55:38 +00:00 ccpexp/templates/deleteDescription.txt
293         49 Sep 26 2015 03:55:38 +00:00 ccpexp/templates/deleteDialerList.txt
294         84 Sep 26 2015 03:55:38 +00:00 ccpexp/templates/deleteDomainNameDNS.txt
295         30 Sep 26 2015 03:55:38 +00:00 ccpexp/templates/deleteEigrp.txt
296         80 Sep 26 2015 03:55:40 +00:00 ccpexp/templates/deleteEnableNbarProtocolDiscovery.txt
297        102 Sep 26 2015 03:55:40 +00:00 ccpexp/templates/deleteExternalDNS.txt
298         32 Sep 26 2015 03:55:40 +00:00 ccpexp/templates/deleteGroup.txt
299        100 Sep 26 2015 03:55:40 +00:00 ccpexp/templates/deleteInterface.txt
300         40 Sep 26 2015 03:55:42 +00:00 ccpexp/templates/deleteIpAccessList.txt
301         63 Sep 26 2015 03:55:42 +00:00 ccpexp/templates/deleteLocalDNS.txt
302        163 Sep 26 2015 03:55:42 +00:00 ccpexp/templates/deleteNat.txt
303         56 Sep 26 2015 03:55:44 +00:00 ccpexp/templates/deleteNatOutside.txt
304         36 Sep 26 2015 03:55:44 +00:00 ccpexp/templates/deleteObjectGroupNetwork.txt
305         38 Sep 26 2015 03:55:44 +00:00 ccpexp/templates/deleteObjectService.txt
306         44 Sep 26 2015 03:55:44 +00:00 ccpexp/templates/deleteParameterMap.txt
307         47 Sep 26 2015 03:55:46 +00:00 ccpexp/templates/deletePolicyClassMap.txt
308         40 Sep 26 2015 03:55:46 +00:00 ccpexp/templates/deletePolicyMap.txt
309         73 Sep 26 2015 03:55:46 +00:00 ccpexp/templates/deletePolicyMapClass.txt
310        199 Sep 26 2015 03:55:46 +00:00 ccpexp/templates/deletePrimaryIfRoutesAndAcl.txt
311        347 Sep 26 2015 03:55:48 +00:00 ccpexp/templates/deletePrimaryPPPOE.txt
312        164 Sep 26 2015 03:55:48 +00:00 ccpexp/templates/deletePrimaryRoutes.txt
313        120 Sep 26 2015 03:55:48 +00:00 ccpexp/templates/deleteRedundantRoute.txt
314         32 Sep 26 2015 03:55:48 +00:00 ccpexp/templates/deleteScanSafe.txt
315         60 Sep 26 2015 03:55:50 +00:00 ccpexp/templates/deleteScriptFromLine.txt
316         46 Sep 26 2015 03:55:50 +00:00 ccpexp/templates/deleteUserClassMap.txt
317         85 Sep 26 2015 03:55:50 +00:00 ccpexp/templates/deleteVlan.txt
318        154 Sep 26 2015 03:55:50 +00:00 ccpexp/templates/deleteVpnIkev1.txt
319        104 Sep 26 2015 03:55:52 +00:00 ccpexp/templates/deleteVpnIkev1InterfaceTunnel.txt
320        208 Sep 26 2015 03:55:52 +00:00 ccpexp/templates/deleteVpnIkev2.txt
321        185 Sep 26 2015 03:55:52 +00:00 ccpexp/templates/deleteVpnIkev2InterfaceTunnel.txt
322         63 Sep 26 2015 03:55:54 +00:00 ccpexp/templates/deleteVpnObjectGroup.txt
323         45 Sep 26 2015 03:55:54 +00:00 ccpexp/templates/deleteVpnWhiteListing.txt
324         76 Sep 26 2015 03:55:54 +00:00 ccpexp/templates/deleteZonePair.txt
325         44 Sep 26 2015 03:55:54 +00:00 ccpexp/templates/dest-net-ipv6Interface.txt
326         47 Sep 26 2015 03:55:56 +00:00 ccpexp/templates/dest-net-ipv6InterfaceDelete.txt
327         44 Sep 26 2015 03:55:56 +00:00 ccpexp/templates/dest-net-ipv6Ip.txt
328         37 Sep 26 2015 03:55:56 +00:00 ccpexp/templates/dest-net-ipv6IpDelete.txt
329         33 Sep 26 2015 03:55:56 +00:00 ccpexp/templates/dest-netInterfaceCreate.txt
330         36 Sep 26 2015 03:55:58 +00:00 ccpexp/templates/dest-netInterfaceDelete.txt
331         29 Sep 26 2015 03:55:58 +00:00 ccpexp/templates/dest-netIpCreate.txt
332         29 Sep 26 2015 03:55:58 +00:00 ccpexp/templates/dest-netIpDelete.txt
333         27 Sep 26 2015 03:55:58 +00:00 ccpexp/templates/dest-netIpDhcpCreate.txt
334         30 Sep 26 2015 03:56:00 +00:00 ccpexp/templates/dest-netIpDhcpDelete.txt
335         93 Sep 26 2015 03:56:00 +00:00 ccpexp/templates/deteteATMInterface.txt
336        134 Sep 26 2015 03:56:00 +00:00 ccpexp/templates/deteteDialer.txt
337        119 Sep 26 2015 03:56:00 +00:00 ccpexp/templates/dialerDHCP.txt
338        130 Sep 26 2015 03:56:00 +00:00 ccpexp/templates/dialerDHCPHostname.txt
339        103 Sep 26 2015 03:56:02 +00:00 ccpexp/templates/dialerIPNego.txt
340        117 Sep 26 2015 03:56:02 +00:00 ccpexp/templates/dialerIpv6Autoconfig.txt
341         82 Sep 26 2015 03:56:02 +00:00 ccpexp/templates/dialerIpv6DhcpClient.txt
342        156 Sep 26 2015 03:56:04 +00:00 ccpexp/templates/dialerIpv6PrefixFromProvider.txt
343        135 Sep 26 2015 03:56:04 +00:00 ccpexp/templates/dialerIpv6StaticIP.txt
344        109 Sep 26 2015 03:56:04 +00:00 ccpexp/templates/dialerStaticIP.txt
345         72 Sep 26 2015 03:56:04 +00:00 ccpexp/templates/disableNativeVlanOnInterface.txt
346         59 Sep 26 2015 03:56:06 +00:00 ccpexp/templates/disableTrunkOnInterface.txt
347         75 Sep 26 2015 03:56:06 +00:00 ccpexp/templates/disassociateVlan.txt
348        202 Sep 26 2015 03:56:06 +00:00 ccpexp/templates/domainNameDNS.txt
349        260 Sep 26 2015 03:56:06 +00:00 ccpexp/templates/enableAAAConfig.txt
350         23 Sep 26 2015 03:56:08 +00:00 ccpexp/templates/enableIpv6UnicastRouting.txt
351         73 Sep 26 2015 03:56:08 +00:00 ccpexp/templates/enableLicense.txt
352         84 Sep 26 2015 03:56:08 +00:00 ccpexp/templates/enableNativeVlanOnInterface.txt
353         74 Sep 26 2015 03:56:08 +00:00 ccpexp/templates/enableNbarProtocolDiscovery.txt
354         68 Sep 26 2015 03:56:10 +00:00 ccpexp/templates/enableTrunkOnInterface.txt
355         73 Sep 26 2015 03:56:10 +00:00 ccpexp/templates/encryptLicenseCWS.txt
356         84 Sep 26 2015 03:56:10 +00:00 ccpexp/templates/externalDNS.txt
357         19 Sep 26 2015 03:56:10 +00:00 ccpexp/templates/filePrivilege.txt
358         88 Sep 26 2015 03:56:12 +00:00 ccpexp/templates/group.txt
359         69 Sep 26 2015 03:56:12 +00:00 ccpexp/templates/hostnameDomainname.txt
360         39 Sep 26 2015 03:56:12 +00:00 ccpexp/templates/import.txt
361         63 Sep 26 2015 03:56:12 +00:00 ccpexp/templates/interfaceDescription.txt
362         61 Sep 26 2015 03:56:14 +00:00 ccpexp/templates/interfaceMediaType.txt
363         51 Sep 26 2015 03:56:14 +00:00 ccpexp/templates/interfaceNoShut.txt
364        114 Sep 26 2015 03:56:14 +00:00 ccpexp/templates/interfacePppoe.txt
365         45 Sep 26 2015 03:56:14 +00:00 ccpexp/templates/interfaceShut.txt
366         86 Sep 26 2015 03:56:14 +00:00 ccpexp/templates/interfaceWithDHCP.txt
367        109 Sep 26 2015 03:56:16 +00:00 ccpexp/templates/interfaceWithDHCPHostname.txt
368         92 Sep 26 2015 03:56:16 +00:00 ccpexp/templates/interfaceWithIPNego.txt
369        114 Sep 26 2015 03:56:16 +00:00 ccpexp/templates/interfaceWithIpv6Autoconfig.txt
370        123 Sep 26 2015 03:56:16 +00:00 ccpexp/templates/interfaceWithIpv6DhcpClient.txt
371        153 Sep 26 2015 03:56:18 +00:00 ccpexp/templates/interfaceWithIpv6PrefixFromProvider.txt
372        132 Sep 26 2015 03:56:18 +00:00 ccpexp/templates/interfaceWithIpv6StaticIP.txt
373         88 Sep 26 2015 03:56:18 +00:00 ccpexp/templates/interfaceWithStaticIP.txt
374         29 Sep 26 2015 03:56:18 +00:00 ccpexp/templates/ipv4DHCPDelete.txt
375         42 Sep 26 2015 03:56:20 +00:00 ccpexp/templates/ipv4DHCPDelete_DNS.txt
376        193 Sep 26 2015 03:56:20 +00:00 ccpexp/templates/licenseCWS.txt
377         49 Sep 26 2015 03:56:20 +00:00 ccpexp/templates/localDNS.txt
378        132 Sep 26 2015 03:56:20 +00:00 ccpexp/templates/loopbackIpv6StaticIP.txt
379         90 Sep 26 2015 03:56:22 +00:00 ccpexp/templates/loopbackStaticIP.txt
380     106537 Sep 26 2015 03:56:22 +00:00 ccpexp/templates/masking_rule.xml
381         48 Sep 26 2015 03:56:22 +00:00 ccpexp/templates/natInside.txt
382        155 Sep 26 2015 03:56:24 +00:00 ccpexp/templates/networkPortAccessList.txt
383         13 Sep 26 2015 03:56:24 +00:00 ccpexp/templates/noCdpRun.txt
384         47 Sep 26 2015 03:56:24 +00:00 ccpexp/templates/noDefaultRoute.txt
385         50 Sep 26 2015 03:56:24 +00:00 ccpexp/templates/noDslGroup0.txt
386         11 Sep 26 2015 03:56:26 +00:00 ccpexp/templates/noIpSla.txt
387         51 Sep 26 2015 03:56:26 +00:00 ccpexp/templates/noNatInside.txt
388         42 Sep 26 2015 03:56:26 +00:00 ccpexp/templates/noimport.txt
389         61 Sep 26 2015 03:56:26 +00:00 ccpexp/templates/objectGroupNetwork.txt
390        111 Sep 26 2015 03:56:28 +00:00 ccpexp/templates/objectGroupPort.txt
391        137 Sep 26 2015 03:56:28 +00:00 ccpexp/templates/pap.txt
392        220 Sep 26 2015 03:56:28 +00:00 ccpexp/templates/papchap.txt
393         76 Sep 26 2015 03:56:28 +00:00 ccpexp/templates/parameterMapURL.txt
394        276 Sep 26 2015 03:56:30 +00:00 ccpexp/templates/parserCLIAaaCommands.txt
395        305 Sep 26 2015 03:56:30 +00:00 ccpexp/templates/parserCLICellularCommands.txt
396        201 Sep 26 2015 03:56:30 +00:00 ccpexp/templates/parserCLIDeleteAaaCommand.txt
397         29 Sep 26 2015 03:56:30 +00:00 ccpexp/templates/parserCLIDeleteView.txt
398         55 Sep 26 2015 03:56:32 +00:00 ccpexp/templates/parserCLIInterface.txt
399        667 Sep 26 2015 03:56:32 +00:00 ccpexp/templates/parserCLIView.txt
400        242 Sep 26 2015 03:56:32 +00:00 ccpexp/templates/parserCLIWlanCommand.txt
401         26 Sep 26 2015 03:56:32 +00:00 ccpexp/templates/parserUserDeleteCmd.txt
402        110 Sep 26 2015 03:56:32 +00:00 ccpexp/templates/policyMap.txt
403         96 Sep 26 2015 03:56:34 +00:00 ccpexp/templates/removeAccessList23.txt
404       1160 Sep 26 2015 03:56:34 +00:00 ccpexp/templates/sampleSwitchConfiguration.txt
405        104 Sep 26 2015 03:56:34 +00:00 ccpexp/templates/scanSafeNameOrIPv4.txt
406        108 Sep 26 2015 03:56:34 +00:00 ccpexp/templates/secondaryIPv4OrName.txt
407        102 Sep 26 2015 03:56:36 +00:00 ccpexp/templates/setDefaultRoute.txt
408         63 Sep 26 2015 03:56:36 +00:00 ccpexp/templates/setMTUSize.txt
409         52 Sep 26 2015 03:56:36 +00:00 ccpexp/templates/shdslATM.txt
410         50 Sep 26 2015 03:56:36 +00:00 ccpexp/templates/shdslAUTO.txt
411         64 Sep 26 2015 03:56:38 +00:00 ccpexp/templates/shdslEFM.txt
412         50 Sep 26 2015 03:56:38 +00:00 ccpexp/templates/shdslEFMATM.txt
413         93 Sep 26 2015 03:56:38 +00:00 ccpexp/templates/shdslMMEFMATM.txt
414         73 Sep 26 2015 03:56:38 +00:00 ccpexp/templates/shutdownDmvpn.txt
415        446 Sep 26 2015 03:56:40 +00:00 ccpexp/templates/tunnelConfiguration.txt
416         21 Sep 26 2015 03:56:40 +00:00 ccpexp/templates/userFormDelete.txt
417         61 Sep 26 2015 03:56:40 +00:00 ccpexp/templates/userPasswordCreate.txt
418         59 Sep 26 2015 03:56:40 +00:00 ccpexp/templates/userSecretCreate.txt
419         48 Sep 26 2015 03:56:42 +00:00 ccpexp/templates/userToGroup.txt
420        570 Sep 26 2015 03:56:42 +00:00 ccpexp/templates/vpnIKEv1.txt
421        782 Sep 26 2015 03:56:42 +00:00 ccpexp/templates/vpnIKEv2.txt
422        323 Sep 26 2015 03:56:42 +00:00 ccpexp/templates/vpnIkev1InterfaceTunnel.txt
423        300 Sep 26 2015 03:56:44 +00:00 ccpexp/templates/vpnIkev2InterfaceTunnel.txt
424         85 Sep 26 2015 03:56:44 +00:00 ccpexp/templates/vpnWhiteListing.txt
425         20 Sep 26 2015 03:56:44 +00:00 ccpexp/templates/wanMode.txt
426        117 Sep 26 2015 03:56:44 +00:00 ccpexp/templates/zonePair.txt
427          0 Sep 26 2015 03:53:10 +00:00 ccpexp/templates2
428        907 Sep 26 2015 03:54:34 +00:00 ccpexp/templates2/CellularNanoDialer.txt
429        687 Sep 26 2015 03:54:34 +00:00 ccpexp/templates2/CellularNanoSim0.txt
430       6470 Sep 26 2015 03:54:36 +00:00 ccpexp/templates2/EMScriptCellular.txt
431       8635 Sep 26 2015 03:54:36 +00:00 ccpexp/templates2/EMScriptTemplate.txt
432      71244 Sep 26 2015 03:54:36 +00:00 ccpexp/templates2/Quick_Setup.txt
433         51 Sep 26 2015 03:54:36 +00:00 ccpexp/templates2/addNAT.txt
434         61 Sep 26 2015 03:54:36 +00:00 ccpexp/templates2/addNATInterface.txt
435         95 Sep 26 2015 03:54:38 +00:00 ccpexp/templates2/addNATwithPort.txt
436         85 Sep 26 2015 03:54:38 +00:00 ccpexp/templates2/addPort.txt
437         61 Sep 26 2015 03:54:38 +00:00 ccpexp/templates2/assignProfile.txt
438         41 Sep 26 2015 03:54:38 +00:00 ccpexp/templates2/cntrlrOperatingMode.txt
439         58 Sep 26 2015 03:54:40 +00:00 ccpexp/templates2/createClockRate.txt
440        214 Sep 26 2015 03:54:40 +00:00 ccpexp/templates2/createDialerEthernet.txt
441        230 Sep 26 2015 03:54:40 +00:00 ccpexp/templates2/createSerialPPP.txt
442        109 Sep 26 2015 03:54:40 +00:00 ccpexp/templates2/createSubEthernet.txt
443         60 Sep 26 2015 03:54:40 +00:00 ccpexp/templates2/createSubEthernetWithoutPPPoE.txt
444        151 Sep 26 2015 03:54:42 +00:00 ccpexp/templates2/deleteATMInterfacePppoe.txt
445         41 Sep 26 2015 03:54:42 +00:00 ccpexp/templates2/deleteDHCPDefaultRoute.txt
446        105 Sep 26 2015 03:54:42 +00:00 ccpexp/templates2/deleteEthernetInterfacePppoe.txt
447         72 Sep 26 2015 03:54:42 +00:00 ccpexp/templates2/deleteNATInterface.txt
448         98 Sep 26 2015 03:54:44 +00:00 ccpexp/templates2/deleteNATIntwithPort.txt
449         62 Sep 26 2015 03:54:44 +00:00 ccpexp/templates2/deleteNATVal.txt
450         88 Sep 26 2015 03:54:44 +00:00 ccpexp/templates2/deleteOldNAT.txt
451         85 Sep 26 2015 03:54:44 +00:00 ccpexp/templates2/deleteSerialPPP.txt
452         61 Sep 26 2015 03:54:44 +00:00 ccpexp/templates2/interfaceWithDHCPPool.txt
453         57 Sep 26 2015 03:54:46 +00:00 ccpexp/templates2/setPrimarySimSlot.txt
454        255 Sep 26 2015 03:54:46 +00:00 ccpexp/templates2/vpnIkev1Modified.txt
455     132462 Sep 26 2015 03:53:10 +00:00 ccpexp/CCPExpress_3.1_Open_Source_Documentation.html
456         70 Sep 26 2015 03:56:44 +00:00 ccpexp/version.txt
457       2885 Sep 26 2015 03:56:46 +00:00 home.shtml
458      99928 Nov 16 2015 23:19:48 +00:00 fbi88xx.BE-01-010.sbn
459    4242376 Nov 16 2015 23:20:34 +00:00 kern88xx.10-3-1-20.sbn
460   54186320 Nov 16 2015 23:22:56 +00:00 rootfs88xx.10-3-1-20.sbn
461       1225 Nov 16 2015 23:23:30 +00:00 sip88xx.10-3-1-20.loads
462     431180 Nov 16 2015 23:24:20 +00:00 sb288xx.BE-01-019.sbn
463    4217072 Nov 16 2015 23:25:08 +00:00 vc488xx.10-3-1-20.sbn
464          0 Nov 17 2015 15:20:30 +00:00 its
465       4748 Nov 17 2015 17:04:32 +00:00 its/softkeyDefault_kpml.xml
466       1948 Nov 17 2015 17:04:32 +00:00 its/SIPDefault.cnf
467       4782 Nov 17 2015 17:04:34 +00:00 its/softkey10.xml
468         69 Nov 17 2015 17:04:32 +00:00 its/syncinfo.xml
469       4782 Nov 17 2015 17:04:34 +00:00 its/softkeyDefault.xml
470       4748 Nov 17 2015 17:04:34 +00:00 its/softkey10_kpml.xml
471        824 Nov 17 2015 17:04:34 +00:00 its/featurePolicyDefault.xml
472        825 Nov 17 2015 17:04:36 +00:00 its/featurePolicy10.xml
473       4776 Nov 17 2015 17:04:36 +00:00 its/SEPAC7E8A2B07A4.cnf.xml
86364160 bytes available (174833664 bytes used)
VSB-Glville-2901#sh voice register tftp-bind
tftp-server url flash:/its/syncinfo.xml alias syncinfo.xml
tftp-server url flash:/its/SIPDefault.cnf alias SIPDefault.cnf
tftp-server url flash:/its/softkeyDefault_kpml.xml alias softkeyDefault_kpml.xml
tftp-server url flash:/its/softkeyDefault.xml alias softkeyDefault.xml
tftp-server url flash:/its/softkey10_kpml.xml alias softkey10_kpml.xml
tftp-server url flash:/its/softkey10.xml alias softkey10.xml
tftp-server url flash:/its/featurePolicyDefault.xml alias featurePolicyDefault.xml
tftp-server url flash:/its/featurePolicy10.xml alias featurePolicy10.xml
tftp-server url flash:/its/SEPAC7E8A2B07A4.cnf.xml alias SEPAC7E8A2B07A4.cnf.xml
VSB-Glville-2901#
VSB-Glville-2901#
*Nov 17 17:09:37.079: TFTP: Server request for port 49650, socket_id 0x3E129A08 for process 427
*Nov 17 17:09:37.079: TFTP: read request from host 10.20.168.11(49650) via GigabitEthernet0/0.20
*Nov 17 17:09:37.079: TFTP: Looking for CTLSEPAC7E8A2B07A4.tlv
*Nov 17 17:09:37.079: TFTP: Sending error 1 No such file
*Nov 17 17:09:38.027: TFTP: Server request for port 52129, socket_id 0x3E129A08 for process 427
*Nov 17 17:09:38.027: TFTP: read request from host 10.20.168.11(52129) via GigabitEthernet0/0.20
*Nov 17 17:09:38.027: TFTP: Looking for ITLSEPAC7E8A2B07A4.tlv
*Nov 17 17:09:38.027: TFTP: Sending error 1 No such file
*Nov 17 17:09:39.087: TFTP: Server request for port 49547, socket_id 0x3E129A08 for process 427
*Nov 17 17:09:39.087: TFTP: read request from host 10.20.168.11(49547) via GigabitEthernet0/0.20
*Nov 17 17:09:39.087: TFTP: Looking for ITLFile.tlv
*Nov 17 17:09:39.087: TFTP: Sending error 1 No such file
*Nov 17 17:09:40.055: TFTP: Server request for port 50857, socket_id 0x3E129A08 for process 427
*Nov 17 17:09:40.055: TFTP: read request from host 10.20.168.11(50857) via GigabitEthernet0/0.20
*Nov 17 17:09:40.055: TFTP: Looking for SEPAC7E8A2B07A4.cnf.xml
*Nov 17 17:09:40.059: TFTP: Opened flash:/its/SEPAC7E8A2B07A4.cnf.xml, fd 5, size 4776 for process 427
*Nov 17 17:09:40.059: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:09:40.059: TFTP: Received ACK for block 1, socket_id 0x3E129A08
*Nov 17 17:09:40.059: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:09:40.059: TFTP: Received ACK for block 2, socket_id 0x3E129A08
*Nov 17 17:09:40.059: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:09:40.059: TFTP: Received ACK for block 3, socket_id 0x3E129A08
*Nov 17 17:09:40.059: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:09:40.063: TFTP: Received ACK for block 4, socket_id 0x3E129A08
*Nov 17 17:09:40.063: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:09:40.063: TFTP: Received ACK for block 5, socket_id 0x3E129A08
*Nov 17 17:09:40.063: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:09:40.063: TFTP: Received ACK for block 6, socket_id 0x3E129A08
*Nov 17 17:09:40.063: TFTP: Sending block 7 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:09:40.063: TFTP: Received ACK for block 7, socket_id 0x3E129A08
*Nov 17 17:09:40.063: TFTP: Sending block 8 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:09:40.063: TFTP: Received ACK for block 8, socket_id 0x3E129A08
*Nov 17 17:09:40.063: TFTP: Sending block 9 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:09:40.063: TFTP: Received ACK for block 9, socket_id 0x3E129A08
*Nov 17 17:09:40.063: TFTP: Sending block 10 (retry 0), len 168, socket_id 0x3E129A08
*Nov 17 17:09:40.063: TFTP: Received ACK for block 10, socket_id 0x3E129A08
*Nov 17 17:09:40.063: TFTP: Finished flash:/its/SEPAC7E8A2B07A4.cnf.xml, time 00:00:00 for process 427
*Nov 17 17:09:43.019: TFTP: Server request for port 50436, socket_id 0x3E129A08 for process 427
*Nov 17 17:09:43.019: TFTP: read request from host 10.20.168.11(50436) via GigabitEthernet0/0.20
*Nov 17 17:09:43.019: TFTP: Looking for SIP_English_United_States/sl-be-sip.jar
*Nov 17 17:09:43.019: TFTP: Sending error 1 No such file
*Nov 17 17:09:43.979: TFTP: Server request for port 52765, socket_id 0x3E129A08 for process 427
*Nov 17 17:09:43.979: TFTP: read request from host 10.20.168.11(52765) via GigabitEthernet0/0.20
*Nov 17 17:09:43.979: TFTP: Looking for United_Kingdom/g3-tones.xml
*Nov 17 17:09:43.979: TFTP: Sending error 1 No such file
*Nov 17 17:10:15.399: TFTP: Server request for port 51720, socket_id 0x3E129A08 for process 427
*Nov 17 17:10:15.399: TFTP: read request from host 10.20.168.11(51720) via GigabitEthernet0/0.20
*Nov 17 17:10:15.399: TFTP: Looking for CTLSEPAC7E8A2B07A4.tlv
*Nov 17 17:10:15.399: TFTP: Sending error 1 No such file
*Nov 17 17:10:16.335: TFTP: Server request for port 50356, socket_id 0x3E129A08 for process 427
*Nov 17 17:10:16.335: TFTP: read request from host 10.20.168.11(50356) via GigabitEthernet0/0.20
*Nov 17 17:10:16.335: TFTP: Looking for ITLSEPAC7E8A2B07A4.tlv
*Nov 17 17:10:16.335: TFTP: Sending error 1 No such file
*Nov 17 17:10:17.327: TFTP: Server request for port 52309, socket_id 0x3E129A08 for process 427
*Nov 17 17:10:17.327: TFTP: read request from host 10.20.168.11(52309) via GigabitEthernet0/0.20
*Nov 17 17:10:17.327: TFTP: Looking for ITLFile.tlv
*Nov 17 17:10:17.327: TFTP: Sending error 1 No such file
*Nov 17 17:10:18.343: TFTP: Server request for port 51577, socket_id 0x3E129A08 for process 427
*Nov 17 17:10:18.343: TFTP: read request from host 10.20.168.11(51577) via GigabitEthernet0/0.20
*Nov 17 17:10:18.347: TFTP: Looking for SEPAC7E8A2B07A4.cnf.xml
*Nov 17 17:10:18.347: TFTP: Opened flash:/its/SEPAC7E8A2B07A4.cnf.xml, fd 5, size 4776 for process 427
*Nov 17 17:10:18.347: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:18.347: TFTP: Received ACK for block 1, socket_id 0x3E129A08
*Nov 17 17:10:18.347: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:18.347: TFTP: Received ACK for block 2, socket_id 0x3E129A08
*Nov 17 17:10:18.347: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:18.347: TFTP: Received ACK for block 3, socket_id 0x3E129A08
*Nov 17 17:10:18.347: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:18.351: TFTP: Received ACK for block 4, socket_id 0x3E129A08
*Nov 17 17:10:18.351: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:18.351: TFTP: Received ACK for block 5, socket_id 0x3E129A08
*Nov 17 17:10:18.351: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:18.351: TFTP: Received ACK for block 6, socket_id 0x3E129A08
*Nov 17 17:10:18.351: TFTP: Sending block 7 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:18.351: TFTP: Received ACK for block 7, socket_id 0x3E129A08
*Nov 17 17:10:18.351: TFTP: Sending block 8 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:18.351: TFTP: Received ACK for block 8, socket_id 0x3E129A08
*Nov 17 17:10:18.351: TFTP: Sending block 9 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:18.351: TFTP: Received ACK for block 9, socket_id 0x3E129A08
*Nov 17 17:10:18.351: TFTP: Sending block 10 (retry 0), len 168, socket_id 0x3E129A08
*Nov 17 17:10:18.351: TFTP: Received ACK for block 10, socket_id 0x3E129A08
*Nov 17 17:10:18.351: TFTP: Finished flash:/its/SEPAC7E8A2B07A4.cnf.xml, time 00:00:00 for process 427
*Nov 17 17:10:21.287: TFTP: Server request for port 51705, socket_id 0x3E129A08 for process 427
*Nov 17 17:10:21.287: TFTP: read request from host 10.20.168.11(51705) via GigabitEthernet0/0.20
*Nov 17 17:10:21.287: TFTP: Looking for SIP_English_United_States/sl-be-sip.jar
*Nov 17 17:10:21.287: TFTP: Sending error 1 No such file
*Nov 17 17:10:22.247: TFTP: Server request for port 51021, socket_id 0x3E129A08 for process 427
*Nov 17 17:10:22.247: TFTP: read request from host 10.20.168.11(51021) via GigabitEthernet0/0.20
*Nov 17 17:10:22.247: TFTP: Looking for United_Kingdom/g3-tones.xml
*Nov 17 17:10:22.247: TFTP: Sending error 1 No such file
*Nov 17 17:10:53.607: TFTP: Server request for port 49309, socket_id 0x3E129A08 for process 427
*Nov 17 17:10:53.607: TFTP: read request from host 10.20.168.11(49309) via GigabitEthernet0/0.20
*Nov 17 17:10:53.607: TFTP: Looking for CTLSEPAC7E8A2B07A4.tlv
*Nov 17 17:10:53.607: TFTP: Sending error 1 No such file
*Nov 17 17:10:54.635: TFTP: Server request for port 51527, socket_id 0x3E129A08 for process 427
*Nov 17 17:10:54.635: TFTP: read request from host 10.20.168.11(51527) via GigabitEthernet0/0.20
*Nov 17 17:10:54.639: TFTP: Looking for ITLSEPAC7E8A2B07A4.tlv
*Nov 17 17:10:54.639: TFTP: Sending error 1 No such file
*Nov 17 17:10:55.655: TFTP: Server request for port 52133, socket_id 0x3E129A08 for process 427
*Nov 17 17:10:55.655: TFTP: read request from host 10.20.168.11(52133) via GigabitEthernet0/0.20
*Nov 17 17:10:55.655: TFTP: Looking for ITLFile.tlv
*Nov 17 17:10:55.655: TFTP: Sending error 1 No such file
*Nov 17 17:10:56.655: TFTP: Server request for port 50504, socket_id 0x3E129A08 for process 427
*Nov 17 17:10:56.655: TFTP: read request from host 10.20.168.11(50504) via GigabitEthernet0/0.20
*Nov 17 17:10:56.655: TFTP: Looking for SEPAC7E8A2B07A4.cnf.xml
*Nov 17 17:10:56.659: TFTP: Opened flash:/its/SEPAC7E8A2B07A4.cnf.xml, fd 5, size 4776 for process 427
*Nov 17 17:10:56.659: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:56.659: TFTP: Received ACK for block 1, socket_id 0x3E129A08
*Nov 17 17:10:56.659: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:56.659: TFTP: Received ACK for block 2, socket_id 0x3E129A08
*Nov 17 17:10:56.659: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:56.659: TFTP: Received ACK for block 3, socket_id 0x3E129A08
*Nov 17 17:10:56.659: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:56.659: TFTP: Received ACK for block 4, socket_id 0x3E129A08
*Nov 17 17:10:56.659: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:56.659: TFTP: Received ACK for block 5, socket_id 0x3E129A08
*Nov 17 17:10:56.659: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:56.663: TFTP: Received ACK for block 6, socket_id 0x3E129A08
*Nov 17 17:10:56.663: TFTP: Sending block 7 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:56.663: TFTP: Received ACK for block 7, socket_id 0x3E129A08
*Nov 17 17:10:56.663: TFTP: Sending block 8 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:56.663: TFTP: Received ACK for block 8, socket_id 0x3E129A08
*Nov 17 17:10:56.663: TFTP: Sending block 9 (retry 0), len 512, socket_id 0x3E129A08
*Nov 17 17:10:56.663: TFTP: Received ACK for block 9, socket_id 0x3E129A08
*Nov 17 17:10:56.663: TFTP: Sending block 10 (retry 0), len 168, socket_id 0x3E129A08
*Nov 17 17:10:56.663: TFTP: Received ACK for block 10, socket_id 0x3E129A08
*Nov 17 17:10:56.663: TFTP: Finished flash:/its/SEPAC7E8A2B07A4.cnf.xml, time 00:00:00 for process 427
*Nov 17 17:10:59.607: TFTP: Server request for port 49605, socket_id 0x3E129A08 for process 427
*Nov 17 17:10:59.607: TFTP: read request from host 10.20.168.11(49605) via GigabitEthernet0/0.20
*Nov 17 17:10:59.607: TFTP: Looking for SIP_English_United_States/sl-be-sip.jar
*Nov 17 17:10:59.607: TFTP: Sending error 1 No such file
*Nov 17 17:11:00.507: TFTP: Server request for port 50923, socket_id 0x3E129A08 for process 427
*Nov 17 17:11:00.507: TFTP: read request from host 10.20.168.11(50923) via GigabitEthernet0/0.20
*Nov 17 17:11:00.507: TFTP: Looking for United_Kingdom/g3-tones.xml
*Nov 17 17:11:00.507: TFTP: Sending error 1 No such file
Jonathan Beardsley CCNA Voice; MCITP Telecom & Network Administrator DECOSIMO
