Dear Expert,
I have configured 8845 phone it join my call manger but giving error
idle application host not found
I need help.
kafi
Hi Kafi,
Increase the idle timer(seconds) to higher value(e.g. 99999) in UDT profile as attached in snap shot 1 and check.
Suresh
Hi Suresh,
I have changed this value but it does not work.
kafi
- Are you trying to use Self-provisioning?
- Is your 8845 IP Phone already registered with CUCM and giving error "host not found" while being idle?
If its registered already and giving that error then go to the device page of the phone > under "External Data Location Settings" > Erase the information with respect to idle and idle timer (seconds) and leave all fields blank.
