8851-3pcc mutes after ignoring an incoming bluetooth call
avezina
Here's a problem I have with the 8851-3pcc. I don't know if you guys can help me with that :
Setup
8851-3pcc paired with an iPhone
Steps to reproduce
- Talk on the phone on a normal extension (ext1) with headset or handset (not speakerphone)
- Receive an incoming call on bluetooth (iPhone)
- Press "ignore" to drop the bluetooth call on the 8851
What happens
- Handset or headset microphone stops working (We can hear something, but the person at the other end can't)
Workaround
- Switch audio device (headset to handset, handset from to headset, headset to speakerphone, etc) : sounds starts working again
- Ignore call on the iPhone instead of on the Cisco 8851
Note that this does not happen when the call is on speakerphone
18 Replies 18
Try contacting from the link I posted. That is a dedicated for SMB and you can raise a case there.
It was not easy, but I finally got a ticket open
I'll let you know how it goes
avezina
Finally got the ticket open. I've been asked by a guy at Cisco to test other phones. Here are the results :
- iPhone 8 Plus: Bluetooth 5.0, A2DP, LE : mutes after ignoring call
- iPhone 6s: Bluetooth 4.2, A2DP, LE : mutes after ignoring call
- LG G4: Bluetooth 4.1, A2DP, LE, aptX : everything works
- Google Pixel : Bluetooth 4.2, A2DP, LE, aptX : mutes after ignoring call
Right now, my feeling is that Bluetooth 4.2 and up is not (or poorly) implemented in the firmware.
I'll let you know if I have news.
FYI, I just got a beta firmware from Cisco. I will let you know how it goes.
Thank you
