04-08-2018 12:46 AM - edited 03-17-2019 12:34 PM
I have modified list.xml with new images and uploaded it with main image and thumbnail image. Phone is taking new image and its working fine.
But i want images to appear only on one phone, where as when i upload list.xml to directory Desktup/800*480*24...images are getting appeared in all 8851 phones.
Can you please suggest, how to get new uploaded images only on one phone.
Faizan.
Solved! Go to Solution.
04-08-2018 08:14 AM
Any 8851 that points to that TFTP will see the images, no way around that, unless you create a dedicated TFTP for only that device.
04-08-2018 01:53 AM
Create new Device profile
Device > Device Sittings >
go down to find background image and type the filename.png. then go to the phone profile and save and apply config.
Cheers
//Moe
04-08-2018 08:14 AM
04-08-2018 10:42 PM
Oh sorry maybe did not get what you need in the beginning. If you want the image not appeared there is no way you can do that. You have one option dont check for user allowance to change background image that way users cannot see it. and set another profile and set the image you need and dont allow user to change it. otherwise, as Jamie said you there is no way around it.
regards,
//Moe
04-08-2018 10:46 PM
