88xx 11.5 new Softkey PopUp Bar not editable
Paul Freiberg
Hi all,
I am testing the new 11.5(1) firmware for 88xx telephones.
With 11.5 a new poping up softkey bar was introduced.
It looks fine, but I do not know how I can edit or disable it.
Chris Deren
You can play with "Simplified New Call UI", and "Actionable Incoming Call Alert" settings on the device for desired behavior.
Chris Deren
Thanks a lot "Actionable Incoming Call Alert" is the parameter which I have to disable to avoid the popping up softkey bar.
