03-05-2020 01:19 PM
Hello All,
I have recently upgraded 88xx phones' firmware version 12.5 to 12.7, and I am noticing a message when speak on call that ' i am a bit louder on the call ' .
may I know if I can remove this message.
03-05-2020 01:37 PM
Per the release notes for 12.7(1):
Users can help keep their phone conversations at an appropriate volume level with the Lower Your Voice alert.
When you speak loudly, a warning message displays on the phone screen. You can lower your voice or select Ignore.
This feature is enabled by default and is located in the phone settings menu if you want to disable it. It does not require any configuration in Cisco Unified Communications Manager.
Lower Your Voice is available for handsets and headsets only.
03-05-2020 01:48 PM
03-05-2020 01:57 PM
To clarify, that bug ID is a Sev 6 Product Enhancement and not a fix to your issue. Here is the bug from a previous Cisco Notification Alert. If you aren't signed up to get these for your specific products and versions I highly recommend that you sign up for them.
Alert Type: | New |
Bug Id: | |
Title: | CP-88xx - Make 'Lower Your Voice Alert' Disabled By Default |
Status: | Open |
Severity: | 6 Enhancement |
Description: | Symptom: |
Last Modified: | 15-Feb-2020 |
Known Affected Releases: | 12.7(1) |
03-10-2020 08:29 AM
I think multiple people need to flood TAC with this annoying "feature", actually bug.
What person decided to put that on the screen.
