8941 custom directory not appearing
carlnewton
Level 3
Level 3
Guys,
On my system I have a custom directory that does a lookup against LDAP.  It is configured as a service under phone services with type "Directories".  It is an enterprise subscription.
This works fine on every single phone except 8941's.  You hit directories, it appears.  You can lookup against LDAP sources.  The 8941 however only shows personal and corporate directories.  The LDAP Directory does not appear.
The only way I can get this service to work on 8941s is to create a new service with type "Standard IP Phone Service" and subscribe the 8941 to it.  It then appears when you press the "Cog" button for settings/services etc, and not under directories.
Does something different need to be done with this phone type?
Rob Huffman
Hi Carl,
I'm not sure what firmware you are running on the 8941's
but I did see this bug;
CSCub72087            Bug Details
Custom Directories not shown when using Load SCCP8941_8945.9-3-1-19.
Symptom:
894x SCCP Phone: 894x 9-3-1-19
Custom directories hosted on external IIS server do not show when directory button is pressed on the phone.
Conditions:
Under Enterprise parameters :-
1)     Services Provisioning set to Both
2)     URL directories points to external web URL
Workaround:
Temporary  work-around would be to use ES load "894x-sccp.9-2-3-ES3-1" , but will  be faced with CSCtz51303, which is fixed in 9-3-1-19.
Status Status
Fixed
Severity Severity
3 - moderate
Last Modified Last Modified
In Last Year
Product Product
Cisco Unified IP Phone 6900 Series
Technology Technology
1st Found-In 1st Found-in
9.3(1)
Fixed-In Fixed-in
9.3(2)
Cheers!
Rob
"Celebration it's around us, every nations, all around us.
Singin' forever young, singin' songs underneath that sun" - K'naan
Rob Huffman
Hi Carl,
Symptom:
Conditions:
Workaround:
Status Status
Fixed
Severity Severity
3 - moderate
In Last Year
Product Product
9.3(1)
Fixed-In Fixed-in
9.3(2)
Cheers!
Rob
Thanks Rob.
Interesting. From the bug report:
1st Found-In
9.3(1)
Fixed-In
9.3(2)
My phones are running 9.2(3) and having this bug.
I just upgraded to 9.3(1)  because its a two stage upgrade to 9.3(2) and it works just fine on 9.3(1), even though thats apparently when they first found the bug!
Cheers for your help!
