IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6409 Views
  • 14 replies
                   Hello,Running CME 8.6 on a 3825.  I have a WAV file as the MOH.  Whenever it is played it sounds "screechy" for lack of a better work, almost like overdrive but I have reduced the volume of the file.  It plays at a lower volume now...
                   Hi Everyone,                   Hope you are doing great!  Would appreciate if someone can assist or suggest method to configure Extension Mobility for all the existing users in CUCM version: (6.1.3) the task is to make sure all uer...
Mavinktul by Level 1
  • 1006 Views
  • 3 replies
We currently have caller ID setup pn our gateway - it shows the main number for all outbound calls. MY COO wants all outbounds calls from our Call Ctr to show the toll-free support number. It would seem that my options are to somehow route all outbou...
rahartmz6 by Level 1
  • 867 Views
  • 4 replies
Hi,Some of the IVR systems does not recognize DTMF tone especially when dialing the DTMF tones very fastly. We use call manager and a cisco voice gateway for sending calls to service provider. Is there a way to change the dtmf frequency timers or wha...
Hey Everyone,I have a client who has a 2811 Voice Gateway with two T1 cards inserted and two PVDM2-16s installed. The 'sh diag' output is attached.Now I know there are no available PVDM slots as the 2811 only has 2. I was wondering if there is a way ...
I am associating groups so that we can implement the group pick up softkey to allow users to pick up someones extension if it is ringing and no one is at that extension. However, I have 13 groups and while associating them I saw that it would only al...
We are on UCCX Enhanced, Application Adminisration 5.0(2) and Unified Callmanager 6.1.2.  When we got the system about 4 years ago all settings were migrated over, or set up by the vendor.We have two teams in UCCX.  One team needed to change supervis...
