8941 problem
pedroferreras
Hi, i'm running callmanager version 8.6.2a (su2), 8941 phone was running fine but suddenly ist shows the following behavior:
When a user is on a call and another call comes in , the first call goes on speaker without user intervention (the user didn't answer the second call).
The firmware version is: SCCP894X.9-2-3-5.
Thank you.
Rob Huffman
Hi Pedro,
It sounds like this bug
CSCty67705 - 8945 calling party goes onto speaker w/2nd call
Symptom:
8945 when receiving second call, first callers voice goes to speaker but no speaker button lit
Conditions:
When  'Ring setting (phone active)' configuration on the line config is set  to 'Use System Default' and Service parameter  'Ring Setting of Busy  Station'  is configured for "RING"
Phone A (any phone) calls Phone B  (8945) Line 1 -> Phone B answers with handset -> Phone C (any  phone) calls Phone B Line 1 -> with no user interaction original  caller (phone A) heard Phone B speaker.  No speaker button lit.
Workaround:
change Service parameter  'Ring Setting of Busy Station'  is configured for "Flash" or "Beep"
Details
First Found in:                          (1)
9.2(3)
Status:
Fixed
Last Modified:
Oct 29,2012
Fixed in:                          (1)
9.3(1)
Product:
Cisco Unified IP Phone 6900 Series
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
Rob Huffman
Hi Pedro,
Symptom:
Conditions:
Workaround:
Details
First Found in:                          (1)
9.2(3)
Status:
Fixed
Last Modified:
Oct 29,2012
Fixed in:                          (1)
9.3(1)
Product:
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
I upgraded to 9-3-2-11 and phones are working fine.
Thank you.
