8941 & URI Dialing
Gordon Ross
Level 9
Level 9
I can't see how to dial a SIP URI on a 8941 with the SIP protocol stack.
The documentation for the 8941 handset says it supports SIP URI dialing in both SIP & SCCP.
Yet I've found BugID CSCuu84243 which kind of suggests that these phones don't support URI dialing :-/
Do the 8941 support URI dialing or not?
GTG
Please rate all helpful posts.
9 Replies 9
Vivek Batra
Not sure, but did you check dialing URI using speed dial button?
- Vivek
I can create a SD button with a URI on it, and that appears to work OK. But I don't get the "ABC" softkey to enter a URI on the phone.
GTG
I doubt if any hardphone supports URI dialing straight away from dialpad. Jabber should be the only option to dial it without needing speed dial buttons.
- Vivek
No, that's wrong, some endpoints like the 9971 do have an ABC softkey to dial URIs, i believe that only the 8961 from those series supports the ABC softkey.
java
if this helps, please rate
JaVa,
Thanks for updating us [+5].
- Vivek
The 9951, 9971 and 8851 all support ABC dialling from the keypad.
GTG
Dennis Mink
I gues when they say
"The documentation for the 8941 handset says it supports SIP URI dialing in both SIP & SCCP.
That doesnt mean you can actually punch URI's in from the phone's keypad. I have found it works flawlessly when dialing URI's from jabber, using CTI deskphone control. (on the 8941's as well)
Let's face it who wants to sit and dial james.bond@mi5.gov.uk  through a keypad?!
Please remember to rate useful posts, by clicking on the stars below.
It's actually not too hard to dial that from a keypad. Entering digits, when in URI dialing mode, however, feels like hard work!
GTG
yeah I hear ya, just having a bit of fun.  I typically just paste the URI into Jabber and with CTI deskphone Control Bob's your uncle.
