8945 and visual voicemail
Hello Everyone,
I am testing out a 8945 with the latest firmware installed.  When I run visual voicemail it reports back to me the following in the logs
00:00:21:22.454 - [XSI][ERR]xsi.viewControllerFactoryMap() unsupported object
00:00:21:22.454 - [XSI][ERR]========================================
00:00:21:22.454 - [XSI][ERR]xsi.viewControllerFactoryMap() return fail  object:
00:00:21:22.456 - [XSI][ERR]MIDlet-Jar-Size:345578
MIDlet-1:VisualVoicemail,,com.cisco.vtg.midlet.voicemail.VisualVMMidlet
MIDlet-Jar-URL:/midlets/TNP/VisualVoicemail.jar
MIDlet-Jar-RSA-SHA1:J4XIunVcSz7kyUntiddozKyVhZc8EA7Yi+a/vpzQGVAXZIx+CAtFD
00:00:21:22.456 - [XSI][ERR]========================================
On the phone simply "Unsupported XML Object
visual voicemail is working fine on the 79xx and 99xx phones that we have here.  So this begs the question, is visual voicemail supported on the89xx phones?
cucm 8.6
1 pub
3 subs
UC 8.6
1 sub
1 pub
firmware
SCCP8941_8945.9-3-2-11
thank you
Hi.
Maybe too late to answer you, but the issue was in the service name.
Make sure that you enter VisualVoicemail as service name without spaces.
That did the trick for me
Carlo
Please rate all helpful posts "The more you help the more you learn"
5 Replies 5
will.alvord
Level 5
Level 5
Nope.  No visual voicemail on the 89xx phones.
Hi Will,
I know this post s a little old, but Load 9.3(4) of the 89xx seems to bee supported with Visual Voicemail.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8941_8945/firmware/9_3_4/english/release_notes/P415_BK_R20BE6A8_00_rn-9_3_4-8941-8945/P415_BK_R20BE6A8_00_rn-9_3_4-8941-8945_chapter_00.html
However I seem to be running into the issue you are when setting up a Service URL on the phone.
If I use the default Voicemail button, and select the option of Visual Voicemail, everything works well.
But as I mentioned, setting up a Service URL creates an Unsupported XML object.
Has anyone seen this, or found a resolution?
If the user receives incorrect pin error message from day one then it might be also the case?
I would give a try by modifying the url.
Let me know
Carlo
Hi.
Carlo
