Cannot add Cisco 8865 to CUCM 10.5.2
John Ruhl
Hi, we are running CUCM version 10.5.2 and are trying to add an 8865.  I have installed the lasted version of the .cop file (cmterm-8845_65-sip.11-0-1-11.k3.cop.sgn) in the Publisher and all the Subscribers.  I restarted the TFTP service on all of the servers as well, but when I try to add the device I am unable to select the phone type.
What am I missing?
3 Accepted Solutions
Hi ,
you need to download latest device pack for cucm 10.5 http://software.cisco.com/download/release.html?i=!y&mdfid=285963825&softwareid=282074299&release=10.5(2.12025)&os=
You need to install it on all server in the cluster and reboot
Carlo
Please rate all helpful posts "The more you help the more you learn"
Manish Gogna
Hi John,
I agree with Carlo [+5], for enabling new device types on cucm you need to install the device pack as suggested on all the servers followed by a clusterwide reboot. TFTP service restart is generally needed when we are doing a normal firmware version upgrade by installing the individual firmware file or device pack.
Manish
Hi ,
Carlo
Nadeem Ahmed
You can install the device pack 10.5(2.13042) with no issues. It is the latest device pack and can be installed on your call manager version.
https://software.cisco.com/download/release.html?i=!y&mdfid=285963825&softwareid=282074299
&release=10.5(2.13029)&os=
Cisco Unified Communications Manager 10.5(2.13042) Device Package - Compatible UCM Version: 10.5
cmterm-devicepack10.5.2.13042-1.cop.sgn
Note: you have to reboot the cluster after you install the device pack.
Br,
Nadeem Ahmed
PS: Please rate all useful post.
Br, Nadeem Please rate all useful post.
Manish Gogna
Hi John,
Manish
Jaime Valencia
