90 and 9011T Dial peer overlay
chandramauliks
IOS 15.1(4)M5
I have a H323/SIP voice gateway at remote site communicating with SME 8.6. The gateway is integrated with PBX which are very old so i have done integration with FXS [inbound from PBX] and FXO [calls to PBX]
I have the following dial peers for outbound calls pointed to the SME 8.6 CUCM.
91[2-9].........$ - Long distance
9011T - International long distance
90$ - Operator
From PBX if the user dials the international pattern 9011! towards the cisco router, the operator destination pattern is matched immediately and sent to call manager. When i disable the operator destination pattern the international calls work.
Note: PBX is very old and cant send digits to router as enbloc through FXS. Anything to do with FXS port interdigit timeout or other timing
I tried incoming called number 90 in the outbound dial peer to cucm still no good, i dont want to do a generic 9T as single outbound dial peer to CUCM. Any help in this regard will be helpful
Chris Deren
Have you tried changing operator destination pattern to 90 instead of 90$?
Also make sure the intl dial peer is above the operator.
Chris
I tried 9. also 90 still no good, the operator pattern only takes precedence over 9011T.
Chandramauli
