911 Call Issue
Thomas Yarger
All,
I have four POTS lines that connect into a router at one of my remote locations. When a 911 call is placed, the POTS lines are the preferred path to take. Is there a command on the router that I can execute that will show me the recent calls that traversed the POTS lines within a given time period with time stamps? A call history if you will. Thanks.
garethpeart
Level 3
Level 3
There's a "show call history voice" that will do what you want, but you'll probably want to change the retention time from the default with "dial-control-mib retain-timer 10080".
Gareth
garethpeart
Level 3
Level 3
Gareth
Thanks Gareth. That is exactly what I'm looking for. Best.
Last minute thought. What is the impact on storage with setting the retain-time to 10080 minutes? I did notice there is a max entries setting.
Chris Deren
Your best bet would be to setup syslog and write things to it.
