Unity Connection help needed. Dial Rule for non voicemail extensions?
Jon Clark1
Community,
Is there a quick way (Other than creating a call handler for each extension) to get Unity to route calls to non voicemail extensions from a main greeting CH?
6513
6514
6515
6516
6517
6518
6519
6520
6521
That's different from what you posted
That checkbox will allow you to dial the DN and be transferred to it, assuming your transfer rules and CSS allows that.
java
if this helps, please rate
5 Replies 5
Jaime Valencia
No, CUC does not allow you to configure wildcards, you would need to configure one CH per DN to do that.
java
Jaime check out...
http://www.cla5h.com/unity-connection-8-6-call-transfer-to-non-unity-extension.html
One check box worked.  Had customer test successfully.
java
Thanks Jaime.  Guess I worded it wrong. Oh well happy customer and learned something. Thanks again.
Jon Clark1
Found the answer in google land.
"In the greeting check this box:
Allow Transfers to Numbers Not Associated with Users or Call Handlers"
