10-13-2017 05:34 AM - edited 03-17-2019 11:22 AM
Hi All,
I been asked to configure 911 in Russia, Moscow. But the call is failing. Please find the below logs.
My question is :
Will 911 work in Moscow, Russia?
Why is the call is automatically trying with Called Party Number i = 0x80, '11' stripping 9 ?
Can someone help me on this. Thanks !
rOCWRUmoc001#
rOCWRUmoc001#
rOCWRUmoc001#
051413: Oct 13 11:58:53.917 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 84957870477
051414: Oct 13 11:58:53.917 UTC: ISDN Se0/1/0:15 Q931: Sending SETUP callref = 0x050C callID = 0x848D switch = primary-net5 interface = User
051415: Oct 13 11:58:53.917 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x050C
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x2181, 'XXXXXXXXXXX'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '911'
Plan:Unknown, Type:Unknown
051416: Oct 13 11:58:53.995 UTC: ISDN Se0/1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x850C
051417: Oct 13 11:58:54.015 UTC: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x850C
Cause i = 0x828100000000 - Unallocated/unassigned number
051418: Oct 13 11:58:54.015 UTC: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x050C
051419: Oct 13 11:58:54.074 UTC: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x850C
051420: Oct 13 11:58:54.077 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num XXXXXXXXXXX
051421: Oct 13 11:58:54.077 UTC: ISDN Se0/1/0:15 Q931: Sending SETUP callref = 0x050D callID = 0x848E switch = primary-net5 interface = User
051422: Oct 13 11:58:54.077 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x050D
Standard = CCITT
Progress Ind i = 0x8183 - Origination address is non-ISDN
rOCWRUmoc001#
051423: Oct 13 11:58:54.156 UTC: ISDN Se0/1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x850D
rOCWRUmoc001#
051424: Oct 13 11:58:55.589 UTC: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x050D
Cause i = 0x8090 - Normal call clearing
051425: Oct 13 11:58:55.651 UTC: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x850D
051426: Oct 13 11:58:55.652 UTC: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x050D
rOCWRUmoc001#
rOCWRUmoc001#
rOCWRUmoc001#
rOCWRUmoc001#
rOCWRUmoc001#
rOCWRUmo
911 Config :
dial-peer voice 911 pots
description Emergency H323-SRST POTS dial-peer
translation-profile outgoing OUTPSTN
preference 1
destination-pattern 911
port 0/1/0:15
forward-digits all
dial-peer voice 9911 pots
preference 1
destination-pattern 9911
port 0/1/0:15
forward-digits 3
10-13-2017 06:15 AM
In Russia the police isn't 911, but 102.
You can see the full dial plan according to Wikipedia:
https://en.wikipedia.org/wiki/Telephone_numbers_in_Russia
The emergency services in Russia are: 10X. (100-104)
10-20-2017 02:11 AM
10-20-2017 05:48 AM
If you are positive this should be allowed you need to contact the telco provider as currently getting "Cause i = 0x828100000000 - Unallocated/unassigned number" means the dialed number in not valid.
