12-10-2013 08:47 AM - edited 03-16-2019 08:48 PM
All of a sudden a few phones are now seeming to have reset issues when connected to our development call manager 10.0.1
A few people have access to mess around with this but so far all that I have asked have told me they have changed "nothing" but I take this with a pinch of salt!
If I connect the phone I am testing with 9951, to another CM, although it doesn't reset every 20 seconds it still shows upgrade failed.
Registration | Registered with Cisco Unified Communications Manager MultiCluster03 |
IP Address | 172.21.233.42 |
Active Load ID | sip9951.9-0-0FCE1-5dev |
Inactive Load ID | sip9951.9-0-0FCA5-4dev |
Download Status | Failed |
Requested Load ID | sip9951.9-2-4-19 |
Download Server | 0.0.0.0 |
Inactive Load Failure Reason | Internal Phone Error |
the above is when connected to an 8.6.2 call manager and as you can see, the active and inactive loads are all older than the requested as I know trying to downgrade can sometimes be an issue. I'm not sure if it's related but unfortunately I cannot browse to the phones IP to view the console logs which is pretty irritating.
Has anyone seen this and have any idea's on how to troubleshoot this further?
12-10-2013 12:10 PM
Try clearing the ITL file under Admin Settings > Security. The phone should reboot, download a new ITL from the dev cluster. Also run 'show itl' (going from memory but that's close) to verify the ITL is intact on the cluster.
Please remember to rate helpful responses and identify helpful or correct answers.
12-11-2013 03:02 AM
I reset all settings yesterday which I believe clears ITL, If I do look in Security on the phone it doesnt show any ITL at all, the command is spot on and the cluster does show as having an ITL file.
