9951 in CME drop calls after 20 seconds.
era_cisco
Situation:
Six 9971 phones + 7925 registered in CME 9.0.
SIP Trunk to TSP.
7925 working great, 9971 drop calls after 20 sec, no matter internal calls or external to TSP.
When HOLD key pressed call droped immediately.
Already tried to change CME version (8.5, 8.6, 9.0) and phone firmware. No result.
Any ideas?
Many thanks for any soluton.
See config down below:
version 15.2
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname c2901.lawer
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone MSK 4 0
no ipv6 cef
ip dhcp excluded-address 192.168.99.1 192.168.99.10
ip dhcp excluded-address 192.168.99.200 192.168.99.254
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.1.200 192.168.1.254
ip dhcp excluded-address 10.192.0.1 10.192.0.10
ip dhcp excluded-address 10.192.0.200 10.192.0.254
ip dhcp excluded-address 172.16.30.1 172.16.30.10
ip dhcp excluded-address 172.16.30.200 172.16.30.254
ip dhcp pool MAN
network 192.168.99.0 255.255.255.0
default-router 192.168.99.254
dns-server 192.168.1.233
option 150 ip 172.16.31.254
domain-name local
lease 3
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.250
domain-name local
lease 3
ip dhcp pool IPTEL
network 10.192.0.0 255.255.255.0
default-router 10.192.0.250
domain-name local
lease 3
ip dhcp pool GUEST
network 172.16.30.0 255.255.255.0
default-router 172.16.30.250
domain-name local
lease 3
ip domain name
ip cef
login block-for 300 attempts 5 within 30
login on-failure log
voice-card 0
dspfarm
dsp services dspfarm
voice call disc-pi-off
voice service voip
ip address trusted list
  ipv4 192.168.1.0 255.255.255.0
  ipv4 192.168.99.0 255.255.255.0
  ipv4 10.192.0.0 255.255.255.0
  ipv4 172.16.31.254 255.255.255.255
  ipv4 89.207.94.24 255.255.255.255
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
sip
  registrar server
  midcall-signaling passthru
voice class custom-cptone MEETME
dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice class custom-cptone MEETLEAVE
dualtone conference
  frequency 400 700
  cadence 150 75 150 50 150 50
voice register global
mode cme
source-address 172.16.31.254 port 5060
max-dn 200
max-pool 42
load 9971 sip9971.9-2-2SR1-9
authenticate presence
authenticate register
authenticate realm local
timezone 34
time-format 24
date-format D/M/Y
no dst auto-adjust
tftp-path flash:
file text
create profile sync 0004260925933938
ntp-server 172.16.31.254 mode unicast
voice register dn  1
number 101
call-forward b2bua busy 102
call-forward b2bua noan 102 timeout 12
allow watch
pickup-group 1
name Streltsova Olga
shared-line max-calls 6
no-reg
label 101@StreltsovaO
voice register dn  3
number 103
allow watch
pickup-group 1
name Loboda K.K.
no-reg
label 103@LobodaKK
voice register dn  4
number 104
allow watch
pickup-group 1
name Yudin S.A.
no-reg
label 104@YudinSA
voice register dn  5
number 105
allow watch
pickup-group 1
name Savenko S.F.
no-reg
label 105@SavenkoSF
voice register dn  6
number 106
allow watch
pickup-group 1
no-reg
voice register dn  7
number 107
allow watch
pickup-group 1
no-reg
voice register template  1
softkeys hold  Newcall Resume iDivert
softkeys idle  Newcall Redial DND Cfwdall Pickup Gpickup
softkeys ringIn  Answer DND iDivert
softkeys seized  Endcall Cfwdall Redial Pickup Gpickup
softkeys connected  Endcall Confrn Hold Park Trnsfer iDivert
softkeys remote-in-use  Newcall Barge cBarge
voice register pool  1
id mac 0008.308B.F1FA
session-transport tcp
type 9971
number 1 dn 1
template 1
presence call-list
username 101 password 101
codec g711ulaw
no vad
blf-speed-dial 1 103 label "Loboda@103"
blf-speed-dial 2 104 label "Yudin@104"
blf-speed-dial 3 105 label "Savenko@105"
blf-speed-dial 4 106 label "106"
blf-speed-dial 5 107 label "107"
voice register pool  3
id mac 68BC.0C80.1A85
type 9971
number 1 dn 3
template 1
presence call-list
username 103 password 103
codec g711ulaw
no vad
blf-speed-dial 1 101 label "Streltsova@101"
voice register pool  4
id mac C8F9.F968.CF56
type 9971
number 1 dn 4
template 1
presence call-list
username 104 password 104
codec g711ulaw
no vad
blf-speed-dial 2 101 label "Streltsova@101"
voice register pool  5
id mac D824.BDBA.084F
type 9971
number 1 dn 5
template 1
presence call-list
username 105 password 105
codec g711ulaw
no vad
blf-speed-dial 3 105 label "Streltsova@101"
voice register pool  6
id mac 68BC.0C80.1C9E
type 9971
number 1 dn 6
template 1
presence call-list
username 106 password 106
codec g711ulaw
no vad
blf-speed-dial 4 101 label "Streltsova@101"
voice register pool  7
id mac E8BA.7006.407B
type 9971
number 1 dn 7
template 1
presence call-list
username 107 password 107
codec g711ulaw
no vad
blf-speed-dial 5 101 label "Streltsova@101"
voice translation-rule 1
rule 1 /7302337/ /101/
rule 2 /7302338/ /102/
voice translation-rule 2
rule 1 /^9\(.*\)/ /\1/
voice translation-rule 3
rule 1 /^90\(.*\)/ /0\1/
voice translation-rule 4
rule 1 /9100/ /8495100/
voice translation-rule 5
rule 1 /^9\(.*\)/ /8495\1/
voice translation-profile 100
translate called 4
voice translation-profile 911
translate called 3
voice translation-profile CALLED
translate called 1
voice translation-profile CITY
translate called 5
voice translation-profile SIP
translate called 2
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
ip ssh version 2
interface Loopback0
ip address 172.16.31.254 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.99.254 255.255.255.0
interface GigabitEthernet0/0.2
encapsulation dot1Q 2
ip address 192.168.1.250 255.255.255.0
interface GigabitEthernet0/0.3
encapsulation dot1Q 3
ip address 10.192.0.250 255.255.255.0
interface GigabitEthernet0/0.4
encapsulation dot1Q 4
ip address 172.16.30.250 255.255.255.0
ip access-group GUEST in
interface GigabitEthernet0/1
ip address 89.207.91.6 255.255.255.0
ip access-group INBOUND in
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.233
ip route 89.207.94.24 255.255.255.255 89.207.91.1
ip route 89.207.94.25 255.255.255.255 89.207.91.1
ip access-list extended GUEST
permit ip 172.16.30.0 0.0.0.255 host 192.168.1.233
deny   ip 172.16.30.0 0.0.0.255 10.0.0.0 0.255.255.255
deny   ip 172.16.30.0 0.0.0.255 172.16.0.0 0.15.255.255
deny   ip 172.16.30.0 0.0.0.255 192.168.0.0 0.0.255.255
permit ip 172.16.30.0 0.0.0.255 any
ip access-list extended INBOUND
permit ip host 89.207.94.24 host 89.207.91.6
permit ip host 89.207.94.25 host 89.207.91.6
deny   ip any any log
tftp-server flash:APPSH-1.4.1SR1.SBN
tftp-server flash:CP7925G-1.4.1SR1.LOADS
tftp-server flash:GUIH-1.4.1SR1.SBN
tftp-server flash:JSYSH-1.4.1SR1.SBN
tftp-server flash:JUIH-1.4.1SR1.SBN
tftp-server flash:SYSH-1.4.1SR1.SBN
tftp-server flash:TNUXH-1.4.1SR1.SBN
tftp-server flash:TNUXRH-1.4.1SR1.SBN
tftp-server flash:WLANH-1.4.1SR1.SBN
tftp-server flash:dkern9971.100609R2-9-2-2SR1-9.sebn
tftp-server flash:kern9971.9-2-2SR1-9.sebn
tftp-server flash:rootfs9971.9-2-2SR1-9.sebn
tftp-server flash:sboot9971.031610R1-9-2-2SR1-9.sebn
tftp-server flash:sip9971.9-2-2SR1-9.loads
tftp-server flash:skern9971.022809R2-9-2-2SR1-9.sebn
tftp-server flash:Analog1.raw
tftp-server flash:Analog2.raw
tftp-server flash:AreYouThere.raw
tftp-server flash:AreYouThereF.raw
tftp-server flash:Bass.raw
tftp-server flash:CallBack.raw
tftp-server flash:Chime.raw
tftp-server flash:Classic1.raw
tftp-server flash:Classic2.raw
tftp-server flash:ClockShop.raw
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:Drums1.raw
tftp-server flash:Drums2.raw
tftp-server flash:FilmScore.raw
tftp-server flash:HarpSynth.raw
tftp-server flash:Jamaica.raw
tftp-server flash:KotoEffect.raw
tftp-server flash:MusicBox.raw
tftp-server flash:Piano1.raw
tftp-server flash:Piano2.raw
tftp-server flash:Pop.raw
tftp-server flash:Pulse1.raw
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:Ring4.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:RingList.xml
tftp-server flash:Sax1.raw
tftp-server flash:Sax2.raw
tftp-server flash:Vibe.raw
tftp-server flash:dkern9971.100609R2-9-2-4-19.sebn
tftp-server flash:kern9971.9-2-4-19.sebn
tftp-server flash:rootfs9971.9-2-4-19.sebn
tftp-server flash:sboot9971.031610R1-9-2-4-19.sebn
tftp-server flash:sip9971.9-2-4-19.loads
tftp-server flash:skern9971.022809R2-9-2-4-19.sebn
tftp-server flash:dkern9971.100609R2-9-1-1SR1.sebn
tftp-server flash:kern9971.9-1-1SR1.sebn
tftp-server flash:rootfs9971.9-1-1SR1.sebn
tftp-server flash:sboot9971.031610R1-9-1-1SR1.sebn
tftp-server flash:skern9971.022809R2-9-1-1SR1.sebn
tftp-server flash:sip9971.9-1-1SR1.loads
control-plane
mgcp profile default
sccp local Loopback0
sccp ccm 172.16.31.254 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface Loopback0
associate ccm 1 priority 1
associate profile 1 register confdsp1
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
maximum sessions 2
conference-join custom-cptone MEETME
conference-leave custom-cptone MEETLEAVE
associate application SCCP
dial-peer voice 501 voip
tone ringback alert-no-PI
description 911
translation-profile outgoing 911
preference 1
destination-pattern 90.
session protocol sipv2
session target ipv4:89.207.94.24
dtmf-relay rtp-nte
codec g711ulaw
clid network-number 4957302337
no vad
dial-peer voice 502 voip
description TIME
translation-profile outgoing 100
preference 1
destination-pattern 9100
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 503 voip
description CITY
translation-profile outgoing CITY
preference 9
destination-pattern 9[12345679]......
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 504 voip
description 499
translation-profile outgoing SIP
preference 1
destination-pattern 98499.......
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 505 voip
description MOB
preference 9
destination-pattern 989.........
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 506 voip
description RUS
preference 9
destination-pattern 98[23456780].........
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 507 voip
description INT
preference 9
destination-pattern 9810T
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 599 voip
description SIP Incoming
translation-profile incoming CALLED
preference 1
session transport udp
incoming called-number .T
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 508 voip
description 495
preference 1
destination-pattern 98495.......
dtmf-relay rtp-nte
codec g711ulaw
no vad
presence
presence call-list
watcher all
allow subscribe
gateway
timer receive-rtp 1200
sip-ua
credentials username advokat7302337 password 7 realm cgp.cittel.ru
authentication username advokat7302337 password 7
timers expires 1800000
registrar ipv4:89.207.94.24 expires 3600
sip-server ipv4:89.207.94.24
presence enable
gatekeeper
shutdown
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 1
sdspfarm tag 1 confdsp1
conference hardware
video
  maximum bit-rate 1024
authentication credential
xml user axluser password 15
pin 0000
fxo hook-flash
max-ephones 42
max-dn 200
ip source-address 172.16.31.254 port 2000
max-redirect 20
no caller-id name-only
service phone videoCapability 1
timeouts interdigit 5
timeouts transfer-recall 40
system message 9-City, 98-Mobile & Domestic
url services http://xmlphones.appspot.com/windows-1251/city/27612
cnf-file location flash:
load 7925 CP7925G-1.4.1SR1
time-zone 34
time-format 24
date-format dd-mm-yy
max-conferences 16 gain -6
call-forward pattern .T
moh "music-on-hold.au"
multicast moh 239.10.16.4 port 2124 route 10.192.0.250
web admin system name admin secret
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
trunk optimization pre-connect
log table retain-timer 500
log table max-size 1000
secondary-dialtone 9
directory entry 1 190 name Conference
fac standard
create cnf-files version-stamp 7960 May 16 2012 21:03:32
ephone-template  1
softkeys remote-in-use  Newcall CBarge
softkeys hold  Resume Newcall Join Select
softkeys idle  Newcall Redial Gpickup Pickup Dnd HLog Cfwdall ConfList Join Login Mobility
softkeys seized  Redial Gpickup Pickup Callback Endcall Cfwdall HLog Meetme
softkeys alerting  Callback Endcall Acct
softkeys connected  Endcall Hold Trnsfer Park Confrn ConfList Acct Flash HLog Join LiveRcd Mobility RmLstC Select
softkeys ringing  Answer Dnd HLog
keep-conference drop-last
max-calls-per-button 2
busy-trigger-per-button 1
paging-dn 71
ssh userid admin password admin
ephone-dn  1  dual-line
ring internal primary
number 102 no-reg both
pickup-call any-group
pickup-group 1
label Streltsova@102
description Streltsova@102
mobility
allow watch
huntstop channel
hold-alert 60 originator
night-service bell
ephone-hunt login
ephone-dn  71
number 199 no-reg both
name Broadcast Message
paging
ephone-dn  72
number 198 no-reg both
park-slot
name Parkslot@198
ephone-dn  73
number 197 no-reg both
park-slot
name Parkslot@197
ephone-dn  74
number 196 no-reg both
park-slot
name Parkslot@196
ephone-dn  75
number 195 no-reg both
park-slot
name Parkslot@195
ephone-dn  76  dual-line
number 190 no-reg both
name ConfRoom1
conference meetme
preference 8
no huntstop
ephone-dn  77  dual-line
name ConfRoom1
conference meetme
preference 7
no huntstop
ephone-dn  78  dual-line
name ConfRoom1
conference meetme
preference 6
no huntstop
ephone-dn  79  dual-line
name ConfRoom1
conference meetme
preference 5
no huntstop
ephone-dn  80  dual-line
name ConfRoom1
conference meetme
preference 4
no huntstop
ephone-dn  81  dual-line
name ConfRoom1
conference meetme
preference 3
no huntstop
ephone-dn  82  dual-line
name ConfRoom1
conference meetme
preference 2
no huntstop
ephone-dn  83  dual-line
name ConfRoom1
conference meetme
preference 1
no huntstop
ephone-dn  92  dual-line
number 191 no-reg both
name AdHoc Conf1
conference ad-hoc
preference 8
ephone-dn  93  dual-line
name AdHoc Conf1
conference ad-hoc
preference 7
no huntstop
ephone-dn  94  dual-line
name AdHoc Conf1
conference ad-hoc
preference 6
no huntstop
ephone-dn  95  dual-line
name AdHoc Conf1
conference ad-hoc
preference 5
no huntstop
ephone-dn  96  dual-line
name AdHoc Conf1
conference ad-hoc
preference 4
no huntstop
ephone-dn  97  dual-line
name AdHoc Conf1
conference ad-hoc
preference 3
no huntstop
ephone-dn  98  dual-line
name AdHoc Conf1
conference ad-hoc
preference 2
no huntstop
ephone-dn  99  dual-line
name AdHoc Conf1
conference ad-hoc
preference 1
no huntstop
ephone  1
mac-address 44D3.CA7B.17DB
ephone-template 1
max-calls-per-button 4
presence call-list
type 7925
button  1:1
night-service bell
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
scheduler allocate 20000 1000
ntp master 2
end
6 Replies 6
oliverpowell
Did you resolve the issues you are having with the 9971s?
We have recenrtly deployed the 9971s over a wireless LAN and are having similar with CME 8.6.
Also having issues like transfer, hold/resume with the SIP phones.
Oli
Just noticed I have the same problem.
A 9951 calling a 9971 call drops after 20 seconds.
A 9971 calling a 9951 is ok.
How are you ? My Be you Do not know me ? but from my search to solve my problem , i see that you face the same ??!! So Kindly could you help me please ? My Problem is as the following :
1-  When I make call from 9951 IP Phone Call for any Other IP Phone Like 7975 , 6921 , 8945 Call still 18 sec then droped
2-   When I make call from any Other IP Phone like 7975 call still opened and not droped
3-  When i make a regular call for Example Mobile number call again still 18 sec then  droped
Note : IOS V 15.2<4> M3
CME V 9.1
and Below is my Config ::
Router#
Router#show run
Building configuration...
Current configuration : 5764 bytes
version 15.2
hostname Router
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.152-4.M3.bin
boot-end-marker
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
no aaa new-model
ip cef
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp excluded-address 192.168.10.200 192.168.10.254
ip dhcp excluded-address 10.1.1.200 10.1.1.254
ip dhcp excluded-address 10.1.1.2 10.1.1.10
ip dhcp pool Voice
network 10.1.1.0 255.255.255.0
option 150 ip 10.1.1.1
dns-server 192.168.1.1 4.2.2.2
domain-name lastvision-sa.com
default-router 10.1.1.1
ip dhcp pool Data
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
no ipv6 cef
voice-card 0
voice-service dsp-reservation 50
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  no rtp send-recv
  registrar server expires max 600 min 60
  asymmetric payload full
voice class media 1
media flow-around
media monitor video
voice class codec 1
codec preference 1 g711ulaw
video codec h264
no fac refer
mode cme
source-address 10.1.1.1 port 5060
bandwidth video tias-modifier 5120000 negotiate end-to-end
timeouts interdigit 2
max-dn 60
max-pool 58
load 9951 sip9951.9-4-1-9.loads
timezone 30
time-format 24
mwi stutter
mwi reg-e164
tftp-path flash:
file text
create profile sync 0001004449345629
voice register dn  1
number 2003
allow watch
pickup-group 6
name 9951
label 9951
voice register dn  2
number 2001
call-forward b2bua busy 8000
call-forward b2bua noan 8000 timeout 10
pickup-group 7
name 8945
label 8945
mwi
id mac C40A.CB4D.0568
type 9951
number 1 dn 1
dtmf-relay sip-notify
username 2003 password 2003
codec g711ulaw
paging-dn 11
camera
video
no keep-conference
busy-trigger-per-button 2
id mac 8478.ACEC.F585
type 8945
username 2001 password 2001
codec g711ulaw
no keep-conference
license udi pid CISCO2921/K9 sn FGL1636126X
license accept end user agreement
hw-module pvdm 0/0
redundancy
no ip address
shutdown
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/1.100
encapsulation dot1Q 100
ip address 10.1.1.1 255.255.255.0
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
no ip http server
ip route 0.0.0.0 0.0.0.0 192.168.1.254
tftp-server flash:dkern9951.100609R2-9-4-1-9.sebn
tftp-server flash:kern9951.9-4-1-9.sebn
tftp-server flash:rootfs9951.9-4-1-9.sebn
tftp-server flash:sboot9951.031610R1-9-4-1-9.sebn
tftp-server flash:sip9951.9-4-1-9.loads
tftp-server flash:skern9951.022809R2-9-4-1-9.sebn
control-plane
sccp local GigabitEthernet0/1.100
sccp ccm 10.1.1.1 identifier 1 version 7.0
sccp
sccp ccm group 2
associate profile 2 register videoconf
sccp ccm group 1
associate ccm 1 priority 2
associate profile 1 register meetmeconf001
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 1
shutdown
dspfarm profile 2 conference video homogeneous
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec h264 vga frame-rate 30 bitrate 1mbps
shutdown
sip-ua
mwi-server ipv4:10.1.1.1 expires 3600 port 5060 transport udp
presence enable
gatekeeper
shutdown
telephony-service
sdspfarm conference lecture-mode on 123 release 321
sdspfarm units 1
sdspfarm tag 1 meetmeconf001
conference hardware
max-ephones 25
max-dn 60
ip source-address 10.1.1.1 port 2000
no service directed-pickup
timeouts night-service-bell 10
system message SOFTBANK BB Corp.
cnf-file perphone
time-format 24
max-conferences 8 gain -6
multicast moh 239.0.0.1 port 2000
web admin system name cisco password cisco
dn-webedit
time-webedit
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  1
softkeys idle  Newcall Gpickup Cfwdall Pickup Redial
softkeys seized  Meetme Redial Gpickup Endcall
softkeys connected  Hold Endcall Confrn Trnsfer Park
number 2004
pickup-group 4
label 8945
name 8945
mwi sip
night-service bell
ephone  1
no multicast-moh
video-codec h264
video
mac-address 8478.ACEC.F585
ephone-template 1
type 8945
button  1:1
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
login
transport input all
end
Router#
Router#
oliverpowell
Apologies, its CCME version 8.6
Oli
Configure bind commands on voice service voip.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Bind you sip source traffic to the voice vlan under the voice service voip.
Rate if it helps
Ajay
