9951 Phone Registering Issue in CME 8.5
jilfersalam
HI Guys,
I have tried to register 9951 in in CME 8.5, and the phones are unregistered. here is the configuration snippet.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 nse version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
sip
  registrar server expires max 3600 min 120
voice register global
mode cme
source-address 10.1.1.170 port 5060
max-dn 40
max-pool 42
load 9951 sip9951.9-1-1SR1<<<i have also given .loads and tried>>>>
tftf-path flash:
timezone 31
create profile sync 020131905538081A
voice register dn  1
number 8002
pickup-group 40
name User1
shared-line max-calls 6
label user1
voice register pool  1
id mac 1CAA.07E2.C2DE
type 9951
number 1 dn 1
cor incoming INTERNATIONAL default
presence call-list
dtmf-relay rtp-nte
no vad
tftp-server flash:dkern9951.100609R2-9-1-1SR1.sebn
tftp-server flash:kern9951.9-1-1SR1.sebn
tftp-server flash:rootfs9951.9-1-1SR1.sebn
tftp-server flash:sboot9951.031610R1-9-1-1SR1.sebn
tftp-server flash:skern9951.022809R2-9-1-1SR1.sebn
tftp-server flash:sip9951.9-1-1SR1.loads
When i am Giving the command tftp-path flash:
i get the following error
CME(config-register-global)#tftp-path flash:
%Error deleting flash:/SIPDefault.cnf (File not found)
%Error deleting flash:/syncinfo.xml (File not found)
%Error deleting flash:/softkeyDefault.xml (File not found)
%Error deleting flash:/softkeyDefault_kpml.xml (File not found)
%Error deleting flash:/featurePolicyDefault.xml (File not found)
%Error deleting flash:/SEP1CAA07E2C2DE.cnf.xml (File not found)
These files though i can see in the flash
I am also attaching the show voice register global command. Any ideas why the phones are not registering
hi,
you need the command 'authenticate register' under voice register global
and username 8002 pass cisco under pool
hi,
