11-14-2012 04:06 AM - edited 03-16-2019 02:10 PM
I have two endpoints.
One of them here in Mozambique, another one on Brazil.
MOZAMBIQUE - - - - - - - - - - - - - - - - - - - BRAZIL
I have CISCO IP PHONES: 6921, 7962, 7942
They can sucessfully make a VoIP call, for that, on this call route:
- MOZAMBIQUE TO BRAZIL: The dialer must first dial the acronym 12 and after this the extension number
- BRAZIL TO MOZAMBIQUE: The dialer must first dial another acronym and after this the extension number
But, from the 9971 I just cant do this VoIP.
What I can do is make internal VoIP calls (no need to add at first the acronym)
Here are some parts of the configs, I dont know if they help.
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
codec preference 5 g723r63
voice translation-rule 1
rule 1 /^9\(....\)/ /\1/
voice translation-rule 3
rule 1 /^124/ /4/
voice translation-rule 4
rule 1 /^128/ /8/
voice translation-rule 6
rule 1 /^12\(....\)/ /\1/
dspfarm profile 10 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 9
associate application SCCP
shutdown
dspfarm profile 20 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
shutdown
Any help on this??
Edson Vuma
11-14-2012 04:08 AM
First of all the dspfarm is in shutdown.. Change this to no shut...
Included the MTP on DSPfarm and try again.
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 9
shutdown
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
shutdown
Best regards,
Daniel
11-14-2012 04:14 AM
Hi, thanks for the reply.
How do I include the MTP?
Would you show me how would be the command?
Edson Vuma
11-14-2012 04:31 AM
Could you please give us more details:
what you mean by can not do VoIP calls? is it ringing? No RTP?
How many phones form 9971 you have?
what are you using CUCM or CUCME?
What is the call flow?
11-14-2012 04:35 AM
1. The call drop before calling...
2. Here I have 2 9971 phones, I have tested here on my environment and they work, they even can make intarnal calls, but I cant make these calls to Brazil.
All SCCP phones, the call flow works, but for this one which uses SIP dont.
Im using CUCME 8.6
Edson Vuma
11-14-2012 04:41 AM
Did you add CUBE Configuration
Voice service voip
no ip address trusted authenticate
al h to h
al h to s
al s to h
al s to s
11-14-2012 04:43 AM
Yes I added.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
Edson Vuma
11-14-2012 04:46 AM
what about:
if you can attach
debug voip ccapi inout
11-14-2012 04:34 AM
Something like this:
sccp local GigabitEthernet0/0.230 |
sccp ccm 10.10.10.2 identifier 2 priority 2 version 7.0 |
sccp ccm 10.10.10.1 identifier 1 priority 1 version 7.0 |
sccp |
sccp ccm group 10 |
description -------[ccm-group-10] bind interface GigabitEthernet0/0.230 |
associate ccm 1 priority 1 |
associate ccm 2 priority 2 |
associate profile 1 register CONFERX02 |
associate profile 2 register XCODECX02 |
associate profile 3 register MTPX02 |
dspfarm profile 2 transcode |
codec g729abr8 |
codec g729ar8 |
codec g711alaw |
codec g711ulaw |
codec g729br8 |
codec g729r8 |
maximum sessions 6 |
associate application SCCP |
dspfarm profile 1 conference |
codec g729br8 |
codec g729r8 |
codec g729abr8 |
codec g729ar8 |
codec g711alaw |
codec g711ulaw |
dspfarm profile 3 mtp |
codec g711ulaw |
maximum sessions hardware 30 |
Best regards,
Daniel
11-14-2012 04:44 AM
Considering that I already have this:
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 9
shutdown
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
shutdown
What should be your final suggestion of the config
Edson Vuma
