99xx and 79xx phones unexpected restart
Fikri FIRAT
Level 5
Level 5
Hi all,
Recently we have been facing issues with Cico IP phones, they frequently reset/restart without our control or any apply config. Does anyone else have the same issue? Any ideas for troubleshooting is appreciated.
Device logs are provided in the attachments,
Regards.
paolo bevilacqua
As often discussed and as you would have found with a search.
Reboots are caused by a short interruption in network connectivity. You may believe that your network is 100% stable, but as long phones are rebotting, for sure it is not.
