A question about call manager traces for Sip phones.
Sarg .
Level 3
Level 3
So today I create a sip based ip communicator and pressed the new call button and heard a dial tone.  I started typing my telephone number. Half way through, I heard  another secondary dial tone (which indicates mis-configured route pattern somewhere) .
However, When I look at the call manager logs, I do not actually see the digits that I was typing. With SCCP, I can see the keypad button press messages in the traces, but here, I cannot see the pressed buttons in my CUCM traces. Can anyone help with telling me how I can see button presses going to call manager .   All I can see are the logs  below which came up as soon as I got the dial tone and the final sip invite messages. I see nothing in-between.
_____________________________
__________________
|SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 10.xx.4.xx on port 56714 index 31809 with 973 bytes:
[6387070,NET]
NOTIFY sip:37184@172.5.x.xx SIP/2.0
Via: SIP/2.0/TCP 10.x.x.66:56714;branch=z9hG4bK00005b1e
To: <sip:37184@17.x.22.xx>
From: <sip:37184@172.x.22.xx>;tag=00ffb00bc50a00340000499f-00006ab4
Call-ID: 00001ab1-0000728b@10.1.2.26
Date: Sat, 14 Feb 2015 14:17:40 GMT
CSeq: 19 NOTIFY
Event: dialog
Subscription-State: active
Max-Forwards: 70
Contact: <sip:ee8b88d5-808c-5446-dac3-92e6077441a0@10.1.x.xx:56714;transport=TCP>
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE
Content-Length: 350
Content-Type: application/dialog-info+xml
Content-Disposition: session;handling=required
<?xml version="1.0" encoding="UTF-8" ?>
<dialog-info xmlns:call="urn:x-cisco:parmams:xml:ns:dialog-info:dialog:callinfo-dialog" version="18" state="partial" entity="sip:37000@10.5.2.xx">
<dialog id="12" call-id="00ffb00b-c50a000e-00004bfe-00004aef@10.xx.1.xx" local-tag="00ffb00bc50a003300006390-00002d4f"><state>trying</state></dialog>
</dialog-info>
______________________________
SIPStationD(12991) - processCommonDialogNotifyInd:   Did 12 Sending Notified SIPOffHook to new Cdfc
8 Replies 8
Ayodeji Okanlawon
Hi Serenity
Sip phones use NOTIFY in cucm to relay digits to cucm. This is similar to the keypadbutton event on sccp phones. A NOTIFY is generated for each button or digit pressed. From the trace above I can seebthe NOTIFY showing the digits 37184
Please rate all useful posts
Yes,
I see that notify for my presence state change in my logs but in the same  logs, I see no further notify messages for my button presses.   This is really odd.
Can you attach the full cucm traces? Which cucm version is this? If its <9.X then please send the SDI traces, otherwise send the SDL traces
Do you have a personal email.
I do but that is not encouraged on the forum so others can benefit from the discussions
well I have just made a sip call with my ipcc and i did see all my digits in the trace. just a different process from sccp really- with  the kplm subscription after the first digit etc.  Using what you said and a little patience, I saw everything.  I will now check the client trace and hopefully what i have learnt will help.
Cheers
Here is a more detailed explanation of how SIP calls notify cucm when they go off hook to make a call. The digit dialled here is 4080
+++++ Analysis of SIP Phone making a call +++++++++
The user picks up the phone and the IP Phone sends a NOTIFY to CUCM to indicate the start of a new dialog. This dialog begings by an offhook event
00869539.002 |14:58:13.837 |AppInfo  |SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 10.50.16.1 on port 52910 index 2748 with 976 bytes:
[46240,NET]
NOTIFY sip:9106@10.28.132.111 SIP/2.0
Via: SIP/2.0/TCP 10.50.16.1:52910;branch=z9hG4bK00002531
To: <sip:9106@10.28.132.111>
From: <sip:9106@10.28.132.111>;tag=544e42f26d0b001e000056e7-0000311c
Call-ID: 00001f54-00003e14@10.50.16.1
Date: Mon, 16 Feb 2015 12:58:13 GMT
CSeq: 11 NOTIFY
Event: dialog
Max-Forwards: 70
Contact: <sip:2b75b6a4-32c6-3ef1-d677-d9b56d34e469@10.50.16.1:52910;transport=TCP>
Content-Length: 350
<dialog-info xmlns:call="urn:x-cisco:parmams:xml:ns:dialog-info:dialog:callinfo-dialog" version="10" state="partial" entity="sip:9106@10.50.16.1">
<dialog id="6" call-id="544e42f2-6d0b000a-000037bc-00004d00@10.50.16.1" local-tag="544e42f26d0b001d00007cc9-000044a3"><state>trying</state></dialog>
</dialog-info>
++++ CUCM SIP stack processes the new connection for the phone+++++++
00869540.001 |14:58:13.837 |AppInfo  |//SIP/Stack/Info/0x0/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 (SIP_NETWORK_MSG), for event 1 (SIPSPI_EV_NEW_MESSAGE)
00869540.002 |14:58:13.837 |AppInfo  |//SIP/Stack/Transport/0x0/sipTransportProcessNWNewConnMsg: context=(nil)
00869540.003 |14:58:13.837 |AppInfo  |//SIP/Stack/Transport/0x0/sipConnectionManagerProcessNewConnMsg: gConnTab=0xe81c0d70, addr=10.50.16.1, port=52910, connid=2748, transport=TCP
++++ Next CUCM allocates a call id for this call +++++
00869546.002 |14:58:13.838 |AppInfo  |LineControl(66) - Get call instance=1 for CI=24419584
+++Next CUCM sends a 200 OK to the NOTIFY request for the new dialog ++++
00869555.007 |14:58:13.839 |AppInfo  |//SIP/Stack/Transport/0x0xe7df4d48/sipTransportPostSendMessage: Posting send for msg=0xefbe9910, addr=10.50.16.1, port=52910, connId=2748 for
00869555.008 |14:58:13.839 |AppInfo  |//SIP/Stack/Info/0x0/act_dialog_pending_resp_event: Changing from State: SUBSCRIBE_STATE_DIALOG_PENDING to state SUBSCRIBE_STATE_ACTIVE
00869556.000 |14:58:13.839 |SdlSig   |SIPSPISignal                           |wait                           |SIPTcp(1,100,71,1)               |SIPHandler(1,100,79,1)           |1,100,14,31314.75^10.50.16.1^SEP00909E9D106C |*TraceFlagOverrode
00869556.001 |14:58:13.839 |AppInfo  |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.50.16.1 on port 52910 index 2748
[46241,NET]
SIP/2.0 200 OK
To: <sip:9106@10.28.132.111>;tag=1822746380
CSeq: 11 NOTIFY
Server: Cisco-CUCM10.5
Content-Length: 0
++++ The IP Phone sends its connection ID to CUCM, its ip address and its port number+++++++++
00869541.001 |14:58:13.838 |AppInfo  |SIPStationInit: connID=2748, SEP00909E9D106C, 10.50.16.1:52910, Routed signal by connection index to (1,100,73,66)
++++ Next CUCM informs us that the NOTIFY message is for an offhook event ++++++
00869542.003 |14:58:13.838 |AppInfo  |SIPStationD(66) - processCommonDialogNotifyInd: Notified Dialogs - Did 6 State trying
00869542.004 |14:58:13.838 |AppInfo  |SIPStationD(66) - processCommonDialogNotifyInd:   Did 6 Sending Notified SIPOffHook to new Cdfc
00869542.010 |14:58:13.838 |AppInfo  |SIPStationD(66) - processSIPOffHook Primary Call Not-Found
00869543.000 |14:58:13.838 |SdlSig   |SIPOffHookInd
+++ The next thing is the USER dials a digit on the phone ++++++
This is where it gets a little complicated. So lets examine this. The first digit that is dialled generates an INVITE to CUCM like this:
In this example the user dialled "4" first so we see an "INVITE sip:4@host-IP"
00869559.002 |14:58:14.064 |AppInfo  |SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 10.50.16.1 on port 52910 index 2748 with 1445 bytes:
[46242,NET]
INVITE sip:4@10.28.132.111;user=phone SIP/2.0
Via: SIP/2.0/TCP 10.50.16.1:52910;branch=z9hG4bK000015ec
From: "Emre ESEN" <sip:9106@10.28.132.111>;tag=544e42f26d0b001d00007cc9-000044a3
To: <sip:4@10.28.132.111;user=phone>
Call-ID: 544e42f2-6d0b000a-000037bc-00004d00@10.50.16.1
Max-Forwards: 70
Date: Mon, 16 Feb 2015 12:58:14 GMT
CSeq: 101 INVITE
User-Agent: Cisco-SIPIPCommunicator/9.1.1
Contact: <sip:2b75b6a4-32c6-3ef1-d677-d9b56d34e469@10.50.16.1:52910;transport=tcp>
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "Emre ESEN" <sip:9106@10.28.132.111>;party=calling;id-type=subscriber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.1.0,X-cisco-xsi-8.5.1
Allow-Events: kpml,dialog
Content-Length: 373
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 21020 0 IN IP4 10.50.16.1
s=SIP Call
t=0 0
m=audio 20250 RTP/AVP 0 8 18 9 116 124 101
c=IN IP4 10.50.16.1
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:9 G722/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:124 ISAC/16000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
+++++ NEXT CUCM sends a trying for the INVITE it received +++++++++++
00869562.001 |14:58:14.065 |AppInfo  |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.50.16.1 on port 52910 index 2748
[46243,NET]
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
++++NOW CUCM evaluates the DTMF supported by the phone to determine how to inform the phones to send the remaining dtmf digits++++
From the INVITE cucm concludes that KPML and rtp-nte is supported
00869566.009 |14:58:14.066 |AppInfo  |setEndpointsDtmfCaps: KPML Supported.
00869566.010 |14:58:14.066 |AppInfo  |setEndpointsDtmfCaps: Detected inband DTMF support
Next CUCM generates kpml event pkg which is going to be used to receive the remaining digits from the phone
00869590.001 |14:58:14.067 |AppInfo  |SIPEventPkg::SIPEventPkg 0xe4a1d1e0 scbId[16725], event name[kpml; call-id=544e42f2-6d0b000a-000037bc-00004d00@10.50.16.1; from-tag=544e42f26d0b001d00007cc9-000044a3], id[]
+++ Next CUCM sends a SUBSCRIBE to the IP phone for kpml event +++++
00869594.001 |14:58:14.068 |AppInfo  |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.50.16.1 on port 52910 index 2748
[46244,NET]
SUBSCRIBE sip:9106@10.50.16.1:52910 SIP/2.0
Via: SIP/2.0/TCP 10.28.132.111:5060;branch=z9hG4bKce719b37856
To: <sip:9106@10.50.16.1>
Call-ID: 768fbc80-4e11e966-bed-6f841c0a@10.28.132.111
CSeq: 101 SUBSCRIBE
User-Agent: Cisco-CUCM10.5
Event: kpml; call-id=544e42f2-6d0b000a-000037bc-00004d00@10.50.16.1; from-tag=544e42f26d0b001d00007cc9-000044a3
Expires: 7200
Contact: <sip:4@10.28.132.111:5060;transport=tcp>
Accept: application/kpml-response+xml
Max-Forwards: 70
Content-Type: application/kpml-request+xml
Content-Length: 424
<kpml-request xmlns="urn:ietf:params:xml:ns:kpml-request" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:kpml-request kpml-request.xsd" version="1.0">
  <pattern criticaldigittimer="1000" extradigittimer="500" interdigittimer="15000" persist="persist">
    <regex tag="Backspace OK">[x#*+]|bs</regex>
  </pattern>
  </kpml-request>
 +++ Next we get a 200 OK to the SUBSCRIBE from the ip phone ++++
 00869595.002 |14:58:14.118 |AppInfo  |SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 10.50.16.1 on port 52910 index 2748 with 459 bytes:
[46245,NET]
SIP/2.0 200 OK
To: <sip:9106@10.50.16.1>;tag=544e42f26d0b001f0000092c-0000070a
CSeq: 101 SUBSCRIBE
Server: Cisco-SIPIPCommunicator/9.1.1
Expires: 7200
Content-Length: 0
+++ NEXT the IP phones sends the remaining digit dialled on the phone to CUCM +++
00869603.002 |14:58:14.183 |AppInfo  |SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 10.50.16.1 on port 52910 index 2748 with 573 bytes:
[46247,NET]
NOTIFY sip:4@10.28.132.111:5060 SIP/2.0
Via: SIP/2.0/TCP 10.50.16.1:52910;branch=z9hG4bK000045c8
To: <sip:4@10.28.132.111>;tag=480227084
From: <sip:9106@10.50.16.1>;tag=544e42f26d0b001f0000092c-0000070a
CSeq: 1000 NOTIFY
Event: kpml
Subscription-State: active; expires=7200
Max-Forwards: 70
Content-Length: 0
00869608.001 |14:58:14.183 |AppInfo  |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.50.16.1 on port 52910 index 2748
[46248,NET]
SIP/2.0 200 OK
CSeq: 1000 NOTIFY
Content-Length: 0
+++Next the IP phone sends the next digit. Here its important to note that the NOTIFY doesnt contain the next digit,
the NOTIFY is still the same as the first digit but the next digit is carried in the xml document attached to the NOTIFY.
At this point I will insert a paragraph from the RFC 4730 for SIP KPML
The event package uses SUBSCRIBE
   messages and allows for XML documents that define and describe filter
   specifications for capturing key presses (DTMF Tones) entered at a
   presentation-free User Interface SIP User Agent (UA).  The event
   package uses NOTIFY messages and allows for XML documents to report
   the captured key presses (DTMF tones), consistent with the filter
   specifications, to an Application Server +++++++++++++++++++++++++++
00869609.002 |14:58:14.209 |AppInfo  |SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 10.50.16.1 on port 52910 index 2748 with 877 bytes:
[46249,NET]
Via: SIP/2.0/TCP 10.50.16.1:52910;branch=z9hG4bK00003c9d
CSeq: 1001 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 209
Content-Type: application/kpml-response+xml
<?xml version="1.0" encoding="UTF-8"?>
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="0" tag="Backspace OK"/>
00869622.001 |14:58:14.210 |AppInfo  |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.50.16.1 on port 52910 index 2748
[46250,NET]
SIP/2.0 200 OK
CSeq: 1001 NOTIFY
Content-Length: 0
+++ Again we get the next digit ++++
00869624.002 |14:58:14.262 |AppInfo  |SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 10.50.16.1 on port 52910 index 2748 with 877 bytes:
[46251,NET]
Via: SIP/2.0/TCP 10.50.16.1:52910;branch=z9hG4bK0000310f
CSeq: 1002 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 209
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="8" tag="Backspace OK"/>
00869637.001 |14:58:14.263 |AppInfo  |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.50.16.1 on port 52910 index 2748
[46252,NET]
SIP/2.0 200 OK
CSeq: 1002 NOTIFY
Content-Length: 0
+++ Finally we get the last digit ++++
00869638.002 |14:58:14.390 |AppInfo  |SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 10.50.16.1 on port 52910 index 2748 with 877 bytes:
[46253,NET]
Via: SIP/2.0/TCP 10.50.16.1:52910;branch=z9hG4bK00006c1c
CSeq: 1003 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 209
Once digit collection is completed CUCM proceeds to finalise its digit analysis process.
Note that digit analysis is carried out for each digit that is recieved. I have only included the final DA here
00869648.003 |14:58:14.391 |AppInfo  |Digit Analysis: star_DaReq: Matching SIP URL, Numeric User, user=4080
00869648.004 |14:58:14.391 |AppInfo  |Digit Analysis: getDaRes data: daRes.ssType=[0] Intercept DAMR.sstype=[0], TPcount=[0], DAMR.NotifyCount=[0], DaRes.NotifyCount=[0]
00869648.005 |14:58:14.391 |AppInfo  |Digit Analysis: getDaRes - Remote Destination [4080] isURI[0]
00869648.012 |14:58:14.391 |AppInfo  |Digit analysis: match(pi="2", fqcn="9106", cn="9106",plv="5", pss="", TodFilteredPss="", dd="4080",dac="0")
00869648.013 |14:58:14.391 |AppInfo  |Digit analysis: analysis results
00869648.014 |14:58:14.391 |AppInfo  ||PretransformCallingPartyNumber=9106
|DialingPartition=
|DialingPattern=4XXX
|FullyQualifiedCalledPartyNumber=4080
|DialingPatternRegularExpression=(4[0-9][0-9][0-9])
|DialingWhere=
+++++Once this is done CUCM then proceeds to send the call out to to the intended destination as configured in the RL ++++
00869701.001 |14:58:14.435 |AppInfo  |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.250.0.13 on port 5060 index 2754
[46256,NET]
INVITE sip:4080@10.250.0.13:5060 SIP/2.0
Via: SIP/2.0/TCP 10.28.132.111:5060;branch=z9hG4bKce931ee3d74
From: "Emre ESEN" <sip:9106@10.28.132.111>;tag=16726~813ee89e-33db-4d58-9f6a-61542cc840ee-24419585
To: <sip:4080@10.250.0.13>
Call-ID: 768fbc80-4e11e966-bee-6f841c0a@10.28.132.111
Supported: timer,resource-priority,replaces
