AA TCL
Hello I have doubt how can I configure in AA TCLwith Gateway  to call at option 4 and also I need to call to extension in range 4…, my problem is the whe to press 4 always to translate to 4119 never I can to calls a other extensions 4…
application
service autoatt flash:its-CISCO.2.0.2.0.tcl
I have a num-exp 4 4119
dial-peer voice 11 voip
destination-pattern 4…
voice-class codec 1
voice-class h323 10
session target ipv4:10.79.15.11
dtmf-relay h245-alphanumeric
no vad
No, not really. Just avoid using option 4.
paolo bevilacqua
You cannot have options overlapping extensions.
Thanks Paolo do you know if I can to do anything with 4# for example?To do differs?
That when I press option 4 says to edn press #, then send the gateway 4# to dial-peer is possible?
