abbreviated dial replace softkey
House Cat
Is it possible to replace abbreviated dial softkey with combination?
For example **25 instead of "hitting AbbrDial then 25"
Jaime Valencia
No, unless you manually configure that as a translation pattern, which would mean you'd need to configure the TPs for every single user as those would change.
java
if this helps, please rate
Jaime Valencia
java
