03-18-2017 09:44 AM - edited 03-17-2019 09:50 AM
hay i have ip phone 7841 sip, communication betwen ip phone establish "ring" when i dial by number but absent "sound" "audio"
03-18-2017 04:09 PM
You need to provide a lot more info and not just say the problem.
CUCM? CME? Version? Call flow?
Most usually no audio or one way audio are routing issues, start by making sure there is full routing between endpoints.
03-19-2017 02:35 AM
i have cucm version 10.5 ,the configuration that i used is the sip because i have ip phone 7841 sip,
session sip with server cucm is good "ring", but withou the sound for answer??
03-19-2017 07:31 AM
Is this happening on all calls, or external calls only? Can you reproduce between 2 IP phones.
If external calls only are you doing NATing to your provider, is there a firewall in the media path?
03-19-2017 07:42 AM
is this hapening all calls network lan
03-19-2017 08:36 AM
To be clear, if you establish call between two phones in the same subnet, are you facing the problem?
03-19-2017 10:16 AM
its not voice no hear any sound , but ring is good
03-19-2017 08:40 PM
Have you already looked into routing issues??
03-20-2017 04:09 AM
think you valencia i fixed the problem by "ip routing"
can you to give me example configuration voice mail please
coardialy
03-20-2017 08:46 AM
For what system??
once again, you need to explain what you have, not just what you want
03-20-2017 11:07 AM
ROUTER 2921 ios 15.5(3)M4a , cme 10.5
I WANT TO CONFIGURE AND ACTIVATE VOICE MAIL
03-20-2017 11:15 AM
That's a whole different issue, and system, open a new thread, FYI, that's just the call control, you need to specify what you're going to be using for voicemail if you expect any assistance.
03-20-2017 11:18 AM
FOR EXAMPLE IF A PHONE BUSY CAN AFTER READ MESSAGE VOICE MAIL
