03-21-2007 12:08 PM - edited 03-14-2019 08:36 PM
HI,
I have a problem that i hope some can help me with.
I have a CCME version 4.0, after the upgrade from 3.x to 4.0, i got this problem. I am using B-ACD 2.1.0.0.
Then the agents talk on a phone (7920) and some is in the queue, we get a bip evry apx. 5 sec. to inform that there is some in the queue. I will like to remove this bip, because it is anoying. It looks like it is the acd tcl script that make this bip. I can not find a parameter on this and how to disable the bip.
If i know that is is posible in newer tcl scipt it is no problem to upgrade it.
Is the some persons here that can confirm this if there is a parameter to disable this bip. ?
Solved! Go to Solution.
03-21-2007 12:35 PM
Hi Soren,
You are correct here, there is a new feature added for this funtionality (it looks like you could disable this by using the no call waiting beep accept command);
IOS
12.4(9)T
12.4(4)XC
In CME 4.0 - Improved waiting call notification - When a call is waiting in a call queue, the phone users who are members of the queue's hunt group are notified by a call-waiting beep, text display, and lit message lamp.
No special configuration is required
The beep will be heard only if the ephone-dn is configured to accept call-waiting beeps (default).
accept - Allows an ephone-dn to receive incoming call-waiting beeps.
call-waiting beep [accept | generate]
***Can you try this command;
Example:
Router(config-ephone-dn)# no call-waiting beep accept
From this doc;
Hope this helps!
Rob
03-21-2007 12:35 PM
Hi Soren,
IOS
12.4(9)T
12.4(4)XC
Example:
From this doc;
Hope this helps!
Rob
03-25-2007 11:39 AM
Thanx for the info :-)
