Ad hoc and DSP
GUNGIT2012
We have CUCM10.0 and Cisco 2911 with H.323 gateway. I have checked the dsp group on 2911, their are all up and available.
Now the problem is the internal conference and external conference. When we using the conference button with internal extensions, the conference can be setup and working normally, if we want to setup the conference with outbound caller, it is ended after add the second caller.
Is there any setup on Cisco 2911 or CUCM10.0? Could you give us some suggestions to setup conference with external caller?
Hi Can you include a screen shot from your CUCM?
Go to Media Resources>Conference Bridge (and find this bridge named GZEQCF1) > Click on it and take a screen shot
-Terry
Edit: Also add the below commands on your gateway
conf t
sccp ccm group 1
associate ccm 2 priority 2
exit
no sccp
sccp
end
Wait for few mins and run below commands and post the output:
sh sccp
ping 10.161.243.91 so g0/0
ping 10.161.243.92 so g0/0
And said above screen shot from CUCM
18 Replies 18
Terry Cheema
Can you post the below output from your router:
sh run | s sccp|dspf
sh sccp
Can you also confirm what media resources you have in your Media Resource Group that's assigned to the MRGL applied to these device? MRGL is applied under the device pool (you can check from there)? Are you using G711 codec for all parties when conferencing or anything other than that (check from Region settings)
-Terry
Hi Terry,
Thanks for your kindly reply.
There is nothing with sh run | s sccp|dspf.
#sh sccp
SCCP Admin State: DOWN
Gateway Local Interface: None
IP Precedence: 5
User Masked Codec list: None
And the other settings about MRGL is correct.
Any ideas?
Thanks!
Ok according to your original post you mentioned checking DSP so I assumed you are using Hardware conferencing bridge, which clearly is not the case from your above post.
Can you also confirm you can call external numbers directly, its just the conference calls having problem?
For conferencing to work you either need a software based bridge (which is fine but it will support only G711 codec) or if you need to support other codec you need to setup hardware conferencing bridge. In your case you appear to be using software based bridge.
You need to have the conference bridge resource assigned to the MRG and corresponding MRGL applied to the device pool to have this work. If thats already done.
Check from your region settings if there is any party involved in the conference using codes other than G711 as the software bridge will only support G711.
Or your option is to configure conf bridge on your router and assign to the MRG\MRGL.
Follow any of the below link to do that if you need to do that:
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/62959-ccm-ios-dsp-farm.html
http://amyengineer.com/tag/sccp-group-configuration/
-Terry
Hi Terry,
Thanks for your help.
Sorry, Just post the wrong sh sccp. Please find the attachement for the right one. Could you please help me to check again?
BTW, we can call external numbers directly. its just conference calls having problem.
Here is the culprit, your conference bridge is showing TCP connection error. Can you confirm if its a new setup or existing setup and it stopped working?
Can you try below steps:
1) Reset conf bridge:
conf t
dspfarm profile X conference - substitue X with your config
shut
yes
no shut
exit
2) Reset SCCP:
no sccp
sccp
3) Post sh run and sh sccp
4) Also post the screen shot from CUCM showing this conference bridge (just want to confirm if it has correct name and type)
-Terry
Please help to check,thanks in advance.
GW#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
GW(config)#dspfarm profile 1 conference
GW(config-dspfarm-profile)#shu
GW(config-dspfarm-profile)#shutdown
Disabling profile will disconnect active CONFERENCING calls,
do you want to continue ? [yes/no]yes
GW(config-dspfarm-profile)#no shu
GW(config-dspfarm-profile)#no shutdown
GW(config-dspfarm-profile)#exit
GW(config)#no sc
GW(config)#no scc
GW(config)#no sccp
GW(config)#scc
GW(config)#sccp
GW(config)#end
GW#sho scc
GW#sho sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0
        IPv4 Address: 10.161.241.123
        Port Number: 2000
IP Precedence: 5
Call Manager: 10.161.243.91, Port Number: 2000
                Priority: 2, Version: 7.0, Identifier: 2
Call Manager: 10.161.243.92, Port Number: 2000
                Priority: 1, Version: 7.0, Identifier: 1
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: CCM_REGISTER_FAILED
Active Call Manager: 10.161.243.92, Port Number: 2000
TCP Link Status: NOT_CONNECTED, Profile Identifier: 1
Reported Max Streams: 40, Reported Max OOS Streams: 0
Supported Codec: ilbc, Maximum Packetization Period: 120
Supported Codec: g722r64, Maximum Packetization Period: 30
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period
: 30
TLS : ENABLED
GW#
GW#sho int gigabitEthernet 0/0
GigabitEthernet0/0 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is 1005.ca89.56b8 (bia 1005.ca89.56b8
conference bridge name,please see the attachment.
GW#sho run
Building configuration...
Current configuration : 3856 bytes
! Last configuration change at 12:35:49 UTC Thu Jan 15 2015 by cisco
version 15.2
service password-encryption
hostname GW
boot-start-marker
boot-end-marker
card type e1 0 0
enable secret 5 $1$/HQ4$PmANH7yeHFy/PLz5sTMNN/
no aaa new-model
network-clock-participate wic 0
ip cef
no ipv6 cef
isdn switch-type primary-net5
voice-card 0
 dspfarm
 dsp services dspfarm
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice translation-rule 1
 rule 1 /21002/ /83930521/
 rule 2 /^.*\(...\)$/ /32813\1/
voice translation-rule 2
 rule 1 /^32813888$/ /21999/
 rule 2 /^32813\(...\)$/ /21\1/
 rule 3 /^83930521$/ /21002/
voice translation-rule 3
voice translation-profile 1
 translate calling 1
voice translation-profile 2
 translate called 2
license udi pid CISCO2911/K9 sn FGL181612EG
hw-module pvdm 0/0
username cisco privilege 15 password 7 1511021F0725
redundancy
controller E1 0/0/0
 framing NO-CRC4
 pri-group timeslots 1-31
interface Loopback0
 ip address 10.255.255.5 255.255.255.255
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 10.161.241.123 255.255.255.0
 duplex auto
 speed auto
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.161.241.123
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.161.241.254
control-plane
voice-port 0/0/0:15
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.161.243.91 identifier 2 priority 2 version 7.0
sccp ccm 10.161.243.92 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/0
 associate ccm 1 priority 1
 associate profile 1 register GZEQCF1
 switchback method graceful
 switchback interval 60
 description GZEQ Conference Bridges
 codec ilbc
 codec g722-64
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729r8
 codec g729br8
 maximum sessions 5
 associate application SCCP
dial-peer voice 4 voip
 description dial-peer to cucm sub
 destination-pattern 2....
 session target ipv4:10.161.243.92
 dtmf-relay h245-alphanumeric
 no vad
dial-peer voice 1 pots
 translation-profile outgoing 1
 destination-pattern 9T
 port 0/0/0:15
dial-peer voice 3 pots
 translation-profile incoming 2
 incoming called-number .
dial-peer voice 2 voip
 description dial-peer to cucm pub
 preference 1
 session target ipv4:10.161.243.91
 no vad
gatekeeper
 shutdown
call-manager-fallback
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address 10.161.241.123 port 2000
 max-ephones 50
 max-dn 50
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login local
 transport input all
line vty 5 15
 login local
 transport input all
scheduler allocate 20000 1000
ntp server 10.163.115.7
end
GW#
-Terry
conf t
sccp ccm group 1
exit
no sccp
sccp
end
sh sccp
Hi Terry,
Thanks for your kindly help.
We made a mistake of the Conference bridge name between gateway and call-manager, now conference bridge can register to call-manager after we changed the same name.
There is also a problem about the conference call of external(PSTN):
1.I started a conference, call fisrt external number is okay, when I press the conference button, the first call is busy and waiting, I added the second external number, it can be connected, but all calls are ended when I press conference button again.
2.I started another conference, call fisrt external number is okay, when I press the conference button, the first call is busy and waiting, I added the second Internal number, it can be connected, I pressed conference button again,and the external number ended, but the internal number still online.
Can you help us to check what is the problem? Is there anything about the MTP settings on call manager?
Ok - Please confirm below:
1) Your conference bridge registered in CUCM:
Post sh sccp and attach screen shot from CUCM
2) The conference bridge is assigned to MRG
3) MRG is assigned to MRGL
4) MRGL is applied under the Device pool of the device you are trying to test.
Please rate all helpful posts.
-Terry
Hi Terry,
You're right, just checked what you mentioned, we missed the conference bridge on MRG, now it is working, thanks for your kindly help again.
Good stuff - glad to know its working. Please mark the thread as answered and do rate all helpful posts.
-Terry
Hi Terry,
Today I tried to have a test about the conference bridge for external number again, but after added the second external number, all calls ended.
I am sure that there is nothing changed after we tested successfully last time.
CUCM:
1) conference bridge GZEQCF1 registered in CUCM
Here is the sh sccp and sh  run | s sccp|dspf
GW#sh sccp
        Port Number: 2000
IP Precedence: 5
Conferencing Oper State: ACTIVE - Cause Code: NONE
TCP Link Status: CONNECTED, Profile Identifier: 1
: 30
TLS : ENABLED
GW#sh run | s sccp|dspf
 dspfarm
sccp
sccp ccm group 1
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g722-64
 codec ilbc
 maximum sessions 5
Could you help me to check again, it is so strange!
Thanks.
Strange - can you try this:
conf t
shut
yes
no shut
Confirm and once the conference bridge is registred - test again.
-Terry
