AD Multiforest integration witch CUCM 7.1.5
Hi Everybody,
I am having callmanager version 7.1.5 & AD 2003 & 2008,
I wants to do Multiforest AD integration witch CUCM 7.1.5.
So I want to know is it possible to do multiforest integration with CUCM 7.1.5.
Regrads
Deepak
Hi Deepak,
For multiforest integration You will have to be on 8.0(1), or later.
Ronak patel
Rate helpful posts by clicking stars belw the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
ronpatel
Level 8
Level 8
Hi Deepak,
No CUCM 7.x do not support multiforest integration. You will have to be on 8.0(1), or later.
https://supportforums.cisco.com/docs/DOC-16356 ( For 8.0.1 and + release ).
Ronak Patel
Hi Ronak
Thankx for tour reply,
But in below doc , 7.x can support ADAM and LDS
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/directry.html
So doest it means it supports Multiforest integration as ADAM and LDS are used for Multiforest integration with CUCM.
Thanx
Deepak
Hi Deepak,
Ronak patel
Thanx a lot Ronak
