IP Telephony and Phones
Labels
Is the port marked "For maintenance only" the console port? Since the package didn't came with any console cable, I used the usual console access with the 38400 baud, but not successful. I changed the baud to 9600 via SSH, the same! The "xoncifuratio...
Jack Liou by Level 1
  • 444 Views
  • 2 replies
                   Hello guys!I have an interesting situation with a hunt pilot in CUCM version 8.5. I've configured a hunt pilot with number 20 and my dial plan for the directory numbers is 2xx. If a dial the hunt pilto, nothiung happens. So i chang...
fuhrersk8 by Level 3
  • 1637 Views
  • 4 replies
Hello,I have a PRI line and i want to cofnigıre  444 XXXX  DID  number IPT LineWhen I called 444 XXXX ,calls ring one time and end.Ex: if outbound  calls PRI line , it should be ring 8945 Here is my voice gateway configredundancy!!controller E1 0/0/0...
KY_ by Level 4
  • 1065 Views
  • 6 replies
Hi all, Looks to me like a simple Question, however I wasn't able to find any Documentation or Posts on the Web… We're using CUCM 7.0.1 with the Mobile Connect Feature that forward Calls to Mobile Phones.The Mobile Connect enabled Line is also a me...
