Add failed. Cannot insert or update pattern. A DN exists with the same pattern and partition.
Ahmed habib
Level 3
Level 3
Hello, I added 7811 phone to the CME and gave him dn 55553 and I am trying to add a route pattern on CUCM that match just that phone but it can't accept it as 55553
It accepts only when I put 5555x but I am afraid to cause a problem or loop as I have a random dial plan
The error say (Add failed. Cannot insert or update pattern. A DN exists with the same pattern and partition.)
Dennis Mink
can you check your route plan report and search for 55553 and see if its already there, if so, delete it and add the router pattern again.
Please remember to rate useful posts, by clicking on the stars below.
5 Replies 5
Dennis Mink
please de-associate the DN, that resolved my issue.
This was really helpful
Thanks a lot for the post
I ran into this same issue and deleting the DN allowed me to setup the translation pattern.
Thanks!
hola revisa si no tienes en hount pattern algo configurado en la ext o en translations pattern por ahi esta el tema  saludos....
