Add ISDN service BRI on the voice router 2911
Arbenjamin
Dear All,
There is a Cisco 2911 and ISDN BRI service in the test lab, and we would like to integrate the ISDN service on the Cisco 2911 router.
Should we purchse the 1-port isdn bri wan interface card or 1-port analog modem interface card?
Please share any experience or advice.
Many thanks.
Best Regards,
Ben Lai
That is fine. Then go a BRI card
You need another BRI card hosted on another router. One side should be running user emulate and other side should be running network emulate. Then you need to connect them using RJ-45 Cables with correct color coding.
Dear mohammed al baqari,
Thank for your kindly response.
However, the ISDN BRI line is provided the Telecommunication company.
Best Regards,
Ben
Arbenjamin
We will order this module and implement it .
Thanks for your time :)
Best Regards,
Ben
