add Welcome IVR msg (auto attend) on ISR 4331
Dears,
i have ISR 44331 router work as voice router and need to add recorded Message (auto attend) any one call me on the PSTN line hear it before connect to IP Phones.
how can i do that?
Jaime Valencia
you should be able to do that with TCL scripting, you'd need to create the script to do this.
java
if this helps, please rate
dear jame,
 can you explain more to me, thanks.
You would need to develop a TCL script to do what you're asking, or pay a consultant/partner to do it for you, or buy a 3rd party solution to do that, like the one from parsec telesystems (although theirs would run on Windows and is for CUCM only).
java
