10-14-2017 08:55 PM - edited 03-17-2019 11:22 AM
i want to add a secondary ip address on the H.323 gateway interface so that when this vlan goes down the secondary ip is up but im wondering will it affect the gateway operations? do i need to add another "h323-gateway voip bind srcaddr <secondary ip address>"?
10-15-2017 09:45 PM
10-16-2017 12:28 AM
I don't think you can do this. You can only add a single srcaddress for h323 signalling from memory. Your best bet will be to use the loopback address on the gateway as your h323 srcaddress and configure the same address on cucm
