08-26-2018 11:26 PM - edited 03-17-2019 01:23 PM
Hi Experts,
I have a simple question which I cant seem to crack.
How do you add a single testing number to a BE6000s running CUCM 11.5 that already has a number block that was assigned at the installation. We are busy with moving the number block to a different service provider and want to be sure when we port the numbers over that we will not have downtime.
We are using a PRI connection.
Current installed number block is 011 *** 9300 to 9499
Testing number is 010 *** 3324
Where would one enter the number to be reachable from outside? Assuming all Partitions etc are working fine.
Best Regards,
Solved! Go to Solution.
08-26-2018 11:46 PM
08-26-2018 11:46 PM
08-26-2018 11:54 PM
08-27-2018 07:37 AM
Yes, your GW needs to be configured to route the calls to your CUCM, and your telco needs to provide you with the PRI or SIP trunk which will route the calls from the PSTN to your premises.
