Conference calls for 5 contancts
aydinlar
Hi everyone;
I have Cisco 3845 Router, I want to make a conference with 5 contacts but I can make with only 2 contacts.
How I can increase number of contacts during conference calls?
The config is below;
telephony-service
no auto-reg-ephone
em logout 0:0 0:0 0:0
max-ephones 240
max-dn 480
ip source-address 10.10.10.1 port 2000
auto assign 32 to 32 type anl
calling-number initiator
service phone videoCapability 1
service phone webAccess 0
timeouts interdigit 3
timeouts transfer-recall 30
system message AYDINLAR
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file location flash:
user-locale 1 U1 TR
network-locale 1 U1
load 7914 S00105000400
load 7912 CP7912080003SCCP070409A.sbin
load 7931 SCCP31.8-4-2S
load 7937 apps37sccp.1-4-5-7.bin
load 7960-7940 P00308010100
load 7941 SCCP41.8-4-2S
load 7942 SCCP42.8-4-2S.loads
load 7945 SCCP45.8-4-2S
load 7970 SCCP70.8-4-2S
load 7975 SCCP75.9-4-2-1S
time-zone 40
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 22164.. extension-length 4 extension-pattern 64..
bulk-speed-dial prefix 0
voicemail 6000
max-conferences 15 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh passenger.au
web admin customer name Customer password cisco
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern 64..
transfer-pattern 65..
transfer-pattern 66..
secondary-dialtone 9
login timeout 5
after-hours block pattern 1 9
after-hours block pattern 2 90
after-hours block pattern 3 900
after-hours pstn-prefix 4 71
night-service code *13271
fac standard
create cnf-files version-stamp 7960 May 30 2018 11:22:44
ephone-template 1
softkeys idle Newcall Redial Pickup Dnd
ephone-template 2
network-locale 1
user-locale 1
ephone-template 3
conference admin
network-locale 1
user-locale 1
keep-conference drop-last
button-layout 7931 1
ephone-template 5
softkeys remote-in-use CBarge Newcall
softkeys hold Resume Newcall Join
softkeys connected TrnsfVM Park Acct ConfList Confrn Endcall Trnsfer Hold
busy-trigger-per-button 2
ephone-template 16
softkeys hold Newcall Resume Select Join
softkeys idle Cfwdall ConfList Dnd Gpickup HLog Join Login Newcall Pickup Redial RmLstC
softkeys seized Redial Pickup Gpickup HLog Meetme Endcall
softkeys connected Acct ConfList Confrn Endcall Flash HLog Hold Join Park RmLstC Select Trnsfer
ephone-dn 69 octo-line
number 6469
label  Conference_tel
description Conference_tel
name Conference_tel
corlist incoming kategori-A4
ephone 69
device-security-mode none
video
mac-address 0004.F2E6.C9F8
ephone-template 3
type 7937
no dnd feature-ring
keep-conference endcall
button 1:69 2m6
Thanks...
Chris Deren
It appears you created software based conferencing which only supports up to 3 participants, if you need more than that you need to have DSPs and configure hardware conferencing per the following guide:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmeconf.html
