Bookmark
Subscribe
653
SIP trunk to CME issues
carl_townshend
I am having issues with a SIP trunk from my CME to a CUCM
The call works when going from CUCM to CME but not the other way around
I have done a debug and getting the error below,
Any ideas?
071053: *Aug 23 19:01:01.167: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=88014853, Peer Info Type=DIALPEER_INFO_SPEECH
071054: *Aug 23 19:01:01.167: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=88014853
071055: *Aug 23 19:01:01.167: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
071056: *Aug 23 19:01:01.167: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
071057: *Aug 23 19:01:01.167: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=8000
     2: Dial-peer Tag=8001
071058: *Aug 23 19:01:01.169: //14505/90B5FEA183E3/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x7F7B219F2840
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           :
Called Number            : 88014853
Source IP Address (Sig  ): 0.0.0.0
Destn SIP Req Addr:Port  : :0
Destn SIP Resp Addr:Port : :0
Destination Name         :
071059: *Aug 23 19:01:01.169: //14505/90B5FEA183E3/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
Run debug ccsip mess on CME for failing call.
I just did as instructed and got the following
JCB-CME#csim start 88014853
csim: Test started.This command can only be run one at a time.
csim: called number = 88014853, loop count = 1 ping count = 0
csim err:csim_do_test invalid major major(1024) minor(0x0)
csim err csimDisconnected recvd DISC cid(39597)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
Run "debug ccsip messages", also post your CME config.
Did you check inbound CSS for your SIP trunk in CUCM ?
