Adding a subscriber communications manager server in a cluster
daniel.espi
at this moment, we have only one publisher/subscriber in our IP telephony solution. Next month, we want to give it some redundancy adding a new subscriber and creating  a cluster with these two servers. I haven´t found any guideline about  adding a new subscriber, does anyone know if there is a guideline about it?
Thanks in advance
Adrian Saavedra
Level 7
Level 7
Hello Daniel,
Sure. Here you can find the guide lines (I'm assuming you have a cluster version 7.X):
Install Software from a DVD on a Subsequent Node
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/7_1_2/install/cmins712.html#wp485604
Apply a Patch During Installation of a Subsequent Node
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/7_1_2/install/cmins712.html#wp485792
Add a New Node to an Existing Cluster
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/7_1_2/install/cmins712.html#wp485892
Hope it helps, please rate if it does.
Good luck!
Kind regards,
- Adrian.
Adrian Saavedra
Level 7
Level 7
Hello Daniel,
Good luck!
Kind regards,
- Adrian.
Thanks for all.
