Adding new server to existing cluster
michaeljbyrne
Current enviroment
4 servers
2 CM groups
8 device pools
Someone decided to add a new server that will be placed in their new Data Center.
How can I effectivly utilize this new server since I already have the CM groups configured with their max 3 servers per group.
Besides editing the groups and possibly making certina servers act as a TFTP server only is there any other design I could use it for?
Chris Deren
Well, it depends on what purpose was the server purchased for. if the intent is use it for DR you will need to adjust your CM groups accordingly to ensure this sevrer is listed as the last entry in the group. But before you go that route you need to plan out your strategy, i.e. understnad your current UC and network topolpgy, DR requirments, etc.
Chris
