11-10-2021 01:08 PM
Dose anyone know how to add the altrnate parameter of TFTP address on 8845. User access menu but doesn't now how to add (.) when typing ip address.
Solved! Go to Solution.
11-10-2021 02:33 PM
Keypad Key Special Characters
One (1) / . @ : ; = ? -_ & %
Leonardo Santana
11-10-2021 01:15 PM
Step 1
On the Cisco IP Phone, press Applications , choose Admin settings > Network setup > Ethernet setup > IPv4 setup > TFTP Server 1.
Step 2
If you have assigned a static IP address to the phone, you must manually enter a setting for the TFTP Server 1 option.
Step 3
If you are using DHCP, the phone obtains the address for the TFTP server from the DHCP server. Check that the IP address is configured in Option 150.
Step 4
You can also enable the phone to use an alternate TFTP server. Such a setting is particularly useful if the phone recently moved from one location to another.
Step 5
If the local DHCP does not offer the correct TFTP address, enable the phone to use an alternate TFTP server.
This is often necessary in VPN scenario.
Leonardo Santana
11-10-2021 01:51 PM
The problem is when you are typing the ip address the user dosent know where is the (.) key to enter the ip address example:
10.1.1.1 doesn't know who to type the (.)
11-10-2021 02:33 PM
Leonardo Santana
11-11-2021 12:56 PM
thank you this worked
11-10-2021 05:44 PM - edited 11-10-2021 11:17 PM
To enter "." on network settings, you need to use "*" and not "1".
